Results 1 to 6 of 6
Thread: 2011 Touareg throwing a lot of fault codes
    Mar 2018
    Norway
    Hello!
    New to this forum, bought a hex-net yesterday to try to solve some issues with my Touareg.
    Car runs great, only "fault" is that the ACC does not work. Engine/gearbox/suspension works as normal, although error codes appear on the info screen.
    This is checked/done:
    New battery, original, coded in
    Checked all fuses
    Erased fault codes several times
     VIN: WVGZZZ7PZBD013171   License Plate: DN49430
    Mileage: 217922km-135410mi   Repair Order:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 28 34 36 3C 42 46
              47 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
    VIN: WVGZZZ7PZBD013171   Mileage: 217922km-135410miles
    13-Auto Dist. Reg -- Status: Malfunction 0110
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401     HW: 7P0 907 401
       Component: 3.0TDI EDC17  H17 0007
       Revision: 51H17---
       Coding: 292A401A237E01020000
       Shop #: WSC 00010 218 999999
       ASAM Dataset: EV_ECM30TDI0117P0907401 002009
       ROD: EV_ECM30TDI_VW52.rod
       VCID: 6C9428C687A92E24D4-8038
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
              [Lost Communication WithCruise Control Front Distance Range Sensor]
                        Fault Frequency: 12
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:36:48
                        Engine speed: 947.00 /min
                        Normed load value: 15.3 %
                        Coolant temperature: 58 °C
                        Intake air temperature: 17 °C
                        Voltage terminal 30: 14.140 V
                        Limitation: accelerator pedal: 43.8 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 244
                        selected gear-Bits 0-7: 0
       Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
       Component: AL1000 AISIN  001 1811
       Coding: 001568
       Shop #: WSC 34063 001 1048576
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031_001_VW52.rod
       VCID: 312AF9B2600B83CCA7-8064
    12816 - No Communication with Cruise Control Module
              U0104 00 [009] - -
                        Reset counter: 201
                        Engine speed: 930.0 /min
                        Transmission input speed: 900 /min
                        Transmission output speed: 0 /min
                        Engine torque: -12 Nm
                        Transmission fluid temperature: 54 °C
                        Accelerator position: 3.2 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Open
                        EOP failure status 2: Normalcy
                        EOP target revolution: 0 /min
                        EOP actual revolution: 65279 /min
                        Engine Speed signal Current: 65279 /min
                        EOP failure status with EOP without HV 1: Motor normal stop
                        EOP target current: 65278 mA
    Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
       Part No SW: 7P0 907 379 E    HW: 7P0 907 379 A
       Component: MK25A         H33 0416
       Revision: --------    Serial number: 421600010EC010
       Coding: 5B6B13C30B252F56DAF5C89AD0D3F4507700
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A00700.rod
       VCID: 3FCEAF8AA65F65BC21-806A
    818440 - Databus
              U1122 00 [072] - Implausible Message
              [AWV CAN Signal unplausibles Signal]
                        Reset counter: 141
                        Mileage: 217820 km
                        Date: 2018.03.10
                        Time: 12:15:01
                        Standard Freeze  Frame Dynamic: 00 46 0B 45 00 00 00 00 01 00 01 20 35
    818436 - Databus
              [AWV CAN-Überwachung kein Signal / Kommunikation]
                        Reset counter: 140
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:38
                        Standard Freeze  Frame Dynamic: 00 3D 00 00 00 00 00 07 00 00 01 20 34
    337668 - Databus
              [Steuergerät für ADR kein Signal/Kommunikation]
                        Reset counter: 140
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:38
                        Standard Freeze  Frame Dynamic: 00 3D 00 00 00 00 00 07 00 00 01 20 0E
       Part No SW: 4H0 907 064 AM    HW: 4H0 907 064 AM
       Component: BCM2 2.0      H23 0208
       Coding: 05A60000000000000000
       VCID: 74A430A6D799F6E40C-8020
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 0210000092333016
       Part No SW: 4H0 959 760 A    HW: 4H0 959 760 A
       Component: MEM-BFS       H07 0114
       Revision: AA000000    Serial number: 00001002073332
       Coding: C018330015004201000001010101202020202121202020
       VCID: 312AF9B2680B83CCA7-8064
    03777 - Sensor for Lumbar Support Adjustment
                        Fault Status: 01100101
                        Reset counter: 140
