Results 1 to 4 of 4
Thread: Octavia MKiii 2017 tweaks help
    Feb 2018
    Israel
    Hia,
    I recently picked up Octavia RS mk3 , could use some help with some adaptations I haven't figured out how to do -
    VCDS ver 18.2.0 using Hex-V2 cable
    Recent scan (before updating VCDS):
    Saturday,03,March,2018,17:52:31:12953
    VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
    VIN: TMBAE7NE4H01XXXXX  License Plate:
    Mileage: 3729km-2317mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
    VIN: TMBAE7NE4H01xxxxx   Mileage: 3729km-2317miles
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       Coding: 0C1D00124424010B0000
       Shop #: WSC 19383 002 1048576
       ROD: EV_ECM20TFS0205G0906259C.rod
       VCID: 2E05F397B0946CE7CA9-807A
    Readiness: 1110 0001
       Part No SW: 0D9 300 042 S    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5010
       Revision: 06454104    Serial number: TFK01610120525
       Shop #: WSC 73430 031 00063
       ROD: EV_TCMDQ250021.rod
       VCID: 290F008B897A0BDF1FB-807C
              P1734 00 [002] - -
    Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 63006000001556
       Coding: 1A076B91542119704078060241CB2958D62A98026082947600410070C00903
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
       VCID: 75B71CFB15421F3F4B3-8020
       Part No SW: 5E0 907 044 AB    HW: 5E0 907 044 AB
       Revision: 00001K07
       Coding: 01010004000110011005000000101002
       VCID: 65974CBBA5E2EFBFFB3-8030
       Serial number: 01061629000275
       Coding: 0C101A42C24722FB47E04000000C07280000000000000000000000000000
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0451713F4E9836B74CD-8050
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 161004  041 0570
       Serial number:         161018094438
       Coding: 065DDD
       Component: RLHS  042 0105
       Serial number: S3Y16M10D31H09M51S07
       Coding: 00885D
       Sun Roof:
       Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.403  H03 0004
       Serial number: 0000FST0018NRYL00000
       Coding: 981803
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39261629502863
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       ROD: EV_EPHVA14AU3700000_002_VW27.rod
       VCID: 3C21C9DF76E88E7774D-8068
       Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SQPMWG67-
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 0F7B4E1317DE45EFE1F-805A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 710 16
       Serial number: 3576U000000241E8BD1J
       Subsystem 2 - Part No SW: -----------    HW: 454 000 310 16
       Serial number: 3586U000000235244E11
       Subsystem 3 - Part No SW: -----------    HW: 454 800 610 16
       Serial number: 3516REB80310D0000006
       Subsystem 4 - Part No SW: -----------    HW: 454 801 310 16
       Serial number: 3526RF8242F0C000000F
       Subsystem 5 - Part No SW: -----------    HW: 454 800 810 16
       Serial number: 3556V422EF90C000000M
    10492928 - Supply Voltage
              B201C 00 [008] - Implausible Signal
              [Powersupply implausible signal]
                        Reset counter: 63
                        Mileage: 3729 km
                        Date: 2018.03.03
                        Time: 17:49:23
       Part No SW: 5Q0 953 521 T    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20161026500471
       Coding: 1410
       Shop #: WSC 73430 031 00000
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 43D3B2230B16F18F357-8016
       Part No SW: 5E0 920 746 C    HW: 5E0 920 746 C
       Component: KOMBI         205 8311
       Coding: 07A5010829800008010A2A001000000000000000
       Revision: --------    Serial number: 0005454104
       Coding: 030100047F085900EB00026A1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013_SK37.rod
       VCID: 7CA109DF36684E7734D-8028
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000A0320111016
       Serial number: 75410803001610260561
    131699 - Control unit for information electronics 1
              U1054 00 [009] - No Communication
              [Timeout Knoten 0x73 / 5F - Steuerger\E4t f\FCr Informationselektronik 1]
                        Reset counter: 23
                        Mileage: 3729 km
                        Date: 2018.03.03
                        Time: 17:41:00
                        Terminal 15: On
       Component: TSG FS        010 0032
       Serial number: 0000223728077
       Coding: 001D0120D000040000001100
       VCID: 47CBA6333F2EDDAFE9F-8012
       Serial number: 00000000000011987022
       Coding: 010200
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCFC77CDCB047661-806E
       Component: TSG BFS       010 0032
       Serial number: 0000225193883
       VCID: 46D5AB373824C4A7129-8012
       Serial number: 00000000000012042926
       Coding: 190200
       Coding: 03DA00003F000000
       Shop #: WSC 73430 790 00063
       VCID: 40D9BD2F1A00EA97285-8014
       Coding: 3E0000
       Coding: 3E0000
       Part No SW: 5E0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0001
       Serial number: 161008200130
       VCID: 698F408B49FACBDFDFB-803C
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.6V/12.4V)-----------
    1. Wipers park after switch close - tried using the info on Briskoda thread but the coding is different in my car - no bit 4 on byte 1
    https://www.briskoda.net/forums/topi...omment-4544426
    2. Start/Stop button disable memory , so I won't have to press the button each time
    3. Close windows from remote without holding the lock button (single press)
    I've saved Central Electronics, CAN Gateway, and Instruments channel maps , be happy to post them
    thanks
    Jun 2017
    1) I think you did not select the sub-system WWS for coding in the dropdown after clicking "Coding" in your BCM
    2) Memory is not possible in MQB cars. Only "always-off"
    3) I didn't know that this tweak exists?
  3. Likes tomer liked this post
    Feb 2018
    Israel
    Thank's, i'll have another look at the coding .
    The close windows tweak i found here http://www.vwwatercooled.com.au/foru...ary-50749.html
    guess it's not relevant anymore
    Jun 2017
    To my knowledge, not possible with your car.
    Please do not try to adapt codings for completely different cars.
  6. Likes PetrolDave, Uwe liked this post
