Results 1 to 5 of 5
Thread: 2006 Audi A3 2.0T 6MT - Buyer’s Advice Needed
    Jun 2017
    Hello guys and gals,
    Not quite sure if this is the correct place to post this but...I’m currently in the market for an A3 sportback preferably with a manual transmission and stumbled across a pretty clean example with approximately 120k miles. The dealer is asking $6,600. The car allegedly has no accidents reported.
    I live in Brooklyn and will be using this car for local travel ONLY commuting to and from work/picking up the baby from daycare. The wife has a brand new Jetta so if this has to sit out for a repair or two occasionally it’s not that big of a deal, but my main question here is this:
    What should I be on the look out for with the A3 8P’s as far as drivetrain/electrical are concerned?
    Are there any well known issues with this car in general?
    Is the timing interval the standard VAG (inspect belt/tensioner) at 60k/80k/100k?
    Does anyone have any experience with the 6 speed standard transmission?
    Is the turbo on the 2.0T prone to consuming tons of oil/leaking tons of oil much like the 2.0Ts/1.8Ts in the VW line up from the early 2000’s?
    Should I consider a different small hatchback?
    Am I wasting my time and money with this car?
    Thanks in advance!
  2. Likes Eric liked this post
  3. #2
    I've had a 2006 since new. My son drives it now. However, it has much lower miles. It has not had any major problems.
    One thing to find out: The BPY engines had an issue with the cam / high pressure fuel pump interface. IIRC, Audi extended the warranty on the relevant parts and repair to 120,000 miles. I suggest finding out whether the fix for that has been applied.
  4. Likes brooklynt3ch11214 liked this post
  5. #3
    Jun 2017
    Thank you for the response! I’ll definitely take a deeper look at the BPY extended warranty. I’ve broadened my search area and found a few in eastern PA with lower miles but they’re also asking closer to $10k. I’m more partial to the facelifted 8P’s but since this is a commuter car I’m trying to keep it as cheap as possible.
    Was yours/your son’s a 6 speed? If so is there a specific brand of clutch you’d recommend for it?
  6. #4
    Quote Originally Posted by brooklynt3ch11214 View Post
    Yes, 6MT. Has not needed a clutch.
  7. Likes brooklynt3ch11214 liked this post
  8. #5
    Jun 2017
    Excellent, good to know.