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:37
       Part No SW: 7P6 907 040 AL    HW: 7P6 907 040 AL
       Component: Klima 4 Zonen H18 0612
       Coding: 36D600BE70
       VCID: 7EB0128EE1D5ACB46A-802A
    0381 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Funktionseinschränkung wegen fehlender Botschaft]
                        Reset counter: 181
                        Mileage: 217814 km
                        Date: 2018.03.10
                        Time: 12:07:44
       Part No SW: 4H0 907 063 C    HW: 4H0 907 063 C
       Component: BCM1 2.0      H11 0083
       Revision: 14011002    Serial number: 00000000606654
       Coding: 26001091D13459010021000080005D0C431C670806010241800000020000
       VCID: 281C14D65BD1C20470-807C
       Component: WWS    100723  31  0020
       Serial number: 90243400100724212752
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10047327
       Coding: 035223
       Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
       Component: E1 - LDS  H04 0031
       Serial number: 00000000000608100637
       Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0275
       Serial number: WA100297000000062072
       Coding: 010300
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475     HW: 7P6 919 475
       Component: PARKHILFE 8K  H03 0016
       Revision: --------    Serial number: 38941016802145
       Coding: 518D01
       ASAM Dataset: EV_VW526ParkiAssis2 001008
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 55E26D2234238FEC1B-8000
    12727552 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Abstandsdistanzregelung - ACC_02_FR - kein Signal/keine Kommunikation]
                        Fault Frequency: 151
                        Reset counter: 181
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:33:13
    Address 13: Auto Dist. Reg
       Part No SW: 7P0 959 655 A    HW: 7P0 959 655 A
       Component: VW10Airbag079 H05 0020
       Revision: --------    Serial number: 003FH000UC0Y
       Coding: 000000000000000000000000000000003739
       Serial number: 3575LRB40676U4L24O5K
       Serial number: 3585LRB401C50GS8CG7H
       Serial number: 3515RRB405L6TUHOM8TG
       Serial number: 3525RRB40596T8MG99B-
       Serial number: 3555NRB40576UBV8NGTY
       Serial number: 3565NRB40576UBV8JPHS
       Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
       Component: Lenks.Modul   H07 0007
       Revision: --------    Serial number: 90815JHG0001W
       Coding: 000C9D
       VCID: 3228F6BE6D0DB8D4DE-8066
       Serial number: 0022466
       Part No SW: 7P6 920 880 D    HW: 7P6 920 880 D
       Component: Kombi         H09 0114
       Revision: 08240053    Serial number: 658130810593000
       Coding: 031F33007F080008010004
       Shop #: WSC 35001 001 104857
       ASAM Dataset: EV_KombiUDSRBVW526 001011
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 3C34D886B7497EA404-8068
    16776960 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_02_FR keine Kommunikation]
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:35
    16776961 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_04_FR keine Kommunikation]
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:35
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 7P0 963 272 B    HW: 7P0 963 272 B
       Component: Standheizung  H23 0240
       Revision: 56005006    Serial number: 20100510085519
       Coding: 514200
       VCID: 3620CAAE8165A4F4F2-8062
       Part No SW: 7P6 907 530 D    HW: 7P6 907 530
       Component: GW-CAN-L-FR-M H08 5202
       Revision: --------    Serial number: 00000000031839
       Coding: 000D077500
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 393AC192B87B4B8C1F-806C
       Serial number: 00000000005650332341
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 7PP 959 663 B    HW: 7PP 959 663 B
       Component: J532_DCDCStab  H16 0039
       Serial number: 10188000689021200180
    4365 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:34
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 31 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    0273 - FlexRay-Data bus
              U106E 00 [008] - Signal error
              [FlexRay-Datenbus Signalfehler (Buszugriff-Fehler / Sendekollision)]
                        Reset counter: 181
                        Mileage: 217792 km
                        Date: 2018.03.10
                        Time: 11:24:04
                        Voltage terminal 30: 14.2 V
                        Voltage terminal 15: 14.1 V
                        Control Module temperature: 24 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 4
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 7P6 907 049 N    HW: 7P6 907 049 N
       Component: Klima Fond    H14 1305
       Coding: 0000000000
       ASAM Dataset: EV_AirCondiHeck 001007
       ROD: EV_AirCondiHeck.rod
       VCID: 48DCB456F391220490-801C
    Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
       Part No SW: 7P0 907 553 J    HW: 7P0 907 553 J
       Component: PASM          H01 1030
       Revision: 00000000    Serial number: 00000102130334
       Coding: 14210001
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
       VCID: 3E30D28EA1556CB42A-806A
    12656679 - Databus
              [CAN-Timeoutfehler ACC]
                        Fault Frequency: 141
                        Reset counter: 3
                        Mileage: 213504 km
                        Date: 2053.04.03
                        Time: 30:09:05
                        Default: 00
                        Default: 8D
                        Default: 00
    0840 - Comfort limitation
              C10D7 00 [137] -  -
              [Dämpferregelung - eingeschränkter Normalbetrieb - Notlauf 1]
                        Fault Priority: 10
                        Reset counter: 3
                        Mileage: 213504 km
                        Date: 2053.04.04
                        Time: 10:29:07
                        Default: 00
                        Default: 8E
                        Default: 00
       Component: MEM-FS        H07 0114
       Revision: AA000000    Serial number: 00001002073270
       Coding: C0183B0015004201000001010101202020202121202020
       Shop #: WSC 14740 000 1048576
    03312 - Temperature Sensor for Seat Heating
                        Fault Status: 00101010
                        Reset counter: 181
                        Mileage: 217814 km
                        Date: 2018.03.10
                        Time: 12:07:44
       Part No SW: 7P6 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH03 0110
       Revision: 00H03000    Serial number: 6PZ 010 316-01
       Coding: 0010151
       VCID: 7EB0128E29D5ACB46A-802A
       Subsystem 1 - Part No: 7P6 907 568
       Component: J770  SWA Slave H01 0110
       Subsystem 2 - Serial number: 6PZ 010 316-21
       Subsystem 3 - Serial number: 5F07.08.1000H010003C520669ÿ
       Subsystem 4 - Serial number: 520669ÿ
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000106851701
       Coding: 011D1620DE00459205080001
       VCID: 3B36DB9ABA47799C0D-806E
       Revision: 00002001    Serial number: 0133461651
       Coding: 01001E2028B91095832006242F0000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P0 959 591     HW: 7P0 959 591
       Component: J245 PS30.050  H05 0006
       Serial number:     WOO1034602X
       Coding: 191100
       Subsystem 2 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
       Component: J394 PS30.050  H06 0006
       Serial number:     WOO1035049$
       Coding: 191100
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:38
                        Fault Status: 00101100
                        Reset counter: 180
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:15:38
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 140
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:15:39
                        Reset counter: 141
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 11:10:29
       Part No SW: 7P6 035 466     HW: 7P6 035 466
       Component: DSP Prem      H01 0090
       Revision: 00001001    Serial number: 10810000471605
       VCID: 75A20DA2DCE3EFEC3B-8020
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0162
       Revision: --------    Serial number: 0000107055630
       Coding: 011D1620DE00459205080000
       Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
       Component: EPB           H51 1000
       Revision: 00000000    Serial number: A1072600589
       Coding: 01040000
       Shop #: WSC 00010 218 50024
       ROD: EV_ParkbA7.rod
       VCID: 3424F0A69F19B6E4CC-8060
       Slave 3:
    12656679 - Databus
              [CAN-Timeout ACC]
                        Reset counter: 140
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:06:39
                        Voltage: 12.0 V
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 01AA00000F000200
       VCID: 7CB41886F7C9BEA444-8028
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0006
       Coding: 130000
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0006
       Coding: 130000
       Part No SW: 4F0 035 061 H    HW: 4F0 035 061
       Component: Radio U DAB   H46 0048
       Revision: AB001007    Serial number: 006CP0A7506084
       Coding: 010105010000000001
       VCID: 210A09F238EB334C37-8074
       Part No SW: 7P6 035 670     HW: 7P6 035 670
       Component: H-BNT-EU      H43 0203
       Revision: --------    Serial number: 478H30A7522693
       Coding: 020100050040EBEF79102B0E00000003F0040101
       Shop #: WSC 37781 001 1048576
       VCID: 72A836BEAD8DF8D41E-8026
       Subsystem 1 - Part No: 8R0 060 884 R
       Component: EUR 2010  1106
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H23 0045
       Serial number: VWZ8Z9K28003W2
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: CD-Database  1886
