Results 1 to 3 of 3
Thread: VW Phaeton 2010 3.0TDI V6 EDC17
    Jul 2015
    Moon
    Hi , i have a Phaeton 2010 and i have DTC about particle filter clogged ....
    Can someone help me where i can view the details about ash load volume?
    In VCDS Hex Can V2 i dont have label for this car
    Also for dpf regeneration, i need security code for login ? I try and no success . I follow procdure for 3.0TDI V6 (uhds) and not work
    Here is my full scan attached
    Thank you in advance
    Monday,02,April,2018,10:18:14:27059
    VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
    Dealer/Shop Name: www.turbocip.ro
    Workshop Code: xxxxxxxxxxxxxxx
    VIN: WVWZZZ3DZA8001045   License Plate:
    Mileage: 344600km-214124mi   Repair Order:
    Chassis Type: 3D (6N0)
    Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 34 36 37 38 42 46 47
              52 55 56 62 68 71 72 76 77
    VIN: WVWZZZ3DZA8001045   Mileage: 344600km-214124miles
    05-Acc/Start Auth. -- Status: Malfunction 1010
    07-Control Head -- Status: Sporadic communication error 1000
    09-Cent. Elect. -- Status: Malfunction 1010
    18-Aux. Heat -- Status: Sporadic communication error 1000
    38-Roof Electronics -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 1010
    46-Central Conv. -- Status: Malfunction 1010
    47-Sound System -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: Malfunction 1010
    68-Wiper Electr. -- Status: Sporadic communication error 1000
    71-Battery Charger -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 1010
    77-Telephone -- Status: Malfunction 1010
    Address 01: Engine (CEX)       Labels: None
       Part No SW: 3D0 907 401 G    HW: 3D0 907 401 D
       Component: 3.0TDI EDC17G000AG  0030
       Revision: --H02---    Serial number: VWX3Z0I1873107
       Coding: 0406002C191F0160
       Shop #: WSC 18560 935 591558
       VCID: 2310E61C37C3632F4FA-5184
    005633 - Relay for Supply Voltage Terminal 30 (J317)
                   P1601 - 000 - Implausible Signal
                        Voltage: 0.00 V
                        Inj. On Time: 0.00 ms
                        Bin. Bits: 00000000
                        Bin. Bits:        0
                        Temperature: -90.0C
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 001 - Restricted/Clogged - MIL ON
                        Fault Status: 11100001
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:14
                        (no units): 16.5
                        (no units): 32.5
                        (no units): 0.0
                        (no units): 2.0
    008194 - Particulate Trap Bank 1
                   P2002 - 008 - Efficiency Below Threshold
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:14
                        (no units): 16.5
                        (no units): 32.5
                        (no units): 0.0
                        (no units): 2.0
    Readiness: 1 1 0 0 0
       Part No SW: 09L 927 760 R    HW: GS1 911 4
       Component: AG6 09L 3,0 TDI RdW 3606
       Revision: --H04---    Serial number:        4532033
       Shop #: WSC 01065 000 00000
       VCID: 46D65F88E4B17607084-5160
    005913 - Functionality limited due to Engine Control Module
                   P1719 - 002 -
                        Fault Status: 01100010
                        Fault Frequency: 29
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:10:57
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H35 0047
       Coding: 0008356
       VCID: 6B80CE3C9F936B6FB7A-51F2
                000 -  -  - Intermittent
       Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
       Component:    Kessy            6850
       Revision: 00H22072    Serial number: VWX3Z0I1873107
       Coding: 0004328
       VCID: 2A0E0B3850B9B2670CC-807E
    00164 - Battery Monitoring Control Module (J367) in Emergency Mode
                        Date: 2064.00.00
                        Time: 00:00:14
                        Fault Frequency: 14
                        Reset counter: 5
                        Date: 2064.00.00
                        Time: 00:00:14
                        Fault Frequency: 14
                        Reset counter: 5
                        Date: 2064.00.00
                        Time: 00:00:14
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 CA
       Component: Sitzmemory D1 BF    1720
       Coding: 0000003
       VCID: 77A8E24CD38BDF8F432-8022
    00455 - Control Module for Access and Start Control; Comfort CAN (J518)
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    01308 - Control Module for Roof Electronics (J528)
    Address 07: Control Head        Labels: 3D0-907-048.clb
       Part No SW: 3D0 907 048     HW: 3D0 907 048
       Component: J127 KBT vorn       0031
       Revision: ABH10001    Serial number: VWZ6Z7J0236033
       VCID: 6390A61C7713232F0FA-8036
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 L
       Component: Climatronic D1      2037
       Shop #: WSC 00367 211 194846
       VCID: 2708F20C43AB8F0F132-8072
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 N    HW: 3D0 937 049 N
       Component: J519                6900
       Revision: -4005---    Serial number: --------------
       Coding: 618C0000EB2115860100000000000000
       Shop #: WSC 00404 211 101502
       VCID: 353428448907ED9F91E-8060
    10 Faults Found:
    00576 - Terminal 15
    01501 - Bulb for Blinkers; Rear Left (M6)
    01505 - Bulb for Blinkers; Rear Right (M8)
    02499 - Right Low Beam Reflector Motor (V295)
       Part No: 3D0 909 601 E
       Component: 0H Airbag 8.4E+ H12 0935
       Coding: 0012360
       VCID: 2514F80439A79D1F21E-8070
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000012
       VCID: 47C8528CE3EB6F0FF32-8012
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No SW: 3D0 920 885 T    HW: 3D0 920 885 T
       Component: J285 KOMBI-INST.    0616
       Revision: KPH06V01
       Coding: 0039101
       Shop #: WSC 43726 001 1048576
       VCID: 3B203E7CAF633BEF67A-806E
    15 Faults Found:
                        Fault Status: 00101110
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Reset counter: 206
                        Mileage: 344602 km
                        Date: 2017.12.28
                        Time: 15:12:58
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:01
                        Fault Frequency: 19
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:01
                        Fault Frequency: 15
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Fault Frequency: 15
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Fault Frequency: 56
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 68
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 68
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 63
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 07:27:22
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Fault Frequency: 61
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
    01207 - Control Module for Auxiliary Heater (J364)
                        Fault Frequency: 65
