Results 1 to 6 of 6
Thread: 2004 vw GTI AWP misfire after fueling PLEASE HELP
    Feb 2018
    Angry 2004 vw GTI AWP misfire after fueling PLEASE HELP
    hi guys,
    im new to the forums but i figured id give it a try since the community has helped so many others. my 04 gti (stage 2 tuned) was running great for three years until i got a timing and water pump replacement. after i got the car back i noticed that it would misfire on start up.
    i began checking the basics, (spark plugs, coilpacks, pcv ect...) i have done everything i can think of and that of my knowledge. i have taken the car to 3 different VW and Audi mechanics and continue to get the same response, BUT THEY ARE THINGS IV ALREADY REPLACED!!
    so here is the problem- when i remove the gas cap and refuel, i put the gas cap back and start the car, the car will misfire and if i leave it rough idling it will stall. if i give it gas the car will keep misfiring for 20 seconds or so and then go back to normal. it will run perfect until i need to refuel. it is only when i put gas. i have even left the car running and put my finger down the filler neck and when the flap in the filler neck goes up the car begins to rough idle.
    my latest discovery is that the car runs better with no gas cap. i believe its a vent issue but i pray someone can help me pinpoint my problem... please
    -Spark plugs are brand new and gapped to .28 (as needed for tune)
    -coil packs are upgraded red tops
    -pcv valve brand new
    -fuel filter brand new
    -gas cap brand new
    -no vacuum leak
    -injectors are clean and all ticking
    -throttle body is clean and wires to sensor redone (checked via vcds running to spec)
    i own vcds and have done output test and all type of scans and nothing comes up except for when i refuel and the car misfire ill get random cylinder misfire code and o2 from the car misfiring but no other codes again after i clear them. the car runs amazing, runs hard no issues other than the one presented above.
    hi guys,
    -Spark plugs are brand new and gapped to .28 (as needed for tune) <<<<<<<<< what type plugs, heat range and why is this for what tune?
    -coil packs are upgraded red tops <<<<<<<<<< Not an upgrade other than pretty color!
    -gas cap brand new
    -no vacuum leak <<<<<<<<<<<<<<<< How are you sure of this?
    -throttle body is clean and wires to sensor redone (checked via vcds running to spec) <<<<<<<<< redone how pictures of fine work?
    Hello OP and welcome to the VCDS Forum.
    That's a lot of paint thrown at the wall in addition to FOD tuning.
    Please post us an auto-scan to see the configuration of this AWP.
    What's the deal with the N80 and LDP circuit?
    Logs on misfire please?
    0x01-08-014/015/016
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    Do you have RTFB?
    JPPSG
  3. Likes thatMK4kidd liked this post
    Feb 2018
    hey bud thanks for your response.
    sorry i wrote it kind of quick because i am currently at work but i will happily post a auto scan for you soon as i get out of work.
    ty!
  5. Likes Jack@European_Parts liked this post
  6. #4
    Feb 2018
    04 gti auto scan
    here is the auto scan as requested
    Saturday,03,March,2018,04:04:41:13478
    VIN: 9BWDE61J044006821   License Plate:
    Mileage: 301550km-187374mi   Repair Order: 04 gti
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWDE61J044006821   Mileage: 301550km-187374miles
    Address 01: Engine        Labels: 06A-906-032-AWP.lbl
       Part No: 06A 906 032 HS
       Component: Stg2 R4/5VT     G   0006
       Coding: 07510
       Shop #: WSC 87119
       VCID: 76B51BAC61D477D7584-5184
       9BWKE61J834078775     VWZ7Z0C7152755
                P0300 - 35-10 -  - Intermittent
    16685 - Cylinder 1
                P0301 - 35-10 - Misfire Detected - Intermittent
    Readiness: 0010 0000
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0019970
       Shop #: WSC 00000 785 00200
       VCID: 3431E1A4322825C7A60-5184
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
       Part No: 1C0 909 605 F
       Component: 08 AIRBAG VW61 0202 0003
       Coding: 12344
       VCID: 270B06E8F6FE5E5F132-5160
    00592 - Seat Belt Switch; Passenger (E25)
                33-10 - Resistance Too Low - Intermittent
    01217 - Side Airbag Igniter; Driver Side (N199)
                32-00 - Resistance Too High
    01588 - Igniter for Head-Airbag; Drivers Side (N251)
                32-10 - Resistance Too High - Intermittent
       Part No: 1J0 920 907
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 00232
       Shop #: WSC 08203
       VCID: 66954BEC31748757E84-5160
       9BWDE61J044006821     VWZ7Z0C7636551
    01177 - Engine Control Unit
                64-10 - Not Currently Testable - Intermittent
    01304 - Radio
                49-00 - No Communications
       Part No: 6N0 909 901
       Coding: 00006
       VCID: 70B92DB403B059E7828-5160
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 8B Komfortgerát HLO 0003
       Coding: 00064
       VCID: 372BD6A8265ECEDF832-4B1E
       Component: 8B Tőrsteuer.FS KLO 0009
       Component: 8B Tőrsteuer.BF KLO 0009
    01131 - Control Circuit for Turn Signals
                25-10 - Unknown Switch Condition - Intermittent
    01358 - Internal Central Locking Switch; Driver Side (E150)
    End----------(Elapsed Time: 05:05, VBatt start/end: 12.3V/12.2V)-----------
    Now please clear DTC's in all modules and immediately before even starting the engine, rescan and post the new auto-scan.
    Thank you
    Feb 2018
    will do, i have my break coming up soon ill take another engine scan. appreciate your time and help