                        Reset counter: 141
                        Mileage: 217919 km
                        Date: 2018.03.10
                        Time: 14:41:00
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
    00862 - Antenna for GPS Navigation (R50/R52)
                        Fault Status: 00101011
                        Reset counter: 181
                        Mileage: 217793 km
                        Date: 2018.03.10
                        Time: 11:24:43
                        Voltage: 14.10 V
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0162
       Revision: --------    Serial number: 0000107224880
       Coding: 011C16200000259005080000
       VCID: 3A38DE9EB57D409416-806E
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000006626
       ROD: EV_RDKBERU25_VW52.rod
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 7P0 907 383 C    HW: 7P0 907 383 C
       Component: Anhaenger     H07 0073
       Revision: 5H001003    Serial number: 00000133448646
       Coding: 0106040000000000
       VCID: 383CC4968B715284E0-806C
    Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
       Part No SW: 7P6 907 441 C    HW: 7P6 907 441 C
       Component: TopView       --- 0093
       Coding: 0100000001010000010102000000
       ASAM Dataset: EV_CamerSysteTopViewVW 001013
       ROD: EV_CamerSysteTopViewVW.rod
    13701388 - Databus
              [Funktionseinschraenkung wegen fehlender Botschaft (LWI_01_alt)]
                        Reset counter: 180
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 10:59:49
                        Voltage terminal 30: 12.5 V
    10489856 - No Basic Setting
              B2010 00 [009] -  -
              [TopView system not calibrated]
                        Reset counter: 140
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:40
                        Voltage terminal 30: 12.0 V
       Part No SW: 7P6 959 107     HW: 7P6 959 107
       Component: HDSG-Modul    H10 0611
       Revision: 09145444    Serial number: 196000006
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202135
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H09 0162
       Revision: --------    Serial number: 0000107225770
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 7P6 907 217     HW: 7P6 907 217
       Component: DPC-SG        H22 0012
       Coding: E9070000
       ASAM Dataset: EV_OnBoardCamerDTR 001001
       ROD: EV_OnBoardCamerDTR.rod
       VCID: 77BE07AACEEF9DFC29-8022
       Slave 1:
       Subsystem 1 - Part No: 7P6 907 658
       Component: NICKRATENSENS  H02 0001
       Serial number: 000000003019861_2090
    0724 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_timeout]
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:40
                        Outside air temperature: -45.0 °C
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 28.0 °C
       Part No SW: 7P6 907 541 A    HW: 7P6 907 541
       Component: ACC3          H13 0230
       Coding: 3F04010101
       ASAM Dataset: EV_AdaptCruisContr2VW526 001004
       ROD: EV_AdaptCruisContr2VW526_001.rod
       VCID: 383CC49683715284E0-806C
    10 Faults Found:
    27648 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_ESP_01]
                        Fault Frequency: 21
                        Reset counter: 181
                        Mileage: 217795 km
                        Date: 2018.03.10
                        Time: 11:26:24
                        Control Module temperature: 3 °C
                        Voltage terminal 15: 14.229 V
                        Velocity_vehicle_reference: 21.80 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
    29184 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_GATEWAY_05]
                        Fault Frequency: 19
                        Reset counter: 181
                        Mileage: 217795 km
                        Date: 2018.03.10
                        Time: 11:26:09
                        Control Module temperature: 4 °C
                        Voltage terminal 15: 14.137 V
                        Velocity_vehicle_reference: 22.82 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.08 m/s²
    76800 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_TSK_05]
                        Reset counter: 181
                        Mileage: 217792 km
                        Date: 2018.03.10
                        Time: 11:23:45
                        Control Module temperature: 5 °C
                        Voltage terminal 15: 14.248 V
                        Velocity_vehicle_reference: 19.89 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.32 m/s²
    94720 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_QDCACC_FAIL]
                        Reset counter: 141
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:38:10
                        Control Module temperature: 8 °C
                        Voltage terminal 15: 14.162 V
