Results 1 to 3 of 3
Thread: 2010 Audi S4 after some advice please..
    Mar 2018
    car was accident damaged , all is back to nomal now apart from airbag module.. has the crash data stored..
    can i code in a new module with VCDS ? if so is it just a case of copying old coding and pasting into new module?
    most of the fault codes in that scan are gone now just the airbag ones remain , not sure if am doing right or wrong by posting the full scan am sure i read when i signed up thou to post full scans if i am wrong i will delete haha sorry.
    thanks in advance Paul.
    also here is a full scan of it if anyone is interested
    Friday,30,March,2018,14:10:09:24744
    VIN: WAUZZZ8K6AA104203   License Plate:
    Mileage: 101220km-62895mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 30 3C 42 46 47 52 53
              55 56 5F 62 72
    VIN: WAUZZZ8K6AA104203   Mileage: 101220km-62895miles
    05-Acc/Start Auth. -- Status: Malfunction 1010
    30-Special Function II -- Status: Malfunction 1010
    46-Central Conv. -- Status: Malfunction 1010
    Address 01: Engine (J623-CAKA)       Labels:. 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551     HW: 8K0 907 551
       Component: 3.0T SIMOS84  X06 0006
       Revision: --X06---
       Coding: 0104000C240F0228
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS8K0907551 A02008
       ROD: EV_ECM30TFS0218K0907551C.rod
       VCID: 6E843E9730110FF7904-803A
    6140 - Fan 1 Control Circuit
              P0691 00 [032] - Short to GND
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:00:40
                        Coolant temperature: 6 °C
                        Intake air temperature: 7 °C
                        Voltage terminal 30: 10.968 V
                        Unlearning counter according OBD: 32
                        Engine speed: actual: 0 /min
                        MAF_ENVD: 0.00000 mg/stroke
                        Coolant temperature (unfiltered): 6.0 °C
                        Engine: operating status: ES
                        Engine load: 0.000000 %
                        Vehicle speed: actual: 0 km/h
    6443 - Power Supply Terminal 30
              P1602 00 [096] - Voltage too Low
                        Time: 00:00:00
                        Coolant temperature: -40 °C
                        Intake air temperature: -40 °C
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 0.000 V
                        Coolant temperature (unfiltered): 34.5 °C
    6487 - Engine Off Timer Performance
              P150A 00 [096] - -
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:02:57
                        Engine speed: 125.00 /min
                        Normed load value: 5.9 %
                        Coolant temperature: 27 °C
                        Intake air temperature: 3 °C
                        Voltage terminal 30: 10.562 V
                        Unlearning counter according OBD: 36
                        Engine speed: actual: 96 /min
                        Coolant temperature (unfiltered): 27.0 °C
                        Engine: operating status: ST
                        Battery voltage: 10.562500 V
    Readiness: 0110 0001
       Part No SW: 8K1 927 156 B    HW: 0B5 927 156 E
       Component: 0B5 30TFSIRdW H03 0003
       Revision: --H03---    Serial number: 0000000731
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A02043
       ROD: EV_TCMDL501.rod
       VCID: 3430ECFF1EBD6527A60-8060
    8013 - Body Control Module (Central Electric)
              U0140 00 [032] - No Communications
                        Reset counter: 33
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:02:22
                        Engine speed: 0 /min
                        Transmission input speed: 0 /min
                        Transmission output speed: 0 /min
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 9 °C
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 290508
       VCID: 7AAC02C77CD953573CC-802E
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:25:37
                        Hex Value: 0x0000
                        Hex Value: 0x1082
                        Hex Value: 0x0003
                        Hex Value: 0x245E
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0326
       Coding: 011100
       VCID: 015E752B110F008F7D6-8054
       Subsystem 1 - Part No SW: 8T0 959 754 AG    HW: 8T0 959 754 AG
       Serial number: 0509000070410018
       Serial number: 0209000092452013
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:56:44
                        Reset counter: 94
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:56:55
                        Fault Status: 00101101
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 02:13:52
       Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
       Component: KLIMA 3 ZONEN H08 0171
       Revision: D1000000    Serial number: 01081220090674
       Coding: 66140000
       VCID: 77AA1BF34FCB4E3F432-8022
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:00:17
                000 -  -  - Intermittent
                        Reset counter: 88
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:25:32
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000409252
       Coding: 260050914074AF010001000300001D0D0F1D430A00010141000000
       VCID: 3C20C4DF366DAD676E0-8068
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 011209  H05 0070
       Serial number: SWF09120010043
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10698807
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002711090984
    6 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Fault Status: 00101100
                        Reset counter: 96
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 02:11:00
                        Reset counter: 95
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:00:00
                        Reset counter: 93
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:49:00
    00532 - Supply Voltage B+
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:57:00
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:11:00
    03423 - Control Module for Vehicle Positioning System Interface
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:01:00
       Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0050
       Revision: 11001001    Serial number: 39840933901072
       Coding: 10010D
