Results 1 to 6 of 6
Thread: 2009 Audi A4 2.0; engine running rough and nosie.
    Jul 2016
    Customer complained about check engine light on.
    Friday,16,March,2018,13:32:53:38819
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    Dealer/Shop Name: Automotive Traveling Tech
    VIN: WAUGF78K09A204376   License Plate:
    Chassis Type: 8K (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
              65 72 77
    VIN: WAUGF78K09A204376   Mileage: 71330km-44322miles
    Address 01: Engine (MA---CAEB)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 N    HW: 8K2 907 115 D
       Revision: E1H14---
       Coding: 010C010A190F0160
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_ECM20TFS8K2907115N A01003
       ROD: EV_ECM20TFS8K2907115M.rod
       VCID: 3A7B6C70BDC83AEE70-806E
    11 Faults Found:
    5593 - Torque Management Request Input Signal A
              P2545 00 [032] - Implausible
                        Mileage: 71126 km
                        Date: 2018.03.10
                        Time: 17:23:39
    7207 - Cam Adjustment Actuator A; Cylinder 1
              P11A1 00 [096] - Elec. Malf. or Open Circuit
    7210 - Cam Adjustment Actuator B; Cylinder 1
              P11A3 00 [096] - Elec. Malf. or Open Circuit
    7219 - Cam Adjustment Actuator A; Cylinder 3
              P11A9 00 [096] - Elec. Malf. or Open Circuit
    7222 - Cam Adjustment Actuator B; Cylinder 3
              P11AB 00 [096] - Elec. Malf. or Open Circuit
    7225 - Cam Adjustment Actuator A; Cylinder 4
              P11AD 00 [096] - Elec. Malf. or Open Circuit
    7228 - Cam Adjustment Actuator B; Cylinder 4
              P11AF 00 [096] - Elec. Malf. or Open Circuit
    7213 - Cam Adjustment Actuator A; Cylinder 2
              P11A5 00 [096] - Elec. Malf. or Open Circuit
    7216 - Cam Adjustment Actuator B; Cylinder 2
              P11A7 00 [096] - Elec. Malf. or Open Circuit
    4063 - Cylinder 4
              P0304 00 [172] - Misfire Detected
                        Fault Frequency: 6
                        Mileage: 70136 km
                        Date: 2018.02.13
                        Time: 05:48:21
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [044] - -
    Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 3663784089D0DE8E94-8062
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 150500
       VCID: 7DF1A76CE466CDD615-8028
                        Reset counter: 133
                        Mileage: 70728 km
                        Date: 2018.03.06
                        Time: 18:10:57
                        Hex Value: 0x00C0
                        Hex Value: 0x4026
                        Hex Value: 0x122E
                        Hex Value: 0x09A7
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0145
       Coding: 090200
       VCID: 75E1BF4CDC5695965D-8020
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0150
       Revision: C1000000    Serial number: 01050220090406
       Coding: 64002000
       VCID: 72EB8450AD3882AE78-8026
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Revision: 05022001    Serial number: 00000000312866
       Coding: 26001091063CAF010000080300003D0D0F1C460800010161000000
       VCID: 306F4E5863B4F0BECE-8064
       Component: WWS 260109  H06 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0080
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Serial number: 0039KD14T575
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 408F1E98DB14603E3E-8014
       Serial number: 5810000R08000039FF
       Serial number: 6334MSME4453431EB
       Serial number: 6344MSME44544870A
       Serial number: 6352QSME141B15268
       Serial number: 6362QSME3C1C1310B
       Serial number: 63732SME3C160414U
       Serial number: 63832SME44164A1C%
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Component: Lenks.Modul   H15 0013
       Revision: --------    Serial number: 90319IB20004X
       Coding: 000037
       VCID: 3D71676CA4E60DD655-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H18 0224
       Revision: 00000000    Serial number: 9DR27RU19
       Coding: 8B1611000300D705020000
       VCID: 2D51572C74869D56E5-8078
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0095
       Revision: GB300043    Serial number: 4300G0912481A9
       Coding: 000303
       VCID: 4B9539B4EA52B366DB-801E
       Component: J367-BDM  H04 0150
    Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Revision: 00000000
       Coding: 020302
       VCID: 78FFB678CB44E8FE46-802C
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001219805
       Coding: 00581300000000000000
       VCID: 77FDB544C65AE7864F-8022
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008455963
       Coding: 011C03204E00410001
       VCID: 41891B9CD81E693631-8014
                        Fault Status: 01101100
                        Fault Frequency: 19
                        Reset counter: 117
                        Mileage: 70319 km
                        Date: 2018.02.20
                        Time: 05:55:36
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0116832143
       Coding: 0126023A207A441400B002
       Component: GTO BF  H06 0040
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS130  H06 0037
       Subsystem 4 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J394 PS225  H06 0037
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 163
                        Reset counter: 116
                        Mileage: 28113 km
                        Date: 2014.02.24
                        Time: 07:49:29
    02616 - Fuel Tank Cap; Unlock
                        Fault Frequency: 235
                        Reset counter: 117
                        Mileage: 30557 km
                        Date: 2014.04.05
                        Time: 18:00:30
    00218 - Humidity Sensor (G355)
                        Reset counter: 234
                        Mileage: 69185 km
                        Date: 2017.07.13
                        Time: 12:49:35
       Part No SW: 8R0 035 223 E    HW: 8R0 035 223 E
       Component: DSP STD       H11 0430
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2E5350207980E64EDC-807A
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000008420229
       VCID: 408F1E98D314603E3E-8014
       Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
       Component: EPB Audi B8   H06 0070
       Revision: 00000003    Serial number: 00000000302896
       VCID: 326B44506DB8C2AEB8-8066
    03200 - Switch for Electric Parking Brake (E538)
                        Fault Status: 00101100
                        Reset counter: 133