                        Velocity_vehicle_reference: -0.01 m/s
    95232 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_QEPBACC_FAIL]
                        Reset counter: 181
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:38:43
    95488 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_QDISACC_FAIL]
                        Reset counter: 181
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 11:10:31
                        Control Module temperature: 10 °C
                        Voltage terminal 15: 13.930 V
                        Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
    77568 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FAULT_CIM_TIMEOUT_LRRM_DEJU]
                        Fault Frequency: 117
                        Reset counter: 181
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:39:42
                        Control Module temperature: 9 °C
                        Voltage terminal 15: 14.221 V
    144896 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_US_FAIL]
                        Reset counter: 181
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:39:28
                        Voltage terminal 15: 14.255 V
    82688 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_TSK_FAIL]
                        Fault Frequency: 13
                        Reset counter: 141
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:29:53
                        Control Module temperature: -2 °C
                        Voltage terminal 15: 12.111 V
    145408 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_NAVI_FAIL]
                        Fault Frequency: 71
                        Reset counter: 181
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:39:12
                        Voltage terminal 15: 14.210 V
    Address 8E: Image Processing (J851)       Labels:* None
       Part No SW: 7P6 907 107     HW: 7P6 907 107
       Component: BV-SG         H28 0003
       Serial number: 000040171906107
       Coding: 0AA0BE04
       ASAM Dataset: EV_BTR 001001
       ROD: EV_BTR_001.rod
       VCID: 75A20DA2D4E3EFEC3B-8020
    0064 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [BCM2_Timeout]
                        Reset counter: 181
                        Mileage: 217795 km
                        Date: 2018.03.10
                        Time: 11:26:12
    0046 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_timeout]
                        Reset counter: 181
                        Mileage: 217922 km
                        Date: 2018.03.10
                        Time: 16:37:45
    0003 - Data Set Implausible
              B2012 00 [009] -  -
              [Code_External_Flash_ROM_missing_or_corrupt]
                        Reset counter: 181
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:35
    0051 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [BCM1_Timeout]
                        Fault Frequency: 9
                        Reset counter: 181
                        Mileage: 217795 km
                        Date: 2018.03.10
                        Time: 11:26:11
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 006606000317037F00033811594097000000
       Shop #: WSC 00001 790 00001
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FAE3FCAB6BFD53CF1-803A
    12583680 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:36
    12583693 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:36
    12583937 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 181
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 11:11:10
    12583970 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 181
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 11:12:29
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       Coding: 00660600031F037F00033811594097000000
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70AC3CB6AB81CAC4E8-8024
              U1111 00 [009] - -
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:39
              U1111 00 [009] - -
                        Reset counter: 141
                        Mileage: 217777 km
                        Date: 2018.03.09
                        Time: 17:05:39
              U1112 00 [008] - -
                        Reset counter: 181
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 11:11:10
              U1112 00 [008] - -
                        Reset counter: 181
                        Mileage: 217783 km
                        Date: 2018.03.10
                        Time: 11:12:29
    End----------(Elapsed Time: 02:25, VBatt start/end: 14.3V/14.4V)-----------
    Many, if not most of those faults appear to be related to your 13 - Auto Dist. Reg module being off-line:
    What's a bit curious though is that the Gateway shows it has having a "Malfunction" rather than "Cannot be reached". I guess the first thing I would do is carefully check wiring to that module.