       VCID: 40D8B02F5A85C987328-8014
    01626 - Sensor for Parking-Aid; Front Right (G252)
                        Fault Status: 00101001
                        Reset counter: 94
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 01:24:28
                        Temperature: 5.0°C
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                        Fault Status: 01101001
                        Reset counter: 48
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:04:27
                        Temperature: 5.0°C
                        Reset counter: 88
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:25:43
                        Temperature: 14.0°C
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 8K0 907 561     HW: 8K0 907 561
       Component: ACC2          H08 0080
       Coding: 002B96
       VCID: 6FBA2393379B06FF9B2-803A
                        Reset counter: 88
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:50
                        Temperature: 29.0°C
                        Voltage: 11.90 V
                        Bin. Bits:    00000
                        Hex Value: 0x044B
                        Hex Value: 0x0044
                        Speed: 28.8 km/h
                        Lateral Accel.: -7.75 m/s^2
       Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EFD083V45
       Coding: 30363435363030303030554A3052384B3053
       VCID: 41DEB52B510FC08F3D6-8014
       Serial number: 6334MSME4E616C20I
       Serial number: 6344MSME4D443A49P
       Serial number: 6352QSME414556068
       Serial number: 6362QSME7C45060EQ
       Serial number: 63732SME4D464F002
       Serial number: 63832SME576745753
    11 Faults Found:
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:54
    9442587 - Igniter for battery interrupt
              B1015 1B [136] - Resistance Too High
                        Fault Frequency: 9
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:00:30
              B1007 1B [137] - Resistance Too High
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:54
              B1000 1B [136] - Resistance Too High
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:54
    9437467 - Igniter 2 for Driver's Airbag
              B1001 1B [136] - Resistance Too High
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:54
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:55
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [136] - Open or Short to Plus
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:01:06
    9444137 - Front Passenger's Front Airbag Crash Sensor
              B101B 29 [136] - Signal Implausible
                        Mileage: 101224 km
                        Date: 2009.07.01
                        Time: 22:28:16
    9445397 - Key switch for deactivation of passenger-side airbag
              B1020 15 [136] - Open or Short to Plus
                        Mileage: 100811 km
                        Date: 2017.08.01
                        Time: 01:21:45
    9446677 - Redundant signal path for airbag shut-off; passenger side
              B1025 15 [136] - Open or Short to Plus
                        Mileage: 100811 km
                        Date: 2017.08.01
                        Time: 01:21:46
    9447424 - Front crash data stored
              B1028 00 [137] -  -
                        Mileage: 101225 km
                        Date: 2017.11.03
                        Time: 20:11:51
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Revision: --------    Serial number: 90319IL20002S
       Coding: 00003E
       VCID: 3E24CED72071BF77404-806A
                        Fault Frequency: 62
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:25:26
                        Fault Frequency: 10
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:26:21
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:11:43
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 02:09:12
       Part No SW: 8K0 920 981     HW: 8K0 920 981
       Component: KOMBIINSTR.   H04 0255
       Revision: 00000000    Serial number: CJ932UGA9
       Coding: 2F07090006002600010000
       VCID: 70B820EF2AA51907828-8024
       Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0105
       Revision: FB900055    Serial number: 5500F09B2102AF
       Coding: 00C303
       VCID: 0058702F1A050987728-8054
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
       Serial number: 1909E75E301109
    6 Faults Found:
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:06:45
                        Bin. Bits:    10000
                        Voltage: 11.90 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 25.40 s
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:11:44
                        Bin. Bits:    10000
                        Voltage: 11.90 V
                        Count: 10
                        Bin. Bits:    10011
                        Time: 25.40 s
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:11:44
                        Bin. Bits:    10000
                        Voltage: 11.90 V
                        Count: 10
                        Bin. Bits:    10011
                        Time: 25.40 s
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 92
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:51:00
                        Reset counter: 95
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 09:51:00
                        Bin. Bits:    00000
                        Voltage: 12.20 V
                        Count: 17
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:57:50
                        Bin. Bits:    10000
                        Voltage: 7.10 V
                        Count: 10
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 02029164747464545425363E
       VCID: 3332EFE31B33621FBFA-8066
       Part No SW: 8K0 907 440 B    HW: 8K0 907 440
       Component: STS           H04 0020
       Revision: S0H04000    Serial number: 00000000023827
       Coding: 01010101000000000000000102
       VCID: 2D06F99BFD1734EFE9E-8078
                        Reset counter: 89
                        Mileage: 94290 km
                        Date: 2014.11.30
                        Time: 03:14:38
                        Reset counter: 89
                        Mileage: 94521 km
                        Date: 2014.12.02
                        Time: 13:19:01