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 07:27:22
                        Fault Frequency: 11
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
    01304 - Radio
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:05
    Address 18: Aux. Heat        Labels: None
       Part No: 3D0 815 005 AP
       Component: J737__Standheizung  4405
       Revision: 00084000    Serial number: 09020869A00000
       Shop #: WSC 00091 211 89643
       VCID: 6B80CE3C9F836B6FB7A-803E
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3D0 920 885 T
       Component: J533  GW-K-CAN TP20 0616
       Coding: 7FF2F7AE3B011002
       VCID: 70BAD950B6A588B7828-8024
    19 Faults Found:
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Reset counter: 206
                        Mileage: 344602 km
                        Date: 2017.12.28
                        Time: 15:12:58
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:05
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:01
                        Fault Frequency: 19
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:01
                        Fault Frequency: 15
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Fault Frequency: 15
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Fault Frequency: 56
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 75
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 07:27:21
                        Fault Frequency: 68
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 68
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 63
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 07:27:22
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
                        Fault Frequency: 61
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:07:52
                        Fault Frequency: 65
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 07:27:22
                        Fault Frequency: 65
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 07:27:22
                        Fault Frequency: 11
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:02
    01304 - Radio
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:05
                        Reset counter: 208
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:05
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005521
       Shop #: WSC 43949 001 1048576
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 CA
       Component: Sitzmemory D1 F     1720
       Coding: 0000004
       VCID: 6FB8DA2CABDB974F9B2-803A
    Address 37: Navigation (J0506)       Labels: None
       Part No SW: 3D0 035 680     HW: 3D0 035 680
       Component: RNS-MID       H10 0210
       Revision: AB001001    Serial number: VWZ6Z7J0236033
       Coding: 020500000000002200
       VCID: 5DE490E45D3715DF39E-8008
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 207
                        Mileage: 332912 km
                        Date: 2017.08.07
                        Time: 18:37:51
                        Reset counter: 206
                        Mileage: 344602 km
                        Date: 2017.12.28
                        Time: 15:31:32
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2017.12.28
                        Time: 15:12:43
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 E
       Component: Dachmodul           0802
       Coding: 0004159
    00926 - Terminal 30
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 M
       Component: 4Z HSG              8132
       Coding: 0000040
       VCID: 3A2E3B78A04902E77CC-4B00
       Subsystem 1 - Part No: 3D1 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 3D1 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 3D0 959 703 G
       Subsystem 4 - Part No: 3D0 959 704 G
       Subsystem 5 - Part No: 3D0 909 610 E
       Component: 3O HDSG             2530
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    11 Faults Found:
    01134 - Alarm Horn (H12)
    00253 - Taillight Assembly - Rear Right
    00318 - Supply Voltage for Rear Lid Control Module
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No SW: 3D0 035 466 B    HW: 3D0 035 466 B
       Component: R12___DSP 12 Kanal  0210
       Revision: DBH03001    Serial number: BP218794952846
       VCID: 211CEC142DCF713F5D6-8074
    6 Faults Found:
                        Fault Status: 00111011
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:15
                        Temperature: 11.0C
    00420 - Front Right DSP Midrange Speaker (R104)
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:15
                        Temperature: 11.0C
                        Code Not Found: TNF 255 255
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:15
                        Temperature: 11.0C
                        Raw, Index/Key Err.: 255 255 255
    03741 - Tweeter 2; Front Right
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:15
                        Temperature: 200.0C
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:12
                        Temperature: 0.0C
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:12
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
       Component: AFS-Steuergeraet    0136
       Coding: 2214081
       VCID: 3B203E7CAF233BEF67A-806E
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000033
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000033
                        Fault Frequency: 21
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2018.01.02
                        Time: 00:00:14
                        Voltage: 12.64 V
                            ABS 1
    Address 56: Radio (J0506)       Labels: None
                        Reset counter: 207
                        Mileage: 332912 km
                        Date: 2017.08.07
                        Time: 18:37:51
                        Reset counter: 206
                        Mileage: 344602 km
                        Date: 2017.12.28
                        Time: 15:31:32
                        Reset counter: 207
                        Mileage: 344602 km
                        Date: 2017.12.28
                        Time: 15:12:43
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
       Part No: 3D1 955 119 B
       Component: Front Wiper         3501
       Coding: 0013685
       Shop #: WSC 01065 000 376832
       VCID: 280AF1304EB580771A8-807C
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 2412E500329D6417360-8070
    00086 - Parallel Battery Connection Relay (J581)
    00576 - Terminal 15
    Address 76: Park Assist        Labels: None
       Part No: 3D0 919 283 E
       Component: 10 Einparkhilfe     1107
       VCID: 2C020D205A4DAC57FE0-8078
    Address 77: Telephone
    End----------(Elapsed Time: 02:45, VBatt start/end: 13.7V/13.9V)-----------
    Try MVB 104. I think it should be something like this:
    104.1 Particle Filter Oil Ash Volume
    104.2 Particle Filter Carbon Mass (calculated)
    104.3 Particle Filter Carbon Mass (actual)
    For Security Access, try: 27971
  3. Likes turbocip liked this post
    Jul 2015
    Moon
    I will try next days .
    I will let you know
