Results 1 to 4 of 4
Thread: 2014 AUDI A6 AVANT 2.0 TDI Ultra - DPF Issue plus others :(
    Mar 2018
    So, I'm new to this whole VAG thing so have invested in the Hex-Net as an enthusiastic amature. While I have worked on vehicles for years, I've virtually no experience with the modern electronic systems.
    I've had a DPF issue and hoped this would help work out what is going on. Unfortunately, it seems there are a couple of faults
    My main issue is DPF Bank 1. My local garage is not AUDI but tried 4 forced regens. This dropped everything to fine limits for 5 days before the engine management light was back on. They are stumped and hadn't seen a dual sensor DPF before so aren't sure how to progress or what the fault really is (replace the DPF?).
    Then comes the Instrument Cluster. Seems it has no basic coding?
    Next is the AC. This was fine until a week ago and now won't operate. Is this needing the system refilled or a new sensor and if a sensor, where is it hidden?
    Last is the fuel cap and flap. Seems there's a short to ground and I should check the wiring. Any assistance on the location of the wiring would be appreciated.
    Thank you all in advance your your help!
    hassis Type: 4G-AU57 (4G5)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 6D 72
              AC
    VIN: WAUZZZ4G4EN187470   Mileage: 177944km-110569miles
    AC-Reductant Control -- Status: OK 000
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FE    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 8243
       Revision: 85H23---
       Coding: 12194012242401080000
       Shop #: WSC 24297 000 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
       ROD: EV_ECM20TDI01104L906021FE_002.rod
       VCID: 6D9221EEBCE5832CC3-8038
    19226 - Particulate Trap Bank 1
              P2002 00 [101] - Efficiency Below Threshold
                        Mileage: 177746 km
                        Date: 2018.03.13
                        Time: 08:53:49
                        Engine speed: 1670.00 /min
                        Normed load value: 63.9 %
                        Vehicle speed: 61 km/h
                        Coolant temperature: 82 °C
                        Intake air temperature: 70 °C
                        Voltage terminal 30: 14.400 V
                        Exhaust mass flow of low-pressure EGR: calculated: 3.015
                        Differential pressure ratio: low-pressure EGR: 24.5 kg/h
                        Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 30.4 hPa
                        Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 29.1 hPa
                        Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 64.10 %
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 40.28 %
                        Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 31.0 hPa
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
       Component: KLIMA 2 ZONEN H14 0096
       Serial number: 11071400110129
       Coding: 3422090821
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 5F8E4B264649E1BC41-800A
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 216
                        Mileage: 177738 km
                        Date: 2018.03.13
                        Time: 08:26:17
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 6.0 °C
                        Temperature after evaporator: 4.64 °C
                        Engine speed: 981 /min
       Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
       Component: MDieGb        H43 0411
       Revision: 27450259    Serial number: 658160714592048
       Coding: 33A4120003412600010000
       ASAM Dataset: EV_RBC7KMID 004048
       ROD: EV_RBC7KMID.rod
       VCID: 3FCEABA6A609C1BC21-806A
    1048578 - No Basic Setting
              B2010 00 [009] -  -
              [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                        Reset counter: 208
                        Mileage: 177719 km
                        Date: 2018.03.12
                        Time: 09:24:49
       Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
       Component: BCM2 2.0      H36 0551
       Revision: 00002001    Serial number: 0340547598
       Coding: 013B0622A0B930408320090400010F470000000000000000000000000000
       VCID: 74A4348AD7CF52E40C-8020
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 208
                        Mileage: 177719 km
                        Date: 2018.03.12
                        Time: 09:59:06
    02615 - Fuel Tank Cap; Lock
                        Reset counter: 208
                        Mileage: 177719 km
                        Date: 2018.03.12
                        Time: 09:59:22
    At 110,000 miles, it might indeed be time for a new DPF, or at least a good cleaning.
    Instrument cluster fault: Someone buggered up the values in the Service Reminder channels.
    Tank flap lock: Might be just an open circuit.
    Mar 2018
    Thanks for the reply.
    Is there a good way to clean out the DPF? Did see a post referring to using cleaning products somewhere...
    As for the instruments, I take it it's back to AUDI to resolve?
    Thanks in advance,
    P.
    Stoke on Trent, England
    Have you checked the Oil Ash Volume, Carbon Mass (spec.), Carbon Mass (meas.)? DPF readings and health of DPF
    In the UK there are companies that clean DPF's I don't know if they have them in USA.
    New User Keith
