RCD510 - RNS510 and no sound !
1975 Kombi
Acton, Ontario, Canada
C?ID=211204
Ok is there something I can check to fix the sound. RCD510 premium 8 stereo to RNS510 that might have come from a dynaudio system with the external amp. I can't get any sound out of the system and thing the coding needs to be changed.
Also original firmware and maps.
I will post the scan tomorrow.
siLc
Tallinn, Estonia
C?ID=330192
The coding of the radio is different between Dynaudio and no external amp. The Long Coding helper should help you out.
1975 Kombi
C?ID=211204
The long coding I believe is the answer but not sure what the 2010 Tiguan should have or does have. So I can't determine what to select. The tiguan is the base model with premium 8 sound and no dynaudio sound but the RNS510 might have come from a dynaudio system. Not sure though it has changed hands now and who knows what it came from.
Vasco Ferraz
Portugal
C?ID=288561
You have to change the coding of the RNS510 to use the internal amplifier.
It's very easy. Just navigate into all the bytes. When you see something related to amplifier, choose the standard one (I think it's the first choice).
1975 Kombi
C?ID=211204
Still no sound.
settings:
sound system not installed
4 speaker channels
speaker monitoring - front and rear
equalization : linear
I must be missing something. Maybe update the firmware. might be corrupt.
1975 Kombi
C?ID=211204
Friday,16,March,2018,11:05:29:08843
VCDS Version: 18.2.0.3 (x64)
VIN: WVGBV7AX0AW532471   License Plate:
Mileage: 125970km-78274mi   Repair Order:
Chassis Type: AX-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 4F 52 53 56 62
          69 72
VIN: WVGBV7AX0AW532471   Mileage: 125970km-78274miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 026 J    HW: 06J 906 026 DA
   Component: MED17.5 TFSI 2,0    0398
   Revision: AAH16---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 06137 002 1048576
   VCID: 3B75393D7A472B9C0D-806E
               P0300 - 000 -  - Intermittent
                    Mileage: 125930 km
                    Date: 2012.08.04
                    Time: 19:01:46
                    RPM: 1151 /min
                    Load: 37.2 %
                    Temperature: -6.0°C
                    Temperature: -3.0°C
                    Absolute Pres.: 960.0 mbar
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 125930 km
                    Date: 2012.08.04
                    Time: 19:01:50
                    RPM: 1092 /min
                    Load: 39.2 %
                    Temperature: -6.0°C
                    Temperature: -3.0°C
Readiness: 0010 0100
   Part No SW: 09G 927 750 KN    HW: 09G 927 750 KN
   Component: AQ 250 6F           1704
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 071D95CD760FBF7C59-8052
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 M    HW: 5N0 614 109 M
   Component: J104    C4 450 V232 0003
   Revision: --H28---    Serial number: 00000002746251
   Coding: 0010528
   VCID: 35612F055C63FDECFB-8060
   Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6ED3C069B1B58E34FA-803A
   Part No SW: 5K0 937 086 E    HW: 5K0 937 086 E
   Component: BCM PQ35 M    011 0029
   Revision: BJ011001
   Coding: 6D580A1B90232EC4008800851000050441015186524D8D605C8000000000
   VCID: 366328098165F6F4F2-8062
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 16041  012 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E3P768S4C
   Coding: 0012336
   VCID: 45815FC50C836D6C6B-8010
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 000000000071WM
   Subsystem 3 - Serial number: 0010.03.000000100000850009ÿ†63
   Subsystem 4 - Serial number: 850009ÿ†6332MTS695100770 ÿ†63
   Subsystem 5 - Serial number: 00770 ÿ†6342MTS692840770 ÿ†63
   Subsystem 6 - Serial number: 40770 ÿ†6351HTS637JE79KR ÿ†63
   Subsystem 7 - Serial number: E79KR ÿ†6361HTS6S5OV96KR ÿ†63
   Subsystem 8 - Serial number: V96KR ÿ†63727TS6539P69KJ ÿ†63
   Subsystem 9 - Serial number: P69KJ ÿ†63827TS68KRQ69KR ÿ
   Subsystem 10 - Serial number: Q69KR ÿ
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0001132
   VCID: 7AFBFC3935FDD29456-802E
   Component: E0221           002 0030
   Part No SW: 5N0 920 871 A    HW: 5N0 920 871 A
   Component: KOMBI         H05 0305
   Coding: 310F00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2F6D1D6D763FC73CB1-807A
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H17 0233
   Revision:   H17       Serial number: 1521J104170385
   Coding: FD827F46000203006002
   VCID: 6BD5C97D4AA77B1CDD-803E
                    Reset counter: 90
                    Mileage: 125946 km
                    Date: 2012.08.05
                    Time: 21:59:40
01304 - Radio
                    Reset counter: 90
                    Mileage: 125946 km
                    Date: 2012.08.05
                    Time: 21:59:43
                    Reset counter: 50
                    Mileage: 125946 km
                    Date: 2012.08.05
