Morning all, This is a project I acquired, and IMO does not need a Auto scan, could be wrong.
2001 TDI beetle. Lack of heat from dash or foot well. My first thought was Thermostat, so replace it (refilled with up lift tool) and these little guys are hard to warm up as stick shift with glow system.
That said when on the road partially covered radiator for testing I have 195 F, and OK heat, but not dynamic. Then I notice small chunks of foam rubber stuck in the vents. Did a little research and noted both lines into Heater core from fire wall are hot. So it is plugged or not able to transfer heat I.E. plugged by FOD, something stuck on face of core or someplace else, just my dumb opinion.
Read some threads and seems the foam rubber decays and gets displaced. My thinking is that it will be an RR just like leaking HC but looking for some easier fix but assume it will be partial or all removal of dash.
Larimore.
Larimore.
