Results 1 to 10 of 17
Thread: 2012 A4 - Intermittent non start
    Nov 2016
    Someone else posted previously having what appears to be identical issues. Car will not start, various faults come up on the dash, headlight range defective, parking brake fault, stability fault etc. Its not all the time though. Previous posted said that a new engine ecu was required. Given VCDS's changes since then the autoscan looks similar but not identical, but whats peoples opinion? For the price of a second hand ecu and getting it cloned i think its worth a shot
    Wednesday,28,March,2018,16:17:08:34436
    VCDS Version: 18.2.0.3 (x64)
    VIN: WAUZZZ4G1CN137347   License Plate: EL60MED
    Mileage: 249907km-155285mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56
              5F 62 72
    VIN: WAUZZZ4G1CN137347   Mileage: 249907km-155285miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H24 9977
       Revision: 45H24---
       Coding: 12034012242401080000
       Shop #: WSC 78387 152 452326
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003011
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 75E65F71D447B2EC3B-8020
              U1113 00 [032] - -
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 21:03:17
                        Engine speed: 890.00 /min
                        Normed load value: 21.2 %
                        Coolant temperature: 59 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 11.940 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 45
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
              U1113 00 [032] - -
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 21:03:17
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000105
       Coding: 000001
       Shop #: WSC 06795 666 30556
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: 3C708A55B7ED23A404-8068
    10077 - Valve for Transmission Fluid Cooler
              P2753 00 [046] - Open Circuit
                        Mileage: 249765 km
                        Date: 2018.03.25
                        Time: 11:48:19
                        Engine speed: 100.00 /min
                        Transmission input speed: 1 /min
                        Transmission output speed: 1 /min
                        Engine torque: -28 Nm
                        Transmission fluid temperature: 68 °C
                        Accelerator position: 0.0 %
                        Clutch status: 1
                        Occurrence_counter_over_length_of_life: 254
    2264 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [044] - -
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 47 °C
                        Clutch status: 1
                        Occurrence_counter_over_length_of_life: 7
    7066 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [044] - -
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Engine torque: 0 Nm
                        Clutch status: 1
                        Occurrence_counter_over_length_of_life: 6
       Coding: 06A187016085E180DB00
       VCID: 3664987D89C1F9F4F2-8062
    8 Faults Found:
    0004 - Brake Switch (F)
              P0571 00 [008] - Implausible Signal
                        Reset counter: 45
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: F6
                        Uz: 9E
    0069 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E3
                        Uz: 9E
    0071 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F0
                        Uz: 9E
    0073 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F5
                        Uz: 9E
    0075 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F8
                        Uz: 9E
    0077 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:50
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: FD
                        Uz: 9F
    0091 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 0C
                        Uz: 9E
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:49
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 04
                        Uz: 9E
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Coding: 01B93006000000000000
       VCID: 76E4587DC141B9F432-8022
       Serial number: 2312000010543011
                        Fault Status: 00101101
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H12 0064
       Serial number: 20021200040518
       Coding: 34220078A0
       VCID: 275A45395E6B907C79-8072
    0278 - Coolant Shut-Off Valve
              B10C8 13 [009] - Open Circuit
                        Fault Frequency: 12
                        Reset counter: 7
                        Mileage: 249765 km
                        Date: 2018.03.25
                        Time: 11:48:04
                        Voltage terminal 30: 12.04 V
                        Outside air temperature: 14.5 °C
                        Interior temperature: 19.85 °C
    0331 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:51
                        Voltage terminal 30: 12.30 V
                        Outside air temperature: 9.5 °C
       Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0111
       Revision: 20012002    Serial number: 00000001410124
       Coding: 2600201040349FE00181008300001D0C0F9DC70827090101000008602100
       VCID: 75E65F71DC47B2EC3B-8020
       Component: WWS57X 120116  H35 0080
       Serial number:         120130132055
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 12008216
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 17 02 2012  00001329
       Serial number: 0D3844E5000000000001
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:00
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901204500467
       Coding: 080308
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3D768751ACF72AAC33-8068
    12648448 - Databus
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:50
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Revision: --------    Serial number: 003JG0074L9-
       Coding: 30323436313230303235554A305234473053
       Serial number: 3575HRB405L12NLA7GMZ
       Serial number: 3585HRB406712NLC9PJX
       Serial number: 3515JRB40530O32K99DY
       Serial number: 3525JRB40184UH6IK0V$
       Serial number: 3554VRB404V14KDMIOGS
       Serial number: 3564VRB405D14KDMAHK1
       Revision: 00000000    Serial number: 20120221000529
       Coding: 000035
       VCID: 3068AE6563A5D7C4A8-8064
