had a little problem with this polo missfireing on cylinder , had a working coil from another car and still no cure.. any advice anyone can off from my scan i see some ecu faults on my scan ? still getting used to vcds so thanks for any advice...
Friday,23,March,2018,09:08:41:24744
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZ9NZ6Y095925 License Plate:
Mileage: 176910km-109926mi Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y095925 Mileage: 176910km-109926miles
Part No: 03D 906 033 F
Component: 1,2l/2V SIMOS3 00HS2509
Coding: 00031
Shop #: WSC 00788
VCID: 221C1AA7BDD9FB9744C-5184
WVWZZZ9NZ6Y095925 VWZ7Z0E1659701
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.clb
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Shop #: WSC 00788 785 00200
VCID: 015E752B1D1F008F7D6-50D0
Fault Status: 00101101
Fault Frequency: 31
Reset counter: 22
Mileage: 176916 km
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Reset counter: 21
Mileage: 176917 km
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00AF BN-SG. 1S34
Coding: 25918
Shop #: WSC 00788
VCID: 3C20C4DF3F7DAD676E0-50D0
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 601 F
Component: 05 AIRBAG VW5 0010
Coding: 12341
Shop #: WSC 00788
VCID: 3634D6F701517737984-50D0
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 903 E
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01431
VCID: 3332EFE31223621FBFA-50D0
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: 70B820EF23B51907828-50D0
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10140
Shop #: WSC 00788
VCID: 6FBA23933E8B06FF9B2-50D0
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 6Q0 959 433 G
Component: 41 Komfortgerát 0002
Coding: 00017
Shop #: WSC 00788
VCID: 3FDAB3D32E6BB67F4B2-4B3C
Address 56: Radio Labels: None
Part No HW: 6Q0 035 152 A
Revision: 00005000 Serial number: VWZ1Z5F8990053
VCID: 55F6717BBD175C2F71E-50D0
End----(Elapsed Time: 03:07, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
