Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: New member - going to need some help
  1. #21
    I wonder if the Battery Management system is shutting down power because it hasn't been told about the new battery?
    I don't think this car has a real BMS that keeps history and can/should be told when the car gets a new battery.
  2. Likes PetrolDave liked this post
  3. #22
    What is being referred to by the term "Electric Load Controller"?
  4. #23
    Module 09, the CECM / BCM.
    It probably has some rudimentary logic that monitors battery voltage and shuts off loads (like interior lights that are unintentionally left on) based on that.
  5. Likes PetrolDave liked this post
  6. #24
    New User
    Mar 2018
    Some interesting notes from last night. 1) Clearing codes using the "OBD-II Function" tab apparently was not clearing the codes, so I went through the modules individually and cleared codes. 2) I was not able to adapt the battery to the regulator - under "select module" then the "drivetrain" tab there are 3 options for battery but each one gives a pop-up stating "No response from Controller." Those 3 options I tried are 21-Engine III/Batt 2, 61 - Battery Regul., and 71 - battery charger. These must not be available on this car. However, clearing the codes did appear to narrow down my problems. My guess is that the ignition switch is the root cause of my problem, although I am concerned about the G28 sensor that keeps coming back (I've replaced this sensor). Take and look and tell me what you think, thanks!
    Monday,16,April,2018,17:35:27:15384
    VCDS Version: 18.2.0.3 (x64)
    VIN: 3VWJM71K28M056478   License Plate:
    Mileage: 284730km-176923mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWJM71K28M056478   Mileage: 284730km-176923miles
    Address 01: Engine        Labels: None
       Part No SW: 07K 906 032 UM    HW: 07K 906 032 Q
       Component: United.342      G   19
       Revision: --H01---    Serial number: VWX7Z0G824R0JF
       Coding: 0000001
       Shop #: WSC 00001 000 00000
       VCID: 0831555D7B0F230450-805C
    005699 - Please check DTC Memory of Electric Load Controller
                   P1643 - 001 -
                        Fault Status: 01100001
                        Mileage: 284739 km
                        Time: 00:10:45
                        Load: 0.0 %
                        Temperature: 3.0°C
                        Temperature: 3.0°C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 12.192 V
    000802 - Engine Speed Sensor (G28)
                   P0322 - 004 - No Signal
                        Mileage: 284739 km
                        Time: 00:22:25
                        Load: 0.0 %
                        Temperature: 3.0°C
                        Temperature: 3.0°C
                        Voltage: 10.795 V
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       Shop #: WSC 00066 000 00000
       VCID: 3FA38E816E41A4BC21-806A
       Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 6EFD03C579AB1D34FA-803A
                013 - Check DTC Memory
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000000750036
       Coding: 04050E234004150007140000001400000008730B5C000100000000000000
       Shop #: WSC 00066 123 12345
       VCID: 6FC31EC17EA1143CF1-803A
       Component: Wischer 260907 020  0501
       Coding: 00038805
       Shop #: WSC 00066
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M0330NS
       Coding: 0013889
       VCID: 6CF909CD4FB7EF24D4-8038
       Subsystem 2 - Serial number: 6332MSME147F3A06H
       Subsystem 3 - Serial number: 6342MSME1B3F1472G
       Subsystem 4 - Serial number: 6351HSME0F7B400AE
       Subsystem 5 - Serial number: 6361HSME0F7A035BJ
       Subsystem 6 - Serial number: 63727SME0F11146D1
       Subsystem 7 - Serial number: 63827SME0E11457C5
    00591 - Seat Belt Switch; Driver (E24)
       Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
       Component: Lenksäulenmodul 036 0070
       Coding: 0010021
       VCID: 00214D7D533F1B4418-8054
    00002 - Transmission Control Unit
    02413 - Switch for Selector Lever Position P Lock (F319)
                008 - Implausible Signal
       Part No SW: 1K0 920 954 F    HW: 1K0 920 954 F
       Component: KOMBIINSTRUMENT 3HL 1212
       Revision: V0002000    Serial number: VWX7Z0G824R0JF
       Coding: 0021203
       VCID: 2F43DEC1BE21543CB1-807A
                        Fault Status: 01101010
                        Reset counter: 103
                        Mileage: 284739 km
                        Time: 00:17:40
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 290707F1000176
       Coding: E9807F070002021002
       VCID: 3041DDBDA31F4BC4A8-8064
                        Reset counter: 103
                        Mileage: 284739 km
                        Time: 00:09:15
       Component: IMMO            3HL 1212
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000606478827
       Coding: 0001205
       VCID: 3B5BFA917A59B89C0D-806E
                        Fault Status: 01100101
                        Reset counter: 103
                        Mileage: 284739 km
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.070 H08 1901
       Shop #: WSC 02069 000 90108
       VCID: 354FECA95C7D6EECFB-8060
                000 -  -
       Component:    KSG PQ35 RDK 052 0221
       Coding: 1B900F880186083F3F04058FB0880F0488DCA0
       VCID: 0429416D472707643C-8050
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000561678827
       Coding: 0001204
       VCID: 3C59F98D7F57BFA404-8068
    Address 56: Radio
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000002155425
       Coding: 0001168
       VCID: 3E5DF385694BADB42A-806A
       Component:    RDK              0450
       Coding: 0100101
    00667 - Ambient Temperature Signal
                        Fault Status: 01111000
                        Reset counter: 103
                        Mileage: 284739 km
                        Time: 00:12:09
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000002151119
       Coding: 0001168
    End-------------------------(Elapsed Time: 01:11)--------------------------
  7. #25
    New User
    Mar 2018
    Does anyone have information on the G28 Crankshaft Position Sensor (CPS or CKS) for this car. 2008 Jetta S with the 82 or 84 pin ecu. Specifically I want to know which pins in the ECU the G28 wires terminate and the "ignition-on" voltage readings for the 2 (+) wires on the G28.
  8. #26
    Quote Originally Posted by 25Tjetta View Post
    Please see: Where do I get a Wiring Diagram?
    You may also find this helpful: How to read wiring diagrams - the videos.
  9. Likes 25Tjetta liked this post
  10. #27
    New User
    Mar 2018
    Well folks, I am out of ideas.
    As stated, G28 Crankshaft position sensor is my only known error. I have continuity through all 3 wires from the g28 sensor to the ECU. I've tried multiple new (1 OEM, 1 from auto parts store, 1 out of the car that I took the 5 speed from) G28 sensors. I've tried to use the ECU out of the donor swap car.
    Any further advice for me at this point?