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
       Component: TDieGb        H79 0416
       Revision: 28460177    Serial number: 658270112596033
       Coding: 33AF10000B012600010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K.rod
    16776971 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:50
       Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000408726
       Coding: 00CD074400
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3460A2759FBDEBE4CC-8060
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790965767
       Voltage stabilizer:
       Serial number: 12042001025011200181
    4224 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:22
                        Voltage terminal 30: 12.1 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 16 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0064
       Serial number: 21021200040539
       Coding: 02
       VCID: 2F6AAD19769BC83CB1-807A
    0132 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:51
                        Voltage terminal 30: 12.33 V
                        Engine speed: 0 /min
                        Vehicle speed: 0.00 km/h
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0009
       Revision: --------    Serial number: EJ1BPA3201HT7A0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 6BD279098203741CDD-803E
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204001620002080002
       VCID: 428CF4ADDD0955544E-8016
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:47
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0007363549
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326CA46D65A9E5D4DE-8066
    3158274 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 27
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:50
                        valid
       Revision: 00002001    Serial number: 0170309120
       Coding: 013B062220B9040083200904000104000000000000000000000000000000
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 5
                        Mileage: 249794 km
                        Date: 2018.03.25
                        Time: 12:38:06
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 5
                        Mileage: 249794 km
                        Date: 2018.03.25
                        Time: 12:40:32
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 418EFBA1D80F4E4C57-8014
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:47
       Revision: --------    Serial number: 00000000254092
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A5CBC0D4D79AD1466-807E
    333568 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Voltage terminal 30: 12.2 V
                        Internal Fault ID: 49
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
    334080 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Internal Fault ID: 51
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331264 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Internal Fault ID: 99
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331520 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Internal Fault ID: 100
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331776 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:48
                        Internal Fault ID: 101
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Serial number: 120220-0004-119
       Coding: 112296101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C50BA15478DB32494-8078
    0095 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:50
    336388 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 48
                        Mileage: 249806 km
                        Date: 2018.03.25
                        Time: 20:57:50
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230BO0C7542029
       Coding: 010003020100000001
       VCID: 2342512922537C5C25-8076
    03278 - Functionality Limited due to Missing Messages
                000 -  -  - Intermittent
                        Reset counter: 48
                        Mileage: 249875 km
                        Date: 2018.03.27
                        Time: 15:40:15
                        Bin. Bits: 00000000 00001000
       Part No SW: 4G0 035 670 G    HW: 4G0 035 670 A
       Component: H-BNT-EU      H48 0484
       Revision: --------    Serial number: 428B-0C7541583
       Coding: 050101010003A1ED05008B3E00000003000001000000000000
       VCID: 275A4539566B907C79-8072
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Serial number: AUZ8ZDB9400R48M
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Serial number: 90349LB9000B7
       Component: CD-Database  3638
                        Reset counter: 48
                        Mileage: 249875 km
                        Date: 2018.03.27
                        Time: 15:40:20
                        Bin. Bits: 00010000 00000000
                        Bin. Bits: 00000000 00010000
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 4480F2B5C71D5B647C-8010
       Component: TSG HR        H04 0212
    End-------------------------(Elapsed Time: 04:40)--------------------------
    Looking at that scan, if I were a betting man, I'd put my money on some kind of power problem.
  3. Likes Jack@European_Parts, rhinopower liked this post
  5. Likes rhinopower liked this post
  6. #4
    6 year old car, still on the original battery? We've had some cold (for the UK) weather recently - 2 x "Beast from the East".
  7. Likes rhinopower liked this post
  8. #5
    Nov 2016
    Jack, your first thought was the same as mine, however, £180 later for a brand new exide agm battery, the problem persists
    This is the other thread that got me thinking the issue was the same
    http://forums.ross-tech.com/showthre...t-Not-Starting
  9. #6
    Nov 2016
    that was my exact train of thought, and exactly the case with my dad's TT, new battery sorted that out fine
  10. #7
    Did you do the things referenced in the other thread?
  11. #8
    Nov 2016
    Its not my car so not had chance to do any further investigation yet, but the guy wants it rolled back to pre ea189 fix anyway, which can be done at the same time as trying a different ecu. The fault codes listed from the auto scan that are also on the ross tech wiki all point at faulty ecu
  12. #9
    But what about the NOx & wildlife?
  13. #10
    Nov 2016
    You not agree with the roll back? Not sure if you are being serious or having a joke?