                        Mileage: 70728 km
                        Date: 2018.03.06
                        Time: 18:10:57
                        Voltage: 13.70 V
                        Count: 10
                        Hex Value: 0x02E3
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    02442 - Function Lamp in Control Head
                        Reset counter: 97
                        Mileage: 28531 km
                        Date: 2014.03.10
                        Time: 14:09:01
                        Voltage: 12.30 V
                        Count: 72
                        Hex Value: 0x0160
                        Hex Value: 0x0008
                        Hex Value: 0x0101
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06334 000 00000
       VCID: 77FDB544065AE7864F-8022
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 195 AD    HW: 8T1 035 195 AD
       Component: Symph3 Sirius H01 0301
       Revision: 00000003    Serial number: AUZ5Z4H1070714
       Coding: 040200020102850043D9070800
       VCID: 79F9B37CF04EF1F639-802C
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
                000 -  -
                        Reset counter: 241
                        Mileage: 25834 km
                        Date: 2013.10.30
                        Time: 11:36:33
                000 -  -  - Intermittent
                        Reset counter: 149
                        Mileage: 25834 km
                        Date: 2013.10.30
                        Time: 14:12:06
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000008478132
       Coding: 010C03204000210001
       VCID: 44871288C70C7C1E1A-8010
                        Fault Frequency: 6
                        Reset counter: 157
                        Mileage: 70454 km
                        Date: 2018.02.23
                        Time: 21:23:20
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140790064451
       Coding: 0CD154
    02214 - Tire Pressure Warning
                        Reset counter: 126
                        Mileage: 69418 km
                        Date: 2017.10.02
                        Time: 18:29:19
                        Bin. Bits: 00000000 00100101
                        Voltage: 13.70 V
                        Text:  22,0°C; -0,49bar;3390520831;00h; 21°C
    Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
       Revision:             Serial number: 0000008479641
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005031292
       Coding: 0010370
       VCID: 3B7569747AF203E66B-806E
    End-------------------------(Elapsed Time: 04:22)--------------------------
    I'm having trouble finding any information for the fault codes addressing (cam adjustment actuator). Any help or guidance would be appreciated. Also this is my first post. Any tips are accepted.
    Whohunter
    Verify ECU for FOD.
    Mechanicals must be observed in head area and harness for cam control in addition to solenoids, lubrication issues and possible FOD.
    Jan 2018
    15.7, Really. Tip from me would be an update. Sorry, can't help with faults, Loads better than me for that lot.
    2006 EOS 3.2 V6.
    With an electrical fault for each Cam Adjustment Actuator, look for something they all have in common, either a source of power or a ground connection.
  5. Likes Jack@European_Parts liked this post
    Apr 2017
    OK I had similar issue after doing valve cover gasket because two of my connectors were broke when I took off and I had to replace the little boogers and when I did after completing the valve cover leak that i had I had to mess with these guys a few times till it ran OK. What a pain but the strange thing there was not any issues till I replaced the the cheesy connectors.
    TO add to this I am now having an issue with the same two!! I had an APR tune put in on Friday and great power but had issue with diverter I thought because once I hit over 4k in first gear it would loose power for a second and then take off again and second and third gear were fine. SO I got new diverter and it seemed to straighten out the hesitation but after that short drive it started to idle rough again. Ran scan and got the same two faults cam adjuster A on both cylinders 1 and 4 which were the same ones I had an issue when I replaced the connectors. So I tried to mess with these again and no luck so far to get this to go away. Wondering if I need to change the the actuators out??? Any help?? The car ran flawless before the tune and it has been several months since I did the valve cover and replaced the connectors and they are fine as far as not broke like they do. I probably put close to 5 k on the car since new connectors.
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Component: 2.0l R4/4V TF H12 0001
       Revision: E1H12---
       Shop #: WSC 06449 444 84029
       VCID: 79BA3080F8DE388C5F-802C
              P11A1 00 [109] - Elec. Malf. or Open Circuit
                        Mileage: 229341 km
                        Date: 2008.03.12
                        Time: 03:21:06
                        Engine speed: 1083.50 /min
                        Normed load value: 8.6 %
                        Coolant temperature: 89 °C
                        Intake air temperature: 63 °C
                        Voltage terminal 30: 11.709 V
              P11AD 00 [109] - Elec. Malf. or Open Circuit
                        Mileage: 229341 km
                        Date: 2008.03.12
                        Time: 03:21:06
    10540 - Camshaft Adj. Bank 1 Intake
              P052A 00 [101] - Cold-Start Timing not Reached
                        Mileage: 229446 km
                        Date: 2008.03.12
                        Time: 10:12:20
                        Engine speed: 1120.00 /min
                        Normed load value: 26.7 %
                        Vehicle speed: 2 km/h
                        Coolant temperature: 33 °C
                        Intake air temperature: 20 °C
                        Voltage terminal 30: 12.863 V
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
              P0016 00 [101] - Incorrect Correlation
                        Mileage: 229448 km
                        Date: 2008.03.12
                        Time: 10:16:58
                        Engine speed: 792.00 /min
                        Normed load value: 9.0 %
                        Vehicle speed: 11 km/h
                        Coolant temperature: 77 °C
                        Intake air temperature: 18 °C
                        Voltage terminal 30: 13.994 V
    Double FOD..............and add a TUNA can to mix
