Results 1 to 9 of 9
Thread: Lost ABS coding PASSAT (3c)
    Mar 2018
    lost ABS coding while testing park brake issue.
    I have pr codes
    Wednesday,28,March,2018,14:51:19:51327
    VCDS Version: 18.2.0.3 (x64)
    VIN: WVWPU73C57E009839   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
              65 6D 72
    VIN: WVWPU73C57E009839   Mileage: 199370km-123882miles
    36-Seat Mem. Drvr -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 997 033 N    HW: Hardware No
       Component: P3.6-FSI-LEV2   G00 2371
       Revision: --H11---    Serial number: VWZCZ000000000
       Coding: 0000075
       Shop #: WSC 05311 000 00000
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 004 -
                        Mileage: 199377 km
                        Date: 2018.03.26
                        Time: 04:06:41
                        RPM: 1126 /min
                        Load: 62.7 %
                        Temperature: 61.0C
                        Temperature: 39.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 10.287 V
                   P1653 - 001 -
                        Fault Status: 01100001
                        Mileage: 199377 km
                        Date: 2018.03.26
                        Time: 04:06:43
                        RPM: 1290 /min
                        Load: 46.6 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Voltage: 11.811 V
    Readiness: 0110 0101
       Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
       Component: AQ 250 6F           1271
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 02607 444 58981
                        Reset counter: 39
                        Mileage: 45057 km
                        Date: 2008.04.29
                        Time: 09:16:12
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
       Component: ESP 440 C2     H015 0004
       Revision:  H015       Serial number: 0100007377
       Coding: 0000000
    6 Faults Found:
                        Reset counter: 154
                        Time: 04:03:49
                        Reset counter: 154
                        Time: 04:03:49
    01542 - Yaw Rate Sensor (G202)
                        Reset counter: 154
                        Time: 04:03:49
                        Reset counter: 154
                        Time: 04:03:49
                        Reset counter: 154
                        Time: 04:03:49
    00810 - Sensor 1/2 for Brake Pressure
                        Fault Frequency: 9
                        Reset counter: 154
                        Mileage: 199377 km
                        Date: 2018.03.26
                        Time: 04:03:49
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       Revision: 00H46000    Serial number: 00000005594134
       Coding: F58C8F0340041A00470A00000F00000000285D435C0000
       Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer VW461 001   0101
       Coding: 00063445
       Shop #: WSC 05311
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 05311
    01064 - Terminal 58d; Interior Dimming
                        Reset counter: 192
                        Time: 06:03:00
    02092 - Enabling Heated Seat
                        Reset counter: 155
                        Time: 14:19:00
    01335 - Drivers Seat/Mirror Position Control Module (J543)
                        Reset counter: 155
                        Time: 13:06:00
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 194
                        Mileage: 199377 km
                        Date: 2018.03.16
                        Time: 09:05:00
                        Voltage: 9.80 V
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7F3017670
                        Reset counter: 194
                        Mileage: 199377 km
                        Date: 2018.03.26
                        Time: 00:36:08
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0P AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3P7FFCEI
       Coding: 0012368
       Subsystem 1 - Part No: 000 000 000 00
       Component: BF-Gewichtsens. 000 0000
       Subsystem 2 - Serial number: 00000000000000
       Subsystem 3 - Serial number: 0001.01.000000000000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME0D186852E†63
       Subsystem 5 - Serial number: 86852E†6342MSME1047326B6†63
       Subsystem 6 - Serial number: 7326B6†6351HTS6TLLMEIJ2Q†63
       Subsystem 7 - Serial number: MEIJ2Q†6361HTS6OLL6EP732†63
       Subsystem 8 - Serial number: 6EP732†63727TS63IKI9KU2-†63
       Subsystem 9 - Serial number: I9KU2-†63827TS61IKAOK52H
       Subsystem 10 - Serial number: AOK52H
    6 Faults Found:
    02511 - Control Module for Seat Occupied Recognition (J706)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
    01217 - Side Airbag Igniter; Driver Side (N199)
    00591 - Seat Belt Switch; Driver (E24)
    00592 - Seat Belt Switch; Passenger (E25)
