Results 1 to 3 of 3
Thread: Steering angle sensor recalibration: 2006 Touareg
    Aug 2014
    Texas
    I have been chasing a few gremlins. Turns out one was a module...the others now look to be a possible wiring harness issue (ugh). I had to disconnect the batteries on the Touareg to R&R the modules and now that I have reconnected the batteries.
    I've seen some procedures for other VAG cars on calibrating the steering angle sensor. Which the code 0778 is throwing off the ABS and level control.
    Questions:
    1) Are the procedures to calibrate the SAS (G85) the same for all/most VAG car's in my year model?
    2) Batteries are OEM (8+yrs old) but still hold a charge. Should I R&R both batteries as preventive maintenance? (I've had to tear out half the interior already just to get to them)
    Here is the scan.
    Thursday,25,September,2014,20:35:56:14552
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140822
    VIN: WVGPT77L06D054863   License Plate:
    Mileage: 208870km-129785mi   Repair Order:
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGPT77L06D054863   Mileage: 208870km/129785miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG000AGMª8472
       Revision: --H02---    Serial number: VWZ3Z0E6402710
       Coding: 0060575
       Shop #: WSC 31414 000 00000
       VCID: 61C95F86BB717216F43-5140
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H51000    Serial number:
       Coding: 0000008
       VCID: 7F0DF9FE2DC5A4E6E27-5140
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D71C3F6674976F6B0B-5140
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137     HW: 5WK 484 92
       Component: G2 Kessy            6700
       Revision: 67005614    Serial number: VWZ3Z0E6402710
       Coding: 0131304
       VCID: F0EFAAC2E09B4B9EEBD-515E
    00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: F7FD91DE85F51CA62A7-515E
    Address 08: Auto HVAC        Labels: 7L6-907-044.clb
       Part No: 7L6 907 044 T
       Component: CLIMAtronic 2+2     4222
       Coding: 0020030
       VCID: 4581AB160F993E36E8B-5140
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    8 Faults Found:
    02379 - Positioning Motor for Left Side Vent (V299)
    02599 - Rear Left Temperature Flap Motor (V313)
    02597 - Rear Left Upper Body Vent Motor (V315)
    00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
    00362 - Rear Left Air Flap Motor (V239)
    02600 - Rear Right Temperature Flap Motor (V314)
    02598 - Rear Right Upper Body Vent Motor (V316)
    00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3001
       Coding: 0111836
       VCID: 479DA11E35952C261A7-515E
    00070 - Starting Battery Voltage
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG000AGSª8472
       Coding: 0060575
    005784 - Please Check DTC Memory of Steering Wheel Electronics
                   P1698 - 000 -  - Intermittent
                        Mileage: 208878 km
                        Date: 2064.00.00
                        Time: 00:00:00
                        RPM: 672 /min
                        Voltage: 11.55 V
                        Bin. Bits: 00001011
                        Bin. Bits: 00000000
                        (no units): 0.0
    005782 - Powertrain Data Bus
                   P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
                        Mileage: 208878 km
                        Date: 2064.00.00
                        Time: 00:00:00
                        RPM: 672 /min
                        Voltage: 11.55 V
                        Bin. Bits: 00001011
                        Bin. Bits: 00000000
                        (no units): 0.0
       Part No: 3D0 909 601 H
       Component: 05 Airbag 8.4E++H02 0562
       Revision: BB38727     Serial number: 0010170?
       Coding: 0012341
       Shop #: WSC 25053 444 59338
       VCID: 285F02A298CBC35EF3D-515E
       Subsystem 1 - Part No: 7L0 959 339 E
       Component: BF-Gewichtsens. 007 0009
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010032
       VCID: 4487B61204A3073EFF5-515E
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0005231
       VCID: 489FA222388B235E13D-5140
    02053 - Control Module for Transfer Case (J646)
    01517 - Control Module for Trailer/Towing Sensor (J345)
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 815 071 D
       Component: Standheizung E1MAC
       Coding: 0000100
       VCID: 3365E5CE510DB08656F-5140
    02251 - Heater Unit Locked
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: F0EFAAC2E09B4B9EEBD-5140
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       VCID: 4581AB160F993E36E8B-515E
       Part No: 0AD 927 755 BG
       Component: TRANSFERCASE        0126
       VCID: 8109FF06DB315216143-515E
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       Coding: 0000003
       VCID: E6C3CC9AD25F952E811-5140
    00492 - Body Pitch Angle from Level Control Module
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       VCID: 3663DCDA427FA5AE711-5140
    01776 - Control Head for Vehicle Leveling System (E281)
    02332 - Position Sensor for Backrest Adjustment (G440)
    01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
    01915 - Lumbar Support Height Adjustment Sensor (G374)
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50AF8A42C0DBEB9E4BD-5140
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: E7DDC19ED5558C26BA7-515E
       Part No: 7L0 959 933 J
       Component:    HSG              5115
       Coding: 0000085
       VCID: 4385B50E01AD0006C6F-4B1A
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014472
       VCID: 3561DBD65F79AEB678B-515E
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C77CEF27C537FFE875-515E
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
       Component: J345  Anhaenger     0080
       Revision: 4A009001    Serial number: 00000193524428
       Coding: 0016385
       VCID: 3F8DB9FE6D4564E6A27-5140
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J670048
       Coding: 0000101
       Shop #: WSC 25053 444 85538
       VCID: F2EBA0CAEE97798E1D9-5140
    03006 - Back-up Camera System not calibrated
                        Reset counter: 118
                            Invalid
                            Invalid
                            Invalid
    03008 - Supply Voltage for Back-Up Camera
                        Fault Frequency: 62
                        Reset counter: 50
                            Reverse OFF
                        Count: 3
    02203 - Audio / Video Input 1
                        Fault Status: 00101011
                        Reset counter: 22
                            Reverse OFF
                        Count: 3
                        Reset counter: 22
                            Reverse OFF
                        Count: 3
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 10
                            Reverse OFF
                        Count: 3
    Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
       Part No: 7L6 919 044 T
       Component: DACHDISPLAY         0539
       Revision: 00900539    Serial number: 2009289.07
       VCID: 489FA222388B235E13D-515E
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 3979D7E673614AD69C3-5140
    Last edited by Uwe; 09-26-2014 at 11:06 AM. Reason: Wrapped CODE tags around Auto-Scan
    1) See:
    http://wiki.ross-tech.com/wiki/index...ke_Electronics
    2) If it were me, I'd replace 'em. I've done both our 2005/2006 model cars within the last year. Batteries weren't dead, but who wants to deal with one that goes dead in the middle of winter? I figured those batteries no longer owed me anything.
    Aug 2014
    Texas
    1) my response...DOH! (I looked and looked but...I really need to upgrade my fuzzy search logic algorithm)
    2) My thoughts...too, besides as you know Uwe, getting to these in the T-reg isn't just a pop the hood R&R
    Thanks Uwe as always.
