Results 1 to 10 of 12
Thread: Polo 6r Address 44: Steering Assist
    Mar 2018
    Norway
    Hi, I'm new in here. I have used vag-com a little but not much.
    I got this car on my shop, with defective j500, no communication with j500.
    I changed the pump, and now the powersteering works a bit but it is not good and the yellow steering wheel in instrument stil lightning.
    I have tried to change the coding but it falls back to 00140 all the time.
    now the car dont have fail cods in 44 (light stil lightning in instrument) but som times it missing signal fron g269 and this car dont have the sensor.
    What can i do?
     Monday,05,March,2018,13:13:21:20376
    VCDS Version: 17.8.1.0 (x64)
    VIN: WVWZZZ6RZDY086219   License Plate: SV33380
    Mileage: 31240km-19411mi   Repair Order:
    Chassis Type: 6R-VW25 (6R0)
    Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 61
    VIN: WVWZZZ6RZDY086219   Mileage: 31240km-19411miles
    Address 01: Engine (J623-CGPA)       Labels:. 03E-906-019-CGP.clb
       Part No SW: 03E 906 019 A    HW: 03E 906 019 A
       Component: SIMOS11.3     H04 9803
       Revision: --H04---    Serial number:
       Coding: 001100B6002401080000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_ECM12MPI02103E906019A 001009
       ROD: EV_ECM12MPI02103E906019A.rod
       VCID: 224A6E2835806956A7-8076
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       Coding: 210224E3217500B8842724E384DA00501300
       VCID: 020A0EA89940895687-8056
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
       Component: Climatronic   H11 0711
       Revision: V0000000
       VCID: 387EAC408B1C138669-806C
       Part No SW: 6R0 937 088 F    HW: 6R0 937 088
       Component: BCM PQ25 Re4  H50 0353
       Revision: BU050001    Serial number: 0456 241120082
       Coding: 24B02BBF08A10000203009F06D2B0DD05FC0612F7E860049200000000000
       VCID: 4188C1A4D8C6524EDE-8014
       Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  008 1611
       Serial number: KU0KU011091200011653
       Coding: 58BC30
       Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  008 1611
       Serial number: KU0KU005091200015262
       Coding: 58BC30
       Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
       Component: J388__TSG_HL  008 1611
       Serial number: KU0KU003091200013102
       Coding: 58BC32
       Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Component: J389__TSG_HR  008 1611
       Serial number: KU0KU004091200013936
       Coding: 58BC32
    Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
       Part No SW: 6R0 919 475 C    HW: 7E0 919 475
       Component: PARKHILFE 4K  H11 0013
       Revision: --------    Serial number: 47361224301241
       Coding: 108001
       ASAM Dataset: EV_VW250ParkiAssis2 S01008
       ROD: EV_VW250ParkiAssis2.rod
       VCID: 3E72BA58A1382DB6A3-806A
       Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
       Component: VW10Airbag01J H10 0020
       Revision: --------    Serial number: 003GY0071FPF
       Coding: 00314A
       Shop #: WSC 01383 785 00200
       ROD: EV_AirbaVW10BPAVW250_VW25.rod
       VCID: 4B94E38CE28A881E34-801E
       Serial number: 3575HRB40571JM5G39LF
       Serial number: 3585HRB40551JM5GA9DD
       Serial number: 3515RRB404R1D2B6K10$
       Serial number: 3525RRB40551AP6031CN
       Part No SW: 6R0 920 860 K    HW: 6R0 920 860 K
       Component: KOMBI         H05 0605
       Coding: 140E01
       ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
       VCID: 3C76B050B7243FA68D-8068
    Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
       Part No SW: 6R0 907 530 E    HW: 1K0 907 951
       Component: J533  Gateway H38 0041
       Revision:   H38       Serial number: 060912F1000162
       Coding: 250002
       VCID: 3560A5749C0EEEEE72-8060
