Results 1 to 3 of 3
Thread: 1999 VW Jetta Airbag Codes
    Mar 2018
    Hey guys, new member of the VCDS community. Hopefully someone can point me in the right direction on this one. I just bought a 1999 MK4 Jetta 2.0L and there are a lot of fault codes. My main concern(and my wife's) at the moment is the airbag system. The light is on, I scanned the car and 7 airbag faults came up.
    Sunday,11,March,2018,09:19:20:38994
    Chassis Type: 9M - VW Jetta IV (1998 > 2014)
              75 76
       Mileage: 138250km-85904miles
    Address 01: Engine        Labels: 06A-906-018-AEG.lbl
       Part No: 06A 906 018 JA
       Component: MOTRONIC M5.9.2  AT V01
       Coding: 00001
       Shop #: WSC 00503
       VCID: 6A8D3F4BF5666C77CCC-4B3C
    6 Faults Found:
    16806 - Main Catalyst; Bank 1
                P0422 - 35-00 - Efficiency Below Threshold
    18057 - Powertrain Data Bus
                P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
    00671 - Cruise Control Switch (E45)
    16795 - Secondary Air Injection System
                P0411 - 35-00 - Incorrect Flow Detected
    16500 - Engine Coolant Temp. Sensor (G62)
                P0116 - 35-10 - Implausible Signal - Intermittent
    18034 - Powertrain Data Bus
                P1626 - 35-10 - Missing Message from TCU - Intermittent
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 EN
       Component: AG4 Getriebe 01M    4386
       Coding: 00000
       VCID: 00597DE3E31A8627728-0962
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 G
       Component: ABS     20 IE CAN  0001
       Coding: 03504
       Shop #: WSC 00066
       VCID: 3537DC37EC58F38F91E-4B00
    01312 - Powertrain Data Bus
                37-10 - Faulty - Intermittent
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 609
       Component:  C AIRBAG VW3 SG   0002
       Coding: 00067
       Shop #: WSC 00066
       VCID: 6C813953FF927247BE0-4B7A
    7 Faults Found:
    65535 - Internal Control Module Memory Error
                00-00 -  -
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                28-10 - Short to Plus - Intermittent
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                25-10 - Unknown Switch Condition - Intermittent
                32-10 - Resistance Too High - Intermittent
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 1J0-919-xxx-17.lbl
       Part No: 1J0 919 951 C
       Component: A4-KOMBIINSTR. VDO V57
       Coding: 06242
       VCID: 3039ED23133AD6A7C28-513C
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 61 Zentral-SG Komf. 0001
       Coding: 04096
       Shop #: WSC 00066
       VCID: 06556BFBC13EA817484-4B1E
       Subsystem 1 - Part No: 1J1959801C
       Component: 61 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 61 Tőrsteuerger. BF0002r
       Subsystem 3 - Part No: 1J4959811C
       Component: 61 Tőrsteuerger. HL0002r
       Subsystem 4 - Part No: 1J4959812C
       Component: 61 Tőrsteuerger. HR0002r
    01141 - Luggage Compartment Unlocking Switch (E165)
    00943 - Heated Exterior Mirror; Driver Side (Z4)
                35-00 -  -
                35-00 -  -
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1JM 035 157 A
       Component:  Radio DE2         0005
       Coding: 02041
       Shop #: WSC 00066
       VCID: 3E25C31BD96E30D7404-51F2
    End----------(Elapsed Time: 05:22, VBatt start/end: 11.8V/13.7V)-----------
    My horn doesn't work and I've tested both horns (in the front bumper not the alarm horn) and only one of them works. My cruise control doesn't work either so I thought it might be the clock spring at first. Would the clock spring cause all of these issues?
    Based on the research I've already done I'm thinking it's the airbag module. A new airbag module is pretty expensive so I want to make sure that it's the problem before I buy one and code it.
    Any help is appreciated. Thanks.
    -Mac
    Mar 2018
    I should also mention that my cabin air filter cover was broken causing water to leak down and soak my cabin air filter which led to water dripping under the glove box, not sure if it actually made it as far as the airbag module though. I pulled the airbag module yesterday and this is what it looked like.
    The actual connection and wiring harness seemed to be OK, there were no broken wires or any corrosion.
    Aug 2016
    Eindhoven, NB, NL
    Welcome OP to the VCDS community.
    Have a look at these links:
    http://wiki.ross-tech.com/wiki/index.php/65535
    http://wiki.ross-tech.com/wiki/index.php/00588
    Looks like there are some good odds the airbag ECU is toast due to water ingress or you have a case of short/resistance on the connector.
    Be aware that the airbags are now not working.
    Also, the photo you try to post is not working.
  4. Likes Jack@European_Parts, Uwe liked this post
