2011 vw golf GTI BCM faulty and tampered with.
mr116
Australia
My name is marco. I have a small workshop in Melbourne Australia and have been using VCDS for a few years now. I have come across a 2011 vw golf GTI that another technician has tampered with the wiring to the BCM due to the fact that the RHF turning signal was staying on. He has touched the wiring to the BCM and now there is no voltage to the LHR turn signal, as well as the failure lamp on the instrument cluster. Not to mention 2 fault codes in the central electronics module.
I was mainly wondering if someone had a step by step procedure on how I could code a S/H module to this vehicle with VCDS as I have never done it before.
Any help would be appreciated greatly.
Thanks,
iichel
Netherlands, eastern part
C?ID=284912
Well it would be good to start with an autoscan to see if it's golf 6 or 7 and what bcm we're talking about.
Did you already have a look at the wiring to undo the wiring of the first technician?
mr116
Australia
please find attached autoscan.
Friday,06,April,2018,11:42:14:44166
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZ1KZBW323867 License Plate:
Mileage: 114680km-71258mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZBW323867 Mileage: 114680km-71258miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0050
Revision: AAH18--- Serial number:
Coding: 0403000C1C070160
VCID: 67DD620E56C1527CB9-8032
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 000 - Malfunction / Open Circuit
Date: 2047.15.31
Time: 31:63:63
RPM: 236 /min
Load: 78.8 %
Temperature: 48.0°C
Temperature: 36.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.033 V
Part No SW: 02E 300 054 L HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2604
Revision: 05351113 Serial number: 00001103261246
VCID: 1F4D3AEECE115ABC01-804A
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 163B600D092400FD681306EA90200081350800
VCID: 76E33F4AC16BBBF432-8022
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000001002
VCID: 6ED3172AB13B8334FA-803A
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 107
Mileage: 114685 km
Date: 2018.04.05
Time: 12:07:45
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AE
Coding: 48180A3A8025F1C040080080340001E441510088536D8D60648000200040
VCID: 3561F8469CEDF0ECFB-8060
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 15041 26 0512
Coding: 009795
Component: RLS 300411 05 54 0403
Coding: 0330AD
Component: LIN BACKUP HO H11 9005
8 Faults Found:
Fault Status: 00101010
Reset counter: 107
Mileage: 114685 km
Date: 2012.08.26
Time: 11:22:37
Voltage: 13.85 V
Term 50 Off
01501 - Bulb for Blinkers; Rear Left (M6)
Reset counter: 107
Mileage: 114685 km
Date: 2012.08.26
Time: 11:22:37
Voltage: 13.85 V
Term 50 Off
01800 - Light Switch (E1)
Reset counter: 107
Mileage: 114685 km
Date: 2012.08.26
Time: 11:59:55
Term 15 Off
Voltage: 12.30 V
Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 67
Mileage: 114685 km
Date: 2012.08.26
Time: 12:00:08
Term 15 Off
Voltage: 12.30 V
Term 50 Off
Reset counter: 67
Mileage: 114685 km
Date: 2012.08.27
Time: 11:19:01
Voltage: 11.90 V
Term 50 Off
Reset counter: 67
Mileage: 114685 km
Date: 2012.08.27
Time: 11:19:01
Voltage: 11.90 V
Term 50 Off
Reset counter: 107
Mileage: 114685 km
Date: 2012.08.26
Time: 12:08:28
Voltage: 12.00 V
Term 50 Off
Reset counter: 107
Mileage: 114685 km
Date: 2012.08.26
Time: 12:08:28
Voltage: 12.00 V
Term 50 Off
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA4CGV
Coding: 0000394B
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3169CC566085DCCCA7-8064
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4648405DZZZ.
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME303A005DZZZS
Serial number: 3512QSME68480A32ZZZW
Serial number: 3522QSME4E030A25ZZZU
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KDM000U1
Coding: 1892140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E33F4AC96BBBF432-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Serial number: 0026953
Coding: 830000
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H20 0420
Coding: 170B01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 71E90C56A0059CCCE7-8024
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 270411F1003298
Coding: 350003
VCID: 306FC952638FD5C4A8-8064
Component: IMMO H20 0420
VCID: 6ADB1B3A8DD36F14A6-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668532517
VCID: 275D220E5641927C79-8072
03138 - Input AUX IN
Fault Status: 00101001
Reset counter: 107
Mileage: 114685 km
Date: 2012.08.27
Time: 11:21:35
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H50 2840
Revision: AB001001 Serial number: VWZ6Z7L5058068
Coding: 0C0004000400009200
Shop #: WSC 30067 959 100543
VCID: 2E53D72A79BBC334BA-807A
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0000692
VCID: 3169CC56A885DCCCA7-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3467C5425797E9E4CC-8060
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0000692
VCID: 326BC35AAD83E7D4DE-8066
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 3561F8465CEDF0ECFB-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 3663FF4A41EBFBF4F2-8062
Part No SW: 5K0 035 730 B HW: 5K0 035 730 B
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669899977
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 244735022F7779645C-8070
0022 - Radio
U1066 00 [000] - No Communication
iichel
C?ID=284912
OK thank you very much.
I'd say replacing the BCM is not very difficult. Make an autoscan of the current coding (check), make a controller adaptation map of 09, swap BCM, place back coding and adaptation channels and marry the remotes for central locking.
However, I'm not completely sure whether replacing the BCM will solve your problems.
Knowing there has been some messing around with the wiring, I'd certainly first verify the wiring from BCM to endpoint, in this case light switch, blinker bulbs and dimmer.
Some errors are flagged as intermittent, meaning they showed up and disappeared (and may have repeated this cycle).
This could mean they are solved already. Do they return after you clear them?
mr116
Australia
Hi iichel,
I understand what you are saying, however when I first looked at the vehicle the Right hand front turn side was staying on solid as the customer had changed the front headlights to an aftermarket type. The turn signal was still illuminated even with the ignition off and key out of barrel. He then took the vehicle to another workshop who chopped and changed the wiring going into the BCM to make the front turn side function correctly, however now there is no power to the rear left turn side lamp assembly. Hence why I think that the BCM is at fault.
This problem has also caused that the turn signal to flash fast on the instrument cluster and normal on the outside. I should post a pic of the wiring mods that have been done.
I was wondering if you could provide a more step by step guide document on the BCM programming? Do I require 2 keys or is 1 enough?
PetrolDave
Westbury, UK
C?ID=1423
So it's not the BCM that's been tampered with, it's the wiring to the BCM - meaning the BCM may well be fine and all that's needed is sorting out the wiring?
iichel
C?ID=284912
that's my hypothesis, yes.
but there's a saying in medicine, choose your specialization and you choose your diagnosis. we always think about what we know best, in my case, wiring.
PetrolDave
Westbury, UK
C?ID=1423
I'm an electronic systems engineer, so my specialisation is the system - meaning I look at the wiring, the electronics and the firmware as a whole - and I've reached the same conclusion as you.
mr116
Australia
If the right hand front turn side was staying on way before the wiring was tampered with to the BCM doesn't that mean that there could have been an internal issue with the module. And now that this is no power getting to the rear left turn side, would that suggest that it would be internal aswell.
PetrolDave
Westbury, UK
C?ID=1423
Much of the BCM configuration is by coding and adaptation channels, so it could be caused by an incorrect setup not only by faulty hardware.
mr116
Australia
This problem was sorted out. It was a faulty BCM. It was replaced and program with VCDS and everything works fine.
