Golf 5 Abs long coding
NWT
C?ID=22843
Hi Guys
I have a 2008 Golf 5 1.9 TDI here that has lost ABS coding somehow. (It also had faulty cluster but we are working on that...)
can anyone please help with the ABS coding for this car?
Thanks
Monday,12,March,2018,15:03:03:46000
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZ1KZ9W029686   License Plate: TUI9227
Mileage: 76910km-47789mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ9W029686   Mileage: 76910km-47789miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 PM    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  1136
   Revision: --H08---    Serial number: VWX7Z0H53NI9N9
   Coding: 0000071
   Shop #: WSC 06402 785 00200
   VCID: 79F39B65306AE28C5F-802C
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Mileage: 76913 km
                    Time: 02:51:43
                    Load: 0.0 %
                    Voltage: 12.92 V
                    Bin. Bits: 00000100
                    Temperature: 15.3°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 76913 km
                    Time: 02:51:43
                    Load: 0.0 %
                    Voltage: 12.92 V
                    Bin. Bits: 00000100
                    Temperature: 15.3°C
                    Bin. Bits: 00110000
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - MIL ON
                    Fault Status: 11110000
                    Mileage: 76913 km
                    Time: 02:51:46
                    RPM: 1008 /min
                    Load: 0.0 %
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Bin. Bits: 11000000
                    (no units): 33.0
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Shop #: WSC 01316 785 00200
   VCID: 74EDAA51D7089FE40C-8020
            000 -  -
                    Reset counter: 132
                    Count: 2
                    Count: 4608
                    Count: 195
                    Count: 47360
   Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 76E9905901748DF432-8022
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000008521846
   Coding: 00890F2700041500471400001400000000087B075C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 32616C49AD9CD1D4DE-8066
   Component: Wischer 060608 021  0501
   Coding: 00038805
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD22Y39D
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D7B4F7564C21EAC33-8068
   Subsystem 1 - Serial number: 6332MSME31634207/
   Subsystem 2 - Serial number: 6342MSME316375445
   Subsystem 3 - Serial number: 6352QSME6A701B67P
   Subsystem 4 - Serial number: 6362QSME6B7C1B65.
   Part No SW: 1K0 953 549 BT    HW: 1K0 953 549 BT
   Component: J0527           051 0101
   Shop #: WSC 01279 785 00200
   VCID: 050BE7954C92966C2B-8050
   Part No SW: 1K0 920 954 N    HW: 1K0 920 954 N
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0H53N98FP
   Coding: 0003403
   Shop #: WSC 00791 210 82417
   VCID: 37775D5D46FE34FCE9-8062
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 070608F2000501
   Coding: E9801F060002020001
   VCID: 356B57555CF2C6ECFB-8060
   Component: IMMO            VDD 1222
01176 - Key
            008 - Implausible Signal
                    Fault Status: 01101000
                    Mileage: 76913 km
                    Time: 03:58:16
   Component: Tuer-SG         006 1208
   Coding: 0000564
   VCID: 38755E614BE03B84E0-806C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A517429854C991466-807E
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 76913 km
                    Time: 03:58:16
                    Battery Volts: 13.1 V
                        DD
                    Temperature: 17.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Coding: 00C802087F2D8405485A038010CC
   VCID: 78F59E610B60FB8420-802C
   Coding: 0000564
   VCID: 39735B6570EA228C1F-806C
   Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
   Component: Radio         017 0043
   Revision: R0017000    Serial number: VWZAZ1H7024382
   Coding: 0000020002
   Shop #: WSC 00156 210 175178
   VCID: 21439305387A5A4C37-8074
End-------------------------(Elapsed Time: 01:21)--------------------------
][/QUOTE]]
[[/CODE]
NWT
C?ID=22843
thanks for the reply. That coding isn't accepted...
As regards the cluster.
Old cluster is completely dead. Have second hand cluster fitted and we are trying to adapt it to the car. Cluster is currently saying safe and we can't thnik if it should say this or has it already been locked out.
We have login for old and new cluster and while cluster will accept the login through securtity access immobiliser (25), adaption (10) channel 50 just shows error....
Any ideas on this?
Thanks again
downtime
C?ID=280813
I don't think you can adapt it that way anymore. The 2008 is using IMMO4c and that I think cannot be adapted with SKC's anymore. You'll need a dealer to do the adaptation online.
iichel
Netherlands, eastern part
C?ID=284912
I agree with downtime.
Furthermore, it is essential for the ABS coding, that we know what VIN the ABS thinks the car has. This VIN needs to match between cluster, immo and engine ECU.
Keep in mind people VIN and PC power class will be required to be a match set for ABS coding.
NWT
C?ID=22843
Ok guys thanks for the advice. Couldn't get cluster adapted so getting nowhere with ABS either. Have had to give up on this one..
thanks anyway for the help!
If you ship me the clusters and all keys with engine ecu I can marry here and do a proper data transfer with verified ownership record since FOD.
Then the data will reflect continuity to allow for ABS long coding.
When I was a child I indeed wanted to be a Priest, as time went on and real life situations took place, I quickly realized it was not a way I wanted to espouse or put my trust again. When you really believe in the big guy upstairs, it really hurts having that crumble.
Much more earth shattering than Santa Claus or the Easter bunny & took a long time to understand, it is still memories I wish I didn't have to live with.
Kind of like believing in a product & that you put your life's work in, only to be completely disappointed.
:cry:
