Results 1 to 8 of 8
Thread: Screwed Up - ABS Module Coding
    Oct 2014
    2016 VW GTI Autobahn
    What wasn't done:
    1. Full backup from auto scan of all modules. Like it tells you to do, and I didn't listen.
    What was done:
    1. ABS adaptation and coding to disable and change ESC, ASR, Starting Vibration, and XDS settings.
    2. Reset all adaptation settings (assumed this would reset all to defaults). This is where the issues started I presume.
    3. Reset all to factory defaults (noticed after, not sure the difference).
    4. Reverted all settings found in the debug logs.
    5. Unplugged VCDS and power cycled the car.
    6. Drove a couple miles, stopped, power cycled the car.
    What's wrong:
    1. TPMS and ESC error's on MFD.
    Goal:
    Reset the module to factory defaults.
    The fault codes
    Sunday,01,April,2018,11:27:25:29806
    VCDS Version: Release 18.2.0 (x64) Running on Windows 10 x64
    Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
    Control Module Part Number: 3Q0 907 379 T HW: 3Q0 907 379 C
    Component and/or Version: ESC H32 0393
    Software Coding: 01FA6BA15426096D0077020941CA6880D62A9000408216B600 4300D1C009
    Work Shop Code: WSC 01383 790 50316
    ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033 (VW37)
    VCID: 4BD6A040E2B17E1CBD-801E
    0295 - Steering angle sensor
    Reset counter: 134
    Date: 2018.04.01
    Time: 11:25:50
    16412 - Display for Tire Pressure Monitoring
    Reset counter: 134
    Mileage: 43387 km
    Date: 2018.04.01
    Time: 11:26:00
    16413 - Display for Tire Pressure Monitoring
    Reset counter: 134
    Mileage: 43387 km
    Date: 2018.04.01
    Time: 11:26:00
    Nov 2016
    take it to vw and act innocent say you started it and got the faults come up on the dash....be under warranty with it being a 16 plate........
  3. Likes Uwe liked this post
    Oct 2014
    Quote Originally Posted by vw754 View Post
    Car is flashed, fully built. Service Manager is a real douche as well @ VW Folsom. Tried denying a taillight because I put a bulb in it once, when it built up condensation despite there being a TSB. Had to build a JIG with water droplets to prove my case.
  5. Likes Jack@European_Parts liked this post
  6. #4
    Oct 2014
    Still reading all over, and found THIS thread. Would make sense since I reset all adaptations. First attempt, error is still there. In case I missed a step, going to give it another shot.
    Aug 2016
    The Hague, NL
    have a look in your c:\whatever\ross-tech\vcds\debug folder and in the codinglog.txt and adaptationlog.txt. there you can find the values from where to where they changed.
  8. Likes Uwe, Jetta ,97 liked this post
  9. #6
    Oct 2014
    Did that already, step 4 I mentioned in the OP.
  10. #7
    Aug 2016
    The Hague, NL
    okay well next step would be a full autoscan I guess
    one error could be solved by doing a basic setting of the G85 steering angle sensor, the other two, about the TPMS display, I'm not sure.
  11. #8
    Oct 2014
    Thanks for the replies. Once the Steering Angle Senser was calibrated, the other errors went away by driving a short distance.
    All I needed to do, was move the steering wheel lock to lock after running the basic setting as outlined in the article I linked.
  12. Likes Jack@European_Parts, Uwe liked this post
