My car has thrown a code the vcds doesnt know, and my vsds will not clear. As soon as i clear it, its right back. Any help will be greatly appreciated.... my car is a 2013 jetta tdi and the code having problems with is P2BA6.... Thank you
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VW3L7AJ2DM279911 Mileage: 199980km-124261miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 N HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H15--- Serial number:
Coding: 0050072
Shop #: WSC 57360 002 1048576
011174 - Unknown Error Code
P2BA6 - 000 -
Mileage: 199988 km
Date: 2018.02.25
Time: 00:15:15
RPM: 828 /min
(no units): 984.0
Temperature: 9.0°C
Mass Air / Rev.: 260.0 mg/str
Temperature: 36.0°C
Readiness: 0 0 0 1 X
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492900038D1402E5921A0042A71000
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BA HW: 5C0 820 047 BA
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001441446
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 086 E HW: 5C0 937 086 A
Component: BCM25 JLB M3 H67 0257
Revision: B0067001 Serial number: 04351049130454
Coding: 7B994B1808230F0000382000240884C50082502E60000000300000000000
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3465
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3465
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0050286 FLE 20130122
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Part No SW: 5C0 959 655 Q HW: 5C0 959 655 Q
Component: AirbagVW10G 013 0851
Serial number: 003LKM03LJ3Q
Coding: 00004A33
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 40D9BDB0FA08AE87328-8014
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y130000RLDN0C
Coding: 303036
Serial number: 3572MSME15182177ZZZP
Serial number: 3582MSME2E112377ZZZV
Serial number: 3516KSME7F280922ZZZY
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME5A530822ZZZP
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME21060A20ZZZF
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME28581A20ZZZV
Part No SW: 5C6 920 952 A HW: 5C6 920 952 A
Component: KOMBI H06 0705
Coding: 270A01
Shop #: WSC 00066 000 00119
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2A0DFF186C7444D70CC-807E
Part No SW: 6N0 909 901 HW: 5C0 937 086 A
Component: GW-K-CAN TP20 H67 0257
Revision: B0067001
Coding: 102200
Component: IMMO H06 0705
VCID: 6A8D3F18ACF484D7CCC-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664106584
Coding: 010100
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
Component: LOW NAR SDARS H03 0005
Revision: -----07S Serial number: VWZ4Z6N3521582
Coding: 01000400020006
Reset counter: 190
Mileage: 199988 km
Date: 2018.02.25
Time: 00:09:35
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664098407
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ROD: EV_UHVNA_002.rod
VCID: 3A2DCF589CD4F4577CC-806E
End----------(Elapsed Time: 01:09, VBatt start/end: 14.1V/14.0V)-----------
Controller Software Versions:
ECU 1 = Engine 9983
ECU 2 = ABS Brakes 0152
ECU 3 = Auto HVAC 0204
ECU 4 = Cent. Elect. 0257
Sub ECU 4 > 1 = Cent. Elect. 3465
Sub ECU 4 > 2 = Cent. Elect. 3465
Sub ECU 4 > 3 = Cent. Elect. 0037
Sub ECU 4 > 4 = Cent. Elect. 3464
Sub ECU 4 > 5 = Cent. Elect. 3464
ECU 5 = Airbags 0851
Sub ECU 5 > 1 = Airbags 0046
Sub ECU 5 > 2 = Airbags ----
Sub ECU 5 > 3 = Airbags ----
Sub ECU 5 > 4 = Airbags ----
Sub ECU 5 > 5 = Airbags ----
Sub ECU 5 > 6 = Airbags ----
Sub ECU 5 > 7 = Airbags ----
ECU 6 = Instruments 0705
ECU 7 = CAN Gateway 0257
ECU 8 = Immobilizer 0705
ECU 9 = Media Player 3 0550
ECU 10 = Steering Assist 330
ECU 11 = Radio 0005
Excellent question! With the MIL on, one would think it almost has to be, no?OP:
Is the code also displayed in OBD2 mode?
