;SW:4M0-907-129-LQ HW:4M0-907-129-LQ --- Steering wheel
;Component:Lenks.Modul H11 0009, Coding:
;EV_SMLSKLOAU736,006008,EV_SMLSKLOAU736_006.rod
;Wednesday,11,April,2018,18:51:45:21132
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: 0A4D5F7F1CBA61972CC-805F
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00333,Driver assistance systems button,not activated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Cruise control switch with ACC,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,Initializing,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,not installed,
IDE02068-MAS00106,Time stamp-Year,2000, yr
IDE02068-MAS00107,Time stamp-Month,1, m
IDE02068-MAS00108,Time stamp-Day,22, d
IDE02068-MAS00109,Time stamp-Hours,14, H
IDE02068-MAS00110,Time stamp-Minutes,2, min
IDE02068-MAS00111,Time stamp-Seconds,16, s
IDE02068-MAS00711,Time stamp-Odometer reading,0, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 55 43 34 43 46 35 32 4A 41 30 36 33 37 36 32,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 3,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
IDE02743-IDE05742,High Beam-Light switch position,not activated,
IDE02744-MAS02201,Steering wheel heater-Temperature,26, °C
IDE02744-MAS02324,Steering wheel heater-Voltage at sensor,0.00, V
IDE02744-MAS03746,Steering wheel heater-Current: actual value,0.00, A
IDE02744-MAS04457,Steering wheel heater-PWM pulse duty factor,0, %
IDE03504-MAS03692,Personalized settings-Key 1,not recognized,
IDE03504-MAS03693,Personalized settings-Key 2,detected,
IDE03504-MAS03694,Personalized settings-Key 3,not recognized,
IDE03504-MAS03695,Personalized settings-Key 4,not recognized,
IDE03504-MAS11282,Personalized settings-Status steering wheel heater key 1,OFF,
IDE03504-MAS11283,Personalized settings-Status steering wheel heater key 2,OFF,
IDE03504-MAS11284,Personalized settings-Status steering wheel heater key 3,OFF,
IDE03504-MAS11285,Personalized settings-Status steering wheel heater key 4,OFF,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,11842.97, mV
IDE03680-IDE00618,Supply voltages-Voltage supply 5V,4978.13, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,0.00, mV
IDE05725-IDE01763,Terminal 58xs dimmer-Dimming,99, %
IDE05725-MAS03873,Terminal 58xs dimmer-Duty cycle,86, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Positive,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in permissible range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0, °/s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,outside permissible range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,13.2, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,0.0, °
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,no error,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,13.2, °
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Positive,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Positive,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Positive,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in permissible range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,outside permissible range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,13.2, °
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,no error,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,13.2, °
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in permissible range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Positive,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,0.0, °
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,0.0, °
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Positive,
Elapsed Time: 00:05