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Revision: 00005000    Serial number: 3C9953507P
       Coding: 0002212
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Revision: V0033000    Serial number: 00000000000000
       Coding: 0007205
                        Reset counter: 194
                        Time: 14:19:19
                        Reset counter: 154
                        Time: 13:06:58
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Coding: 3FFD0F0CD32002
                        Reset counter: 154
                        Time: 13:06:58
                        Reset counter: 194
                        Time: 14:19:19
       Component: Kompass         001 0002
       Component:    IMMO         041 0364
       Shop #: WSC 02607 444 14564
       Component:    ELV          028 0380
    Address 36: Seat Mem. Drvr
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Component: Tuer-SG         024 2801
       Component: EPS_ZFLS Kl.5   D04 1607
       Component:    KSG PQ46 RDK 041 0213
       Coding: 13900E88D1032E521804141FF00A8F0E081800
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Coding: 0010000
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                        Fault Status: 11111100
                        Reset counter: 154
                        Mileage: 199376 km
                        Date: 2018.03.26
                        Time: 00:35:03
                        Voltage: 12.53 V
                        Count: 86
                        Fault Status: 11101101
                        Reset counter: 155
                        Mileage: 199376 km
                        Date: 2018.03.26
                        Time: 19:45:06
                        Voltage: 11.70 V
                        Count: 220
                        Reset counter: 155
                        Mileage: 199376 km
                        Date: 2018.03.26
                        Time: 04:03:49
                        Voltage: 13.35 V
                        Count: 236
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                012 - Electrical Fault in Circuit - MIL ON
                        Reset counter: 154
                        Mileage: 199376 km
                        Date: 2018.03.26
                        Time: 00:35:12
                        Voltage: 12.73 V
                        Count: 87
    02431 - Right Parking Brake Motor (V283) Resistance to Movement
                003 - Mechanical Failure - MIL ON
                        Fault Status: 11110011
                        Reset counter: 154
                        Mileage: 199376 km
                        Date: 2018.03.26
                        Time: 00:35:12
                        Voltage: 13.15 V
                        Count: 89
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio PM6       016 0017
       Revision: 00016000    Serial number: VWZ5Z7F2069037
       Coding: 0040400
       Shop #: WSC 05311 000 08193
       Part No: 3C9 959 703 A
       Component: Tuer-SG         021 2507
       Coding: 0000144
       Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
       Component:    RDK              0391
       Revision: 00041000    Serial number: VWZCZ000000000
       Coding: 0100101
    00667 - Ambient Temperature Signal
                        Fault Status: 00111000
                        Reset counter: 194
                        Mileage: 199377 km
                        Date: 2018.03.26
                        Time: 00:09:58
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
       Component: J605  HECKDECKEL    0405
       Revision: 00H20001
       Shop #: WSC 23250 384 715754
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0405
       Subsystem 2 - Serial number: 0600H20001000A0006
       Part No: 3C9 959 704 A
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:20)--------------------------
    Controller Software Versions:
    ECU 1 = Engine 2371
    ECU 2 = Auto Trans 1271
    ECU 3 = ABS Brakes 0004
    ECU 4 = Auto HVAC 0404
    ECU 5 = Cent. Elect. 1501
    Sub ECU 5 > 1 = Cent. Elect. 0101
    Sub ECU 5 > 2 = Cent. Elect. 1110
    ECU 6 = Digital Radio 0060
    ECU 7 = Airbags 2521
    Sub ECU 7 > 1 = Airbags 0000
    ECU 8 = Steering wheel 0015
    Sub ECU 8 > 1 = Steering wheel 2001
    ECU 9 = Instruments Labels:
    ECU 10 = CAN Gateway 0040
    ECU 11 = Position Sensing 00
    ECU 12 = Immobilizer 0364
    Sub ECU 12 > 1 = Immobilizer 8038
    ECU 13 =
    ECU 14 = Door Elect, Driver
    ECU 15 = Steering Assist 160
    ECU 16 = Central Conv. 0213
    ECU 17 = Door Elect, Pass. 2
    ECU 18 = Parking Brake 0001
    ECU 19 = Radio 0017
    ECU 20 = Door, Rear Left 250
    ECU 21 = Tire Pressure 0391
    ECU 22 = Trunk Elect. 0405
    Sub ECU 22 > 1 = Trunk Elect. 040
    ECU 23 = Door, Rear Right 25
    Hello and welcome OP to the VCDS forum.
