Wednesday,28,February,2018,12:30:10:16477
VCDS Version: 18.1.0.2 (x64) HEX-NET CB: 0.4411.4
VIN: WAUZZZ8T1FA050745 License Plate:
Mileage: 19790km-12296mi Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 20 22 30 36 3C 42 44
46 47 52 53 56 5C 5F 62 6C 72 A9
VIN: WAUZZZ8T1FA050745 Mileage: 19790km-12296miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 8K2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0005
Revision: --H10---
Coding: 1A2500340447010B3800
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K2907551A 003001
ROD: EV_ECM30TFS0218K2907551_003.rod
VCID: B12A43A8E06987CD8A-80E4
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K0 927 166 HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H03 0004
Revision: --H03---
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: F2A88CA425EFFCD533-80A6
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 296DCE01
VCID: 895ACB4820799F0D62-80DC
Part No SW: 8K0 907 064 KF HW: 8K0 907 064 KF
Component: BCM2 2.0 H15 0711
Coding: 05B44040000000000000
VCID: FEB0A89469B7A8B547-80AA
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000021920011
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Component: KLIMA 3 ZONEN H04 0122
Revision: D1000000 Serial number: 01260220152196
Coding: 6624028080
VCID: F8BCBE8C4B9396850D-80AC
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00001012316901
Coding: 260000108074AFF2398140C300001D0D0F9DC30AA7090221000008004400070200020034000000
VCID: FAB8A484759F84957B-80AE
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 130215 H13 0080
Serial number: SWF15022135480
Coding: 00FD11
Component: G397_RLFS H06 0004
Serial number: 20149920
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002102150939
Subsystem 4 - Part No SW: 4G0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0030
Serial number: 0000000094CE01DE587E
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 0968C597000000000001
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 B HW: 8K0 907 561 B
Component: ACC3 H11 0100
Coding: 003352
VCID: B12A43A8E86987CD8A-80E4
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 C HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0054
Revision: 00000000 Serial number: 27011500720002
Coding: 070181
VCID: BA386484351F44953B-80EE
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC652TJ
Coding: 30543938363030303030554A305238543053
VCID: C8DC0E4C73F32605BD-809C
Serial number: 6334MSME4E592E74W
Serial number: 6344MSME4C3B4B47U
Serial number: 6352QSME60524574A
Serial number: 6362QSME69524868Q
Serial number: 63732SME4C52435A1
Serial number: 63832SME7C520644/
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372OBR0004C
Coding: 0000FE
VCID: C4C41A7C47DB026551-8090
Component: E221 - MFL H03 0004
Part No SW: 8T0 920 984 D HW: 8T0 920 984 D
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 5U-34GX1G
Coding: 33EF3100FF012600010000
Shop #: WSC 06325 123 12345
VCID: C0CC166C53C31E4575-8094
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z152230201
Coding: 80CF07FF00
VCID: CCD4325C6F8BCA2599-8098
Serial number: 8761475703
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 15050000159011200410
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 040100
VCID: B93A7B8830194F8D32-80EC
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02029864747464545425363E00
VCID: FCB4A29C7FABBAA569-80A8
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 002201150001008
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
VCID: AF2E45D0F65D913D9C-80FA
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000120087
Coding: 01010101000000000001000102
VCID: AD125FD8F451E32DAE-80F8
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0077
Revision: AA000000 Serial number: 00000135130040
Coding: 01781B00000000000000
VCID: BB3661803A257D9D20-80EE
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0360483383
Coding: 010312
Shop #: WSC 06324 000 00000
VCID: BFCE1590263D61BD0C-80EA
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0361034602
Coding: 010312
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011C12625E21450005
VCID: D6E0D034A14780F53F-8082
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 J HW: 8K0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0031154924
Coding: 010001010001
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: B83C7E8C03135685CD-80EC
Revision: 00002001 Serial number: 0361279341
Coding: 013F0E22A0B948818330043680000047
Shop #: WSC 06324 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000953878
Subsystem 2 - Part No: 8K0 951 177
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813040965506
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
Coding: 011C12225E21450005
VCID: D5E2D738BC418BED36-8080
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001624494
ROD: EV_ParkiBrake_AU48.rod
VCID: BA3864843D1F44953B-80EE
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109BP0F8018050
Coding: 010103010000000001
VCID: AB1651C0CA45ED1DB0-80FE
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600215226000E7
Coding: 0033205
VCID: B73E7DB0C60D59FDC4-80E2
Part No SW: 8R2 035 670 J HW: 8R2 035 670 J
Component: H-BNT-EU H49 0897
Revision: -------- Serial number: 517BX0F7501572
Coding: 140101040206A9EF7D82CB5E00000403040000000000000000
Subsystem 1 - Part No: 8R0 060 884 CH
Component: EUR 2014 2004
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130BW0F3275846
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000002151211
Component: CD-Database 5950
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010C12224021450005
VCID: D9FADB08D059AF8D12-808C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J4Z92OK
Coding: 1021006
VCID: B83C7E8CCB135685CD-80EC
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H08 0305
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0006
Serial number: 150207200574
End----------(Elapsed Time: 02:18, VBatt start/end: 14.7V/14.6V)-----------