  3. Likes Ole Opsahl liked this post
    Hello and welcome OP to the VCDS forum.......
    Thank you for posting the auto-scan!
    Please Check fuses and ground points in addition for water ingress.
    Trace and check CCS 0x13 for distance module using WD and RTFB, if bad change CSS distance sensor module.
    JPPSG
  5. Likes Ole Opsahl liked this post
  6. #4
    Mar 2018
    Norway
    Thank you for the good advice.
    I opened up the ACC radars, and one of them was badly damaged by water ingress.
    Found a set of radars on ebay from germany, so have changed them today.
    This is the new scan, a lot better, but ACC is still not working.
    I know i must have them calibrated etc, but it seems that there is some kind of error still?
       Monday,26,March,2018,17:43:10:08921
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
    VIN: WVGZZZ7PZBD013171   Mileage: 219404km-136331miles
    06-Seat Mem. Pass -- Status: Malfunction 0010 (known fault)
       Revision: 51H17---
       Coding: 001568
              U0104 00 [008] - -
                        Reset counter: 196
                        Engine speed: 690.0 /min
                        Transmission input speed: 660 /min
                        Engine torque: -4 Nm
                        Accelerator position: 0.0 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:22
       Coding: 36D600BE70
       Coding: 004DBD
       Coding: 035223
       Coding: 010300
       Coding: 518D01
       Part No SW: 7P6 907 561     HW: 7P6 907 561
       Component: ACC3          H13 0160
       Coding: 3F04010101
       ASAM Dataset: EV_AdaptCruisContrVW526 001004
       ROD: EV_AdaptCruisContrVW526_001.rod
       VCID: 79BA0192F8FB8B8C5F-802C
              U1113 00 [009] - -
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:24
                        Control Module temperature: 2 °C
                        Voltage terminal 15: 14.119 V
                        Velocity_vehicle_reference: 16.95 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.52 m/s²
              U1101 00 [009] - Active
              [FAULT_ATP_IKA_FAILED]
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:24
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_VIDEO_FAIL]
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:24
       Coding: 000C9D
       Coding: 514200
       Coding: 000D077500
       Voltage stabilizer:
       Coding: 0000000000
       Coding: 14210001
       Coding: 0010151
       Coding: 191100
       Coding: 191100
       Coding: 130000
       Coding: 130000
              B2010 00 [009] -  -
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:44
                        Voltage terminal 30: 13.9 V
       Coding: 0533314003
       Coding: E9070000
       Slave 1:
       Part No SW: 7P6 907 541 B    HW: 7P6 907 541
       Component: ACC3          H13 0340
       Coding: 3F04010101
       Shop #: WSC 17302 666 28888
       ASAM Dataset: EV_AdaptCruisContr2VW526 002010
       ROD: EV_AdaptCruisContr2VW526_002.rod
              U1113 00 [009] - -
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:24
                        Voltage terminal 15: 14.130 V
                        Longitudinal_acceleration_vehicle_reference: -0.56 m/s²
    15360768 - Component Protection
              [FAULT_ATP_IKA_FAST_FAILED]
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:24
                        Voltage terminal 15: 14.151 V
                        Velocity_vehicle_reference: 17.12 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.50 m/s²
       Coding: 0AA0BE04
       ROD: EV_BTR_001.rod
              B2012 00 [009] -  -
                        Reset counter: 170
                        Mileage: 219404 km
                        Date: 2018.03.26
                        Time: 17:40:23
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:22, VBatt start/end: 14.3V/14.1V)-----------
  7. Likes Jack@European_Parts liked this post
  8. #5
    Dec 2016
    NL
    Component protection is an anti-theft measure, which will trigger if you install a control module that uses CP into a different car. The dealer can re-learn the new radar module(s) to the car which requires an online connection to VW HQ. Until the component protection is cleared, the module will not communicate with any other modules and will not work.
    Current:
  9. Likes Ole Opsahl, Jack@European_Parts, Uwe liked this post
  10. #6
    Replacement radar unit(s) also need to be calibrated / aligned, requiring special equipment:
