VCDS mobile: Engine readiness
Dippy
C?ID=10790
I usually use VCDS PC, but I wanted to check my engine readiness quickly so I have tried using VCDS mobile. I selected the engine module and then registered on VCDS cloud, but I still couldn't find how to read the readiness bits. On VCDS PC it is 01-engine/15-readiness. Can anyone advise how I can see it in VCDS mobile?
Santos
You should be able to check the bits using the advanced measuring block data. Can you post an autoscan from the car?
Dippy
C?ID=10790
Wednesday,28,February,2018,12:30:10:16477
VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WAUZZZ8T1FA050745   License Plate:
Mileage: 19790km-12296mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 20 22 30 36 3C 42 44
          46 47 52 53 56 5C 5F 62 6C 72 A9
VIN: WAUZZZ8T1FA050745   Mileage: 19790km-12296miles
Address 01: Engine (J623-CREC)       Labels: None
   Part No SW: 8K2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---
   Coding: 1A2500340447010B3800
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K2907551A 003001
   ROD: EV_ECM30TFS0218K2907551_003.rod
   VCID: B12A43A8E06987CD8A-80E4
Readiness: 0010 0001
   Part No SW: 8K0 927 166     HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0004
   Revision: --H03---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: F2A88CA425EFFCD533-80A6
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Coding: 296DCE01
   VCID: 895ACB4820799F0D62-80DC
   Part No SW: 8K0 907 064 KF    HW: 8K0 907 064 KF
   Component: BCM2 2.0      H15 0711
   Coding: 05B44040000000000000
   VCID: FEB0A89469B7A8B547-80AA
   Serial number: 3215000021920011
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01260220152196
   Coding: 6624028080
   VCID: F8BCBE8C4B9396850D-80AC
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001012316901
   Coding: 260000108074AFF2398140C300001D0D0F9DC30AA7090221000008004400070200020034000000
   VCID: FAB8A484759F84957B-80AE
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 130215  H13 0080
   Serial number: SWF15022135480
   Coding: 00FD11
   Serial number: 20149920
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002102150939
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Serial number: 0000000094CE01DE587E
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 0968C597000000000001
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H11 0100
   Coding: 003352
   VCID: B12A43A8E86987CD8A-80E4
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 27011500720002
   Coding: 070181
   VCID: BA386484351F44953B-80EE
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC652TJ
   Coding: 30543938363030303030554A305238543053
   VCID: C8DC0E4C73F32605BD-809C
   Serial number: 6334MSME4E592E74W
   Serial number: 6344MSME4C3B4B47U
   Serial number: 6352QSME60524574A
   Serial number: 6362QSME69524868Q
   Serial number: 63732SME4C52435A1
   Serial number: 63832SME7C520644/
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372OBR0004C
   Coding: 0000FE
   VCID: C4C41A7C47DB026551-8090
   Part No SW: 8T0 920 984 D    HW: 8T0 920 984 D
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5U-34GX1G
   Coding: 33EF3100FF012600010000
   Shop #: WSC 06325 123 12345
   VCID: C0CC166C53C31E4575-8094
   Revision: 1Z120030    Serial number: 3041Z152230201
   Coding: 80CF07FF00
   VCID: CCD4325C6F8BCA2599-8098
   Serial number: 8761475703
   Serial number: 15050000159011200410
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Coding: 040100
   VCID: B93A7B8830194F8D32-80EC
   Revision: AA001002
   Coding: 02029864747464545425363E00
   VCID: FCB4A29C7FABBAA569-80A8
   Component: 4 Wheel Drive H15 0100
   Serial number: 002201150001008
   VCID: AF2E45D0F65D913D9C-80FA
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000120087
   VCID: AD125FD8F451E32DAE-80F8
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000135130040
   Coding: 01781B00000000000000
   VCID: BB3661803A257D9D20-80EE
   Serial number: 0360483383
   Coding: 010312
   Shop #: WSC 06324 000 00000
   VCID: BFCE1590263D61BD0C-80EA
   Component: SWA Slave  H05 0071
   Serial number: 0361034602
   Coding: 010312
   Component: TSG FA        H10 0305
   Coding: 011C12625E21450005
   VCID: D6E0D034A14780F53F-8082
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0031154924
   Coding: 010001010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: B83C7E8C03135685CD-80EC
   Revision: 00002001    Serial number: 0361279341
   Coding: 013F0E22A0B948818330043680000047
   Shop #: WSC 06324 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000953878
   Subsystem 2 - Part No: 8K0 951 177
   Revision: 00005001    Serial number: 94813040965506
   Component: TSG BF        H10 0305
   Coding: 011C12225E21450005
   VCID: D5E2D738BC418BED36-8080
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001624494
   ROD: EV_ParkiBrake_AU48.rod
   VCID: BA3864843D1F44953B-80EE
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109BP0F8018050
   Coding: 010103010000000001
   VCID: AB1651C0CA45ED1DB0-80FE
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600215226000E7
   Coding: 0033205
   VCID: B73E7DB0C60D59FDC4-80E2
   Part No SW: 8R2 035 670 J    HW: 8R2 035 670 J
   Component: H-BNT-EU      H49 0897
   Revision: --------    Serial number: 517BX0F7501572
   Coding: 140101040206A9EF7D82CB5E00000403040000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130BW0F3275846
   Serial number: 00000002151211
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C12224021450005
   VCID: D9FADB08D059AF8D12-808C
   Revision: --H09---    Serial number: 525PA8-J4Z92OK
   Coding: 1021006
   VCID: B83C7E8CCB135685CD-80EC
   Component: TSG HR        H08 0305
   Component: SAS-GEN 2     H06 0006
   Serial number: 150207200574
End----------(Elapsed Time: 02:18, VBatt start/end: 14.7V/14.6V)-----------
Dippy
C?ID=10790
Any further advice on this?
Try ENG102831 - "Ready bits (completed tests)"
If that doesn't give you what you're looking for, there are some (8, I think) "Status of intermittent monitoring" values that should cover it.
