Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: ABS long coding lost
    Italy
    Hi guys
    I have a problem with a Polo 6R abs unit. I installed a new cluster and forgot to save abs unit long coding. Is not possibile to create by vcds.
    Is possible on vw service only. I send you autoscan, can you create long coding for me?
    Regards
    Danilo
    Monday,29,September,2014,22:48:54:05573
    VCDS Version: 12.12.3.0
    Data version: 20140822
    Dealer/Shop Name: Danilo
    VIN: WVWZZZ6RZAY258477   License Plate:
    Chassis Type: 6R (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 44 56
    Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 D    HW: 03F 906 070 D
       Component: SIMOS10.20H02 9694
       Revision: --------    Serial number:
       Coding: 001900D6200400080000
       Shop #: WSC 124697 483 00190
       ASAM Dataset: EV_ECM12TFS02103F906070D 003014
       ROD: EV_ECM12TFS02103F906070D.rod
       VCID: 234E21652AC03D06A6F-8076
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0005
       Revision: --------
       Shop #: WSC 02069 000 00000
       VCID: 8200C4E1191A540E0D9-80D7
                        Fault Frequency: 22
                        Reset counter: 67
                        Mileage: 53421 km
                        Date: 2030.14.27
                        Time: 15:25:55
                        Hex Value: 0x4007
                        Hex Value: 0x0002
                        Hex Value: 0x3213
                        Hex Value: 0x1496
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
                        Fault Status: 01100101
                        Fault Frequency: 22
                        Reset counter: 67
                        Mileage: 53421 km
                        Date: 2030.14.27
                        Time: 15:25:55
                        Hex Value: 0x4007
                        Hex Value: 0x0002
                        Hex Value: 0x3251
                        Hex Value: 0x1B96
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    00493 - ESP-Sensor Unit (G419)
                        Fault Frequency: 22
                        Reset counter: 67
                        Mileage: 53421 km
                        Date: 2030.14.27
                        Time: 15:25:55
                        Hex Value: 0x4007
                        Hex Value: 0x0002
                        Hex Value: 0x32E1
                        Hex Value: 0x1A96
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
       Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
       Component: Climatic       24 0660
       Revision: 00 10 24
       VCID: 356AEF3D9C54B3B678B-8060
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
       Component: BCM PQ25 H+4  H46 0207
       Revision: BF046001    Serial number: 0147 092100132
       Coding: 3CB02BBF08A10000003000003C2B9CD00048410F60060000200000000000
       Shop #: WSC 12469 483 00190
       VCID: 3E78F011A96270EEA91-806B
       Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  006 0903
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  006 0902
       Coding: 08BC30
       Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
       Component: J388__TSG_HL  006 0902
       Coding: 08BC32
       Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
       Component: J389__TSG_HR  006 0902
       Coding: 08BC32
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag00G H08 0020
       Revision: --------    Serial number: 003GX000X4FI
       Coding: 003047
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A90ACC1EDAACC4E059-801F
       Serial number: 3572SRB40000B0150B1U
       Serial number: 3582SRB40000B00D091-
       Serial number: 3515RRB405T6DUG679E3
       Serial number: 3525RRB405P6NG4E59CV
       Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
       Component: KOMBI         H03 0505
       Coding: 140A01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 336ED1259A20AD8656F-8066
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 6R0 937 087 D
       Component: GW-K-CAN TP20 0207
       Coding: 002200
       VCID: F0E49E2923B6569EEBD-80A5
       Component: IMMO          H03 0505
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAD08C410D6AAC4EA59-80BF
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664346325
       Coding: 010100
       VCID: 2A50CC4145EAEC4EE59-807F
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11230
       Shop #: WSC 00788
       VCID: 2F66DD55EA088966327-807A
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K7087193
       Coding: 0100040002
       VCID: 6BDE09458A9035465EF-803E
    Stoke on Trent, England
    Welcome to the forum Danilo.
    All those codes are in Ross-Tech Wiki
    New User Keith
    Italy
    Hi Keithuk
    I don't find it in ross-tech wiki....
    On Polo 6r coding is particular because it has some part of VIM number.
    Can you help me for it?
    @Sebastian can help me?
    Received PM
    What size brakes do you have front and rear?
    United States
    ESP8.2i (and similar extremely long coded controllers such as MK60EC1) modules are typically coded online using the dealer scan tool with a direct connection to VW/Audi headquarters. The process is called SVM, which is a system used by VW/Audi to flash update control modules, and in certain cases, to change their Coding, Adaptation and unlock Component Protection.
    We do not have enough information at this point in time to build the long coding from scratch but if you have a scan saved with the original configuration we should be able to help you enter the proper coding. If you do not have a scan saved in the original condition I would send the vehicle to the dealer for coding.
  6. Likes Uwe, Jack@European_Parts, jakematic liked this post
    I'm starting to like Seb's suggestion more and more: Automatically save every Auto-Scan done, whether the user wants it saved or not.
    Italy
    Received PM
    Front 288x25mm
    Rear 230x9mm
  9. #8
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Hard to disagree.
    I had figured your long-term direction on this class of problems (coding, immo, CP) would be Cloud-based, though.
    Jason
  10. Likes Jack@European_Parts, jakematic liked this post
  11. #9
    Try this base coding and see if it accepts it.
    113b400d09270002880f02eb90200002300000
    Man I have been on the mandated auto-scan mission forever...........
  12. Likes jyoung8607, jakematic liked this post
  13. #10
    If you really do not want to do SVM, i would come up with this:
    210228E3217200BA842914E984D800401300
    or:
    210228E3217200BA842914E982D800401300
    No guaranties at all!
  14. Likes jakematic, Jack@European_Parts liked this post
