2014 AUDI A6 AVANT 2.0 TDI Ultra - DPF Issue plus others :(
PuddyTat
C?ID=320492
So, I'm new to this whole VAG thing so have invested in the Hex-Net as an enthusiastic amature. While I have worked on vehicles for years, I've virtually no experience with the modern electronic systems.
I've had a DPF issue and hoped this would help work out what is going on. Unfortunately, it seems there are a couple of faults :(
My main issue is DPF Bank 1. My local garage is not AUDI but tried 4 forced regens. This dropped everything to fine limits for 5 days before the engine management light was back on. They are stumped and hadn't seen a dual sensor DPF before so aren't sure how to progress or what the fault really is (replace the DPF?).
Then comes the Instrument Cluster. Seems it has no basic coding?
Next is the AC. This was fine until a week ago and now won't operate. Is this needing the system refilled or a new sensor and if a sensor, where is it hidden?
Last is the fuel cap and flap. Seems there's a short to ground and I should check the wiring. Any assistance on the location of the wiring would be appreciated.
Thank you all in advance your your help!
hassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 6D 72
          AC
VIN: WAUZZZ4G4EN187470   Mileage: 177944km-110569miles
AC-Reductant Control -- Status: OK 000
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FE    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8243
   Revision: 85H23---
   Coding: 12194012242401080000
   Shop #: WSC 24297 000 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
   ROD: EV_ECM20TDI01104L906021FE_002.rod
   VCID: 6D9221EEBCE5832CC3-8038
19226 - Particulate Trap Bank 1
          P2002 00 [101] - Efficiency Below Threshold
                    Mileage: 177746 km
                    Date: 2018.03.13
                    Time: 08:53:49
                    Engine speed: 1670.00 /min
                    Normed load value: 63.9 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 14.400 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.015
                    Differential pressure ratio: low-pressure EGR: 24.5 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 30.4 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 29.1 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 64.10 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 40.28 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 31.0 hPa
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 11071400110129
   Coding: 3422090821
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 5F8E4B264649E1BC41-800A
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [009] - Signal Amplitude Too Low
                    Reset counter: 216
                    Mileage: 177738 km
                    Date: 2018.03.13
                    Time: 08:26:17
                    Compressor current: actual value: 0 mA
                    Outside air temperature: 6.0 °C
                    Temperature after evaporator: 4.64 °C
                    Engine speed: 981 /min
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658160714592048
   Coding: 33A4120003412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3FCEABA6A609C1BC21-806A
1048578 - No Basic Setting
          B2010 00 [009] -  -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 208
                    Mileage: 177719 km
                    Date: 2018.03.12
                    Time: 09:24:49
   Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0551
   Revision: 00002001    Serial number: 0340547598
   Coding: 013B0622A0B930408320090400010F470000000000000000000000000000
   VCID: 74A4348AD7CF52E40C-8020
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 208
                    Mileage: 177719 km
                    Date: 2018.03.12
                    Time: 09:59:06
02615 - Fuel Tank Cap; Lock
                    Reset counter: 208
                    Mileage: 177719 km
                    Date: 2018.03.12
                    Time: 09:59:22
At 110,000 miles, it might indeed be time for a new DPF, or at least a good cleaning.
Instrument cluster fault: Someone buggered up the values in the Service Reminder channels.
Tank flap lock: Might be just an open circuit.
PuddyTat
C?ID=320492
Thanks for the reply.
Is there a good way to clean out the DPF? Did see a post referring to using cleaning products somewhere...
As for the instruments, I take it it's back to AUDI to resolve?
Thanks in advance,
P.
Keithuk
Stoke on Trent, England
C?ID=122432
Have you checked the Oil Ash Volume, Carbon Mass (spec.), Carbon Mass (meas.)? DPF readings and health of DPF
In the UK there are companies that clean DPF's I don't know if they have them in USA.
