This is my first repair with a VAG system, so please forgive my inexperience.
My 2009 A6 3.0T burned a valve, and I replaced it. To my surprise, after the repair, the camshaft position sensor was the only persistent error code. I'm not sure if the data shows if the camshaft is a few degrees out from the crankshaft, or if it is not sending data at all.
Please help. =)
Thank you,
Eric C
Los Altos, CA
Please help. =)
Wednesday,25,October,2017,17:03:43:43269
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WAUWG74F39N021614 License Plate:
Mileage: 222570km-138298mi Repair Order:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4C
4F 52 53 55 56 62 67 6C 72 77
VIN: WAUWG74F39N021614 Mileage: 222570km-138298miles
Address 01: Engine (CCA) Labels: None
Part No SW: 4F1 910 551 A HW: 4F1 907 551
Component: 3.0l V6 TFSI 0030
Revision: --H02--- Serial number:
Coding: 0105000A190F0120
Shop #: WSC 02325 785 00200
VCID: 211F1B2C1DC37A5F744-8074
000024 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
P0018 - 000 - Incorrect Correlation - MIL ON
Fault Status: 11100001
Mileage: 222356 km
Date: 2017.10.23
Time: 19:31:45
RPM: 704 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 91.5°C
Idle
Bin. Bits: 00010000
Readiness: 1010 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0040
Revision: --H04--- Serial number: 4494272
Shop #: WSC 02149 785 00200
VCID: 2C01FA186A01A737D72-8078
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H01 0060
Coding: 0020921
VCID: 6E8530109C9D9527B96-803A
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501226287
Coding: 0000007
VCID: 25170F3C09EB967F08C-8070
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
Fault Status: 00111011
Reset counter: 155
Mileage: 222404 km
Date: 2017.10.24
Time: 05:01:30
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361JS087525315
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 323DE4604825F1C79DE-8066
Subsystem 2 - Serial number: 00000001210370
Subsystem 3 - Serial number: 0124.10.080000000100011079ÿ
Subsystem 4 - Serial number: 011079ÿ
Reset counter: 150
Mileage: 222238 km
Date: 2017.09.22
Time: 16:51:29
Bin. Bits: 00000000
Bin. Bits: 0010000
Bin. Bits: 000
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000030403301
Coding: 0524326
VCID: 1C612AD83AA157B7A72-8048
Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
Component: ILM Fahrer H22 0320
Coding: 0133123
VCID: 3333E164B73FF8CF968-8066
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Fault Status: 00111010
Reset counter: 150
Mileage: 222220 km
Date: 2017.09.22
Time: 14:50:00
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B03F904630FA00FDE8-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0448184
Coding: 0000100
Shop #: WSC 02323 785 00200
VCID: 313FEB6C4D23CADFE44-8064
Reset counter: 110
Mileage: 222221 km
Date: 2017.09.22
Time: 14:47:33
Address 15: Airbags (J234) Labels:| 4F0-910-655-10.clb
Part No SW: 4F0 910 655 M HW: 4F0 959 655 F
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142373034303030314A55304C34463053
ROD: EV_Airba10AURB4.rod
VCID: 313FEB6C41A3CADFE44-8064
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000002U2R
Serial number: 3574SRB400007EA4B1FM
Serial number: 3584SRB400007EA469FQ
Serial number: 35152RB401P804A78RK$
Serial number: 35252RB402F804A7635X
Serial number: 3554NRB4000047673C80
Serial number: 3564NRB4000047AA6A78
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055082880108
Coding: 0012141
VCID: 270B053473E7846F3A0-8072
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 C HW: 4F0 920 983 C
Component: KOMBIINSTR. H06 0133
Revision: 00200000 Serial number: 9G2067TA8
Coding: 8B960A050B00CF05020201
Shop #: WSC 02391 823 56573
VCID: 2C01FA186601A737D72-8078
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L08A26007C
Coding: 000303
VCID: 323DE4604425F1C79DE-8066
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
Serial number: 00000000002730370736
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8655697
VCID: 1A6D2CC030952987B5E-804E
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001171762
Coding: 00581B00004011110000
VCID: 313FEB6C4123CADFE44-8064
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H52 1100
Revision: 00000000 Serial number: 395J.087530366
Shop #: WSC 22133 444 59264
VCID: 3829D648AE591B97A3A-806C
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100411299
Coding: 011F57204E40410001
VCID: 46D5A8B0D8AD7D67216-8012
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01156511480000
Coding: 4618269
VCID: 3537DF7CB94BE6FFB8C-8060
02743 - Bulb for Brake/Turn Signal Light; Right
Fault Status: 00101001
Reset counter: 150
Mileage: 176772 km
Date: 2016.01.05
Time: 12:16:57
02742 - Bulb for Brake/Turn Signal Light; Left
Fault Frequency: 19
Reset counter: 150
Mileage: 176772 km
Date: 2016.01.05
Time: 12:17:00
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000122662
Coding: 0000026
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 A HW: 4F0 907 274
Component: J793 RKA+ H02 0100
Revision: 00000000 Serial number: 00008390037870
Coding: 0623301
Shop #: WSC 00477 128 36039
VCID: 221D142018C561476DE-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000252005
Coding: 0002014
VCID: 5EE560D06C3D05A7096-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100423086
VCID: 45D7AFBCE5AB767F28C-8010
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000026
VCID: 698F430CA573721FEC4-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Revision: 00000000 Serial number: 379J3087546618
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100416316
Coding: 010E57204040220001
VCID: 43D3B1A4EB9F484F068-8016
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000810240210
Shop #: WSC 12336 024 394758
VCID: 3431E278B231FFF78F2-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J8X20UC
Coding: 1000304
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100421376
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005067952
Coding: 0010900
VCID: 280906087EF98B1733A-807C
End----------(Elapsed Time: 01:58, VBatt start/end: 14.0V/14.0V)-----------
Thank you,
Eric C
Los Altos, CA