    JPPSG
    Try this : Coding: 0046544
    Should be: 0046541
    Then see Wiki.
    Mar 2018
    Thanks I will give that a try, tomorrow
    Is anyone else wondering why the OP might have edited his scan in the manner that he did?
    I guess he inserted it to, and then copied it from VCDSToolbox.
    I thought it must be a fetish for controller firmware versions ? ........
  9. #8
    Does that strip out one line from the data for each control module?
  10. #9
    Yes, and from sub modules.
    It is a test I tried out.
    ECU 1 = Engine 0001
    ECU 2 = Auto Trans 2817
    ECU 3 = ABS Brakes 0521
    ECU 4 = Acc/Start Auth. 0551
    Sub ECU 4 > 1 = Acc/Start Auth. 0046
    ECU 5 = Auto HVAC 1406
    ECU 6 = Cent. Elect. 0311
    Sub ECU 6 > 1 = Cent. Elect. 0021
    Sub ECU 6 > 2 = Cent. Elect. 0020
    Sub ECU 6 > 3 = Cent. Elect. 0040
    Sub ECU 6 > 4 = Cent. Elect. 0030
    ECU 7 = Park/Steer Assist 0030
    ECU 8 = Auto Dist. Reg 0400
    ECU 9 = Airbags 0043
    Sub ECU 9 > 1 = Airbags 0005
    ECU 10 = Steering wheel 0005
    Sub ECU 10 > 1 = Steering wheel 0028
    ECU 11 = Instruments 0515
    ECU 12 = CAN Gateway 6042
    Sub ECU 12 > 1 = CAN Gateway 0190
    ECU 13 = Seat Mem. Drvr 0156
    ECU 14 = Lane Change 0021
    Sub ECU 14 > 1 = Lane Change 0021
    ECU 15 = Door Elect, Driver 0306
    ECU 16 = Central Conv. 0551
    Sub ECU 16 > 1 = Central Conv. 0059
    Sub ECU 16 > 2 = Central Conv. 1501
    Sub ECU 16 > 3 = Central Conv. 0008
    Sub ECU 16 > 4 = Central Conv. 0008
    Sub ECU 16 > 5 = Central Conv. 0813
    ECU 17 = Sound System 0090
    ECU 18 = Door Elect, Pass. 0306
    ECU 19 = Parking Brake 1201
    ECU 20 = Headlight Range 0091
    Sub ECU 20 > 1 = Headlight Range 0005
    Sub ECU 20 > 2 = Headlight Range 0005
    ECU 21 = Radio 0133
    ECU 22 = Information Electr. 0881
    Sub ECU 22 > 1 = Information Electr. 1102
    Sub ECU 22 > 2 = Information Electr. 0046
    Sub ECU 22 > 3 = Information Electr. 0046
    Sub ECU 22 > 4 = Information Electr. 5950
    ECU 23 = Door, Rear Left 0306
    ECU 24 = Tire Pressure 0002
    ECU 25 = Trailer 0137
    ECU 26 = Back-up Cam. 0115
    ECU 27 = Trunk Elect. 0043
    ECU 28 = Door, Rear Right 0306
    ECU 29 = On Board Cam. 0035
    Sub ECU 29 > 1 = On Board Cam. 0001
    ECU 30 = Adaptive Cruise 2 0400
    ECU 31 = Image Processing 0035