                        Reset counter: 89
                        Mileage: 94521 km
                        Date: 2014.12.02
                        Time: 13:19:01
       Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0030
       Revision: 00H01000    Serial number: 6PZ 009 014-82
       Coding: 0001101
       VCID: 3C20C4DF3A6DAD676E0-8068
       Subsystem 1 - Part No: 8K0 907 568 H
       Component: J0770_SWA_Slave_H01 0030
       Subsystem 2 - Serial number: 6PZ 009 014-92
       Subsystem 3 - Serial number: 5F05.12.0900H010003C320723˙
       Subsystem 4 - Serial number: 320723˙
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009739531
       Coding: 011C02205021410001
       VCID: 45D6A13B45A7ECAF01E-8010
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.08
                        Time: 12:57:45
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 02:25:41
       Revision: 00002001    Serial number: 0124501262
       Coding: 011B062200390C800030013280000000
       Shop #: WSC 06342 000 00000
    6 Faults Found:
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:14:59
    03549 - Terminal 15 Locking Active
                        Reset counter: 91
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:14:59
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 04:11:42
    00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                        Fault Status: 00101011
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 08:56:50
                        Reset counter: 89
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:56:38
                        Reset counter: 94
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:57:54
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34882000677701
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009749420
       VCID: 44D0BC3F4E9DD5A7160-8010
                        Fault Frequency: 7
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.07
                        Time: 12:21:59
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.08
                        Time: 12:58:39
       Revision: 00000003    Serial number: 00000000514534
       VCID: 3430ECFF1E3D6527A60-8060
                        Reset counter: 49
                        Mileage: 101224 km
                        Date: 2009.06.27
                        Time: 01:57:53
                        Voltage: 7.20 V
                        Count: 44
                        Hex Value: 0x0163
                        Hex Value: 0x0088
                        Hex Value: 0x1010
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 77AA1BF343CB4E3F432-8022
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
                        Fault Status: 11101010
                        Reset counter: 48
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:01:11
       Part No SW: 4F0 035 061 K    HW: 4F0 035 061
       Component: Radio U DAB   H45 0074
       Revision: AB001007    Serial number: 343KY097541912
       Coding: 010103010000000001
       VCID: 24101CBFAEDDF5A7360-8070
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.07
                        Time: 12:21:30
                        Voltage: 8.60 V
                        Fault Frequency: 7
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.06
                        Time: 10:27:54
                        Voltage: 8.90 V
    02984 - Connection between Impedance Converter 2 and Window Antenna
                        Fault Frequency: 218
                        Reset counter: 96
                        Mileage: 96648 km
                        Date: 2017.03.10
                        Time: 15:52:29
                        Voltage: 11.90 V
                        Reset counter: 89
    03455 - Function Restriction due to Faults in Other Modules
                        Reset counter: 88
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:00:46
                        Bin. Bits: 00000000 00000001
       Part No SW: 8T2 035 666 M    HW: 8T2 035 666 E
       Component: H-BN-EU       H45 0187
       Revision: --------    Serial number: 475L8097529493
       Coding: 01010100020689ED31000B1E000000030001
       Subsystem 1 - Part No: 8R0 060 884 DF
       Component: EUR 2016  2204
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356L0091148982
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000424604
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
                        Reset counter: 89
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:26:14
                        Voltage: 6.10 V
                        Reset counter: 88
                        Mileage: 101224 km
                        Date: 2009.06.26
                        Time: 00:00:44
                        Bin. Bits: 00100000 00000000
                        Bin. Bits: 00000000 00000000
    03367 - Supply Voltage for Display Module
                        Reset counter: 88
                        Mileage: 101225 km
                        Date: 2017.11.17
                        Time: 10:25:45
                        Voltage: 7.00 V
    03606 - Antenna for Telphone Base-Plate
                        Reset counter: 86
                        Mileage: 101101 km
                        Date: 2017.10.28
                        Time: 19:58:17
                        Voltage: 15.10 V
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102467790
       Coding: 010C02204021210001
       VCID: 42DCBA275489DB9724C-8016
                        Reset counter: 89
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102467752
                        Reset counter: 89
    End----(Elapsed Time: 01:59, VBatt start/end: 12.3V/11.9V. VIgn 11.9V)-----
    A full scan is always welcome!
    Is it safe to assume that the "Crash Data Stored" code won't clear? Depending on the severity of the crash, many newer airbag modules do allow that code to be cleared.
    VCDS can code a new airbag module, but I would suppose that in this car, a new module will throw a Component Protection fault, and that's something that will have to be dealt with at the dealer (or an independent workshop with access to Audi's servers).
    Mar 2018
    thanks mate will give it a whirl , ile replace belts first and side bag and try, i was just assuming it would have crash data stored , there is no actual fault code now for crash data come back once av cleard it
