Hey guys, new member of the VCDS community. Hopefully someone can point me in the right direction on this one. I just bought a 1999 MK4 Jetta 2.0L and there are a lot of fault codes. My main concern(and my wife's) at the moment is the airbag system. The light is on, I scanned the car and 7 airbag faults came up.
My horn doesn't work and I've tested both horns (in the front bumper not the alarm horn) and only one of them works. My cruise control doesn't work either so I thought it might be the clock spring at first. Would the clock spring cause all of these issues?
Based on the research I've already done I'm thinking it's the airbag module. A new airbag module is pretty expensive so I want to make sure that it's the problem before I buy one and code it.
Any help is appreciated. Thanks.
-Mac
Sunday,11,March,2018,09:19:20:38994
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
75 76
Mileage: 138250km-85904miles
Address 01: Engine Labels: 06A-906-018-AEG.lbl
Part No: 06A 906 018 JA
Component: MOTRONIC M5.9.2 AT V01
Coding: 00001
Shop #: WSC 00503
VCID: 6A8D3F4BF5666C77CCC-4B3C
16806 - Main Catalyst; Bank 1
P0422 - 35-00 - Efficiency Below Threshold
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
00671 - Cruise Control Switch (E45)
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-10 - Implausible Signal - Intermittent
18034 - Powertrain Data Bus
P1626 - 35-10 - Missing Message from TCU - Intermittent
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 EN
Component: AG4 Getriebe 01M 4386
Coding: 00000
VCID: 00597DE3E31A8627728-0962
01316 - ABS Control Module
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3537DC37EC58F38F91E-4B00
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: C AIRBAG VW3 SG 0002
Coding: 00067
Shop #: WSC 00066
VCID: 6C813953FF927247BE0-4B7A
7 Faults Found:
00-00 - -
01221 - Crash Sensor Side Airbag; Driver Side (G179)
28-10 - Short to Plus - Intermittent
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
25-10 - Unknown Switch Condition - Intermittent
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 951 C
Component: A4-KOMBIINSTR. VDO V57
Coding: 06242
VCID: 3039ED23133AD6A7C28-513C
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 06556BFBC13EA817484-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
01141 - Luggage Compartment Unlocking Switch (E165)
35-00 - -
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 02041
Shop #: WSC 00066
VCID: 3E25C31BD96E30D7404-51F2
End----------(Elapsed Time: 05:22, VBatt start/end: 11.8V/13.7V)-----------
-Mac