                000 -  -  - Intermittent
                        Mileage: 31247 km
                        Date: 2018.03.05
                        Time: 04:05:49
       Component: IMMO          H05 0605
       VCID: 6ADA46088D3071162F-803E
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663431718
       Coding: 010100
       VCID: 2A5A860845B0B116EF-807E
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeSEI        V202
       Coding: 00140
       Shop #: WSC 12345
       VCID: 6FEC571C2AD2943E78-803A
    Address 56: Radio
       Part No SW: 6R0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H38 0041
       Coding: 032B7A64
       VCID: 74E65870D7F4B7E685-8020
       Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970096847
    End-------------------------(Elapsed Time: 02:30)--------------------------
    Tuesday,06,March,2018,11:05:58:20376
    Readiness: 0110 0101
       Revision: --------
       Revision: V0000000
       Coding: 58BC30
       Coding: 58BC30
       Coding: 58BC32
       Coding: 58BC32
       Coding: 108001
       Coding: 00314A
       Coding: 140E01
       Coding: 250002
       Coding: 010100
       Coding: 00140
       Shop #: WSC 12345
    00816 - Power Steering Sensor (G250)
                30-00 - Open or Short to Plus
    08448 - Unknown Error Code
                00-00 -  -
    Address 56: Radio
       Coding: 032B7A64
    End-------------------------(Elapsed Time: 02:33)--------------------------
    Aug 2016
    The Hague, NL
    try something like 11241 for your 44 coding
    Mar 2018
    Norway
    it loses the code when i go out of 44. when i go back in its 00140 again.
    Aug 2016
    The Hague, NL
    update your VCDS to 18.2
    check fuse 26
    try coding it again to 11241 or 01241 or 01240
    as long as the coding has the 01 in it instead of 12 it will give you the error 00618
  5. Likes Jack@European_Parts liked this post
    Mar 2018
    Norway
    check fuse 26
    i wiil try tomorrow
    Mar 2018
    Norway
    now whith the new update 18.2. it got new fail code in 44. The car dont have G250.
    and the codings jumps straigth back to 00140 after change.
    Friday,16,March,2018,08:32:52:20376
    VCDS Version: 18.2.0.3 (x64)
       VCID: 224A6E28358069542E-8076
    Readiness: 0010 0101
       Revision: --------
       VCID: 020A0EA8994089540E-8056
       Revision: V0000000
       VCID: 387EAC408B1C1384E0-806C
       VCID: 4188C1A4D8C6524C57-8014
       Coding: 58BC30
       Coding: 58BC30
       Coding: 58BC32
       Coding: 58BC32
       Coding: 108001
       VCID: 3E72BA58A1382DB42A-806A
       Coding: 00314A
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4B94E38CE28A881CBD-801E
       Coding: 140E01
       VCID: 3C76B050B7243FA404-8068
       Coding: 250002
       VCID: 3560A5749C0EEEECFB-8060
       VCID: 6ADA46088D307114A6-803E
       Coding: 010100
       VCID: 2A5A860845B0B11466-807E
       Coding: 00140
       Shop #: WSC 12345
       VCID: 6FEC571C2AD2943CF1-803A
    Address 56: Radio
       Coding: 032B7A64
       VCID: 74E65870D7F4B7E40C-8020
    End-------------------------(Elapsed Time: 02:59)--------------------------
    Aug 2016
    The Hague, NL
    that is really strange. did you check the fuse? do you see any errors? or does it say coding accepted?
  9. #8
    Mar 2018
    Norway
    yes i check the fuse, cant se anything wrong.
    Yes when i put in the coding it is writhing the code, but when i leave the address 44 and go back in its 00140 again.
  10. #9
    Aug 2016
    The Hague, NL
    OK, so now I'm slightly lost.
    Are you sure 6Q0423156AB is a proper replacement for your car? What was the part number of the original pump? do you still have it?
  11. #10
    Mar 2018
    Norway
    that was the pump i got, on the old one it was writet 6R0423156C... yes i still have the pump.