                    Time: 22:06:04
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4C976AE12FE99C24B4-8018
   Component: IMMO          H05 0305
   VCID: 6ADBCC798D5D6214A6-803E
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684 C
   Component: RNS-MID       H08 1140
   Revision: AB001001    Serial number: VWZ6Z7K4174042
   Coding: 0C0000000100008200
   Shop #: WSC 02449 002 104857
   VCID: 2345E15D22F7735C25-8076
                    Reset counter: 50
                    Mileage: 125944 km
00823 - Line-Output; Front Left
                    Fault Status: 00101100
                    Reset counter: 90
                    Mileage: 125944 km
00859 - Line-Output; Front Right
                    Reset counter: 90
                    Mileage: 125944 km
                    Reset counter: 50
                    Mileage: 125968 km
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2101
   Coding: 0001205
   VCID: 366328094165F6F4F2-8062
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.163 0703
   Revision: 1AH03828    Serial number: 00100990294101
   Coding: 0000258
   VCID: 3A7B3C39757D129416-806E
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H17 0233
   Revision: --------    Serial number: 1521J104170385
   Coding: 050B0500
   VCID: 66C3B8499145467482-8032
   Component: J245EE20SKB13  H01 0220
   Component: J394EE20SKB13  H01 0220
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Coding: 0001204
   VCID: 377D250D466F0FFCE9-8062
   Part No SW: 3AA 907 801 B    HW: 3AA 907 801 B
   Component: J540 EPB4  VW-49878 0004
   Revision:   H17       Serial number: 00000000092343
   Coding: 0023057
   VCID: 306F1E11A301D8C4A8-8064
                    Fault Status: 00101101
                    Reset counter: 87
                    Mileage: 125930 km
                    Date: 2012.08.04
                    Time: 02:42:19
                    Voltage: 9.50 V
                    Count: 141
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 50
                    Mileage: 125944 km
                    Reset counter: 90
                    Mileage: 125944 km
                    Reset counter: 90
                    Mileage: 125944 km
                    Reset counter: 50
                    Mileage: 125968 km
   Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
   Component: Tuer-SG         007 2102
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 39792335707B198C1F-806C
   Revision: 3A001001    Serial number: 00008200388594
   Coding: 0200000100000000
   Shop #: WSC 12345 444 00001
   VCID: 306F1E116301D8C4A8-8064
   Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
   Coding: 0001168
1975 Kombi
C?ID=211204
Maybe I have to get the coding correct on the CAN Gateway first??
1975 Kombi
C?ID=211204
Looks like it might be the internal mother board on this one. I'll try a few more things but the no communication says IC chip on board.
Viking
C?ID=151455
I've had no experience with NA units, but last time I had this it was the radio board. Do all those faults clear if you try? Or do they come back again?
1975 Kombi
C?ID=211204
I'll know tomorrow. Everything works well but no sound. It seems like the speakers pop on start up. I've read that there is a communication chip responsible on the board for the sound.
I'll try a firmware update from the 1140 it's at to 5218. If that is no good I'll try the chip bypass.
AndySwede
Stockholm Sweden
C?ID=172802
I´ve done a few retrofits with this unit. As I recall... it was a few years ago... there is a setting for external amp, if used. There is also a setting (a dropdown list) with different car models. Depending on what car the unit is installed into these are different presets with different sound profiles. This setting was sometimes necessary to change to get sound. And in Basic Settings you should be able to find a test function every speaker.
1975 Kombi
C?ID=211204
I've done a lot of reading and ya I have the long coding down pat. The highest revision of firmware I can't go on a North American RNS 510 is apparently 1140. Which is where it is at currently. So I would like to re install the 1140 and see If the firmware is corrupt at all and causing the issues.
1975 Kombi
C?ID=211204
Ok I have success!!!! I did a ton of reading the last few days and decided to re install the firmware. The highest NAR firmware that the RNS510 "C" can use is the 1140 which was installed. So it took a few days but I downloaded the 1140 and burned it to a TDK DVD at 8 speed and re installed the firmware and everything is functioning perfectly now. Took 50 mins so use a battery charger to maintain 12V. Sound is back and all CD/DVD/SD/HDD song play correctly.
I may tweak long coding for radio but currently it has sound.
Dana
Western PA, USA
Excellent! Do try that alternative coding at some point. I came up with the same value as iichel:
try coding 0C0004000400008200 for 56 radio
