- Jun 10, 2014
- 1,250
- 850
- Poland
- C?ID=159607
Can you describe your process for the swap?
I have a 2017 Sportwagen, I have a GTI 3D MFA Cluster I want to swap in. I cant find much if any info, on Component protection, the swap process its self, nothing.
Any guidance will be GREATLY appreciated
Tuesday,23,October,2018,17:30:06:40674
Dealer/Shop Name: Retrofitters Kzn
VIN: WVWZZZAUZEW154658 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 20 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW154658 Mileage: 172506km-107190miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0007
Revision: --H13---
Coding: 091D00324424050B3000
ASAM Dataset: EV_ECM20TFS0215G0906259 001011
ROD: EV_ECM20TFS0215G0906259_VW37.rod
VCID: 6B823067E30C1E7F5B7-803E
17178 - Databus
Mileage: 172506 km
Date: 2018.10.23
Time: 00:04:32
Coolant temperature: 110 °C
Intake air temperature: 57 °C
Ambient air pressure: 840 mbar
Voltage terminal 30: 12.324 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 1010 0001
Part No SW: 0D9 300 040 L HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4025
Revision: 05652104 Serial number: TFK01309201983
ROD: EV_TCMDQ250021.rod
VCID: 2018174B5A4A0D27BE5-8074
P1734 00 [002] - -
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6264300000053C
Coding: 01FA93A134252970037D0605C1CBA980C92C94C0608395F7004250BAC109
Shop #: WSC 47649 001 1048576
VCID: 7BA20027936C8EFFCB7-802E
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 70
Date: 2018.10.23
Time: 00:04:33
Revision: 00021000 Serial number: 0194515140
Coding: 030C0C
VCID: 3A2CC523DCD677F7901-806E
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120014200100001005000012101800
VCID: 66944153F8EE2317049-8032
Air quality sensor:
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011328201012
Coding: 03111B46C24122FB0BA44080B10C0728180A000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77AA1C17AF44AA9FAFF-8022
Component: WWS 130915 042 0551
Serial number: 130926083906
Component: RLFS 024 0042
Serial number: Y13M10D09H08M13S21S1
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1324116QY
Serial number: 00000000000027889966
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO24389415
Coding: 181801
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Revision: -------- Serial number: 61131325501051
Coding: 0131061051
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 3D26CE3FCDF840CFB53-8068
13637426 - Databus
Reset counter: 110
Mileage: 172506 km
Date: 2018.10.23
Time: 00:04:32
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 09091341356708
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76B41113A84ED397B49-8022
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R01908Q
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 41DEB2CFB100242FD1B-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 909 13
Serial number: 357670000003C649CD01
Subsystem 2 - Part No SW: ----------- HW: 480 001 909 13
Serial number: 3586700000002A2CFD0/
Subsystem 3 - Part No SW: ----------- HW: 480 400 910 13
Serial number: 3516502B71171FE170FG
Subsystem 4 - Part No SW: ----------- HW: 480 400 910 13
Serial number: 3526502C51171FE51087
Subsystem 5 - Part No SW: ----------- HW: 480 400 110 13
Serial number: 3556502BD1171FE2B20I
Part No SW: 5Q0 953 507 BK HW: 5Q0 953 549
Revision: -------- Serial number: 04101304220218
Coding: 0400
VCID: 005877CBFA8AED279E5-8054
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 314 2210
Coding: 27AD09183B90000800082A00040000
VCID: 6C80337BE602194752D-8038
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001103306
Coding: 030100042B085900EF00026A9C0F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 3B22C027D3EC4EFF8B7-806E
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001506550063384
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2093481403
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02028864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B02F067238CDE7F1B7-807E
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000219904002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73B22807BB3CC6BF937-8026
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 21091304080223
Coding: 003E12208001040000001000
VCID: 3FDAB437C7F452DFA7F-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002842756
Coding: 0D0000
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 8301
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: 3332E807FBBC86BF537-8066
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 07101303110325
Coding: 003E10208E01040000801000
VCID: 3E24C933C0FE5BD7AC9-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002880350
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029603000B000200
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 040 0421
Serial number: V1C00610131815
Coding: 02730000FF00000011110001000900001F0203860100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 270A0C573F64FA1FFFF-8072
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H51 0022
Serial number: VWZ8Z9NJ7021US
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0011
Serial number: 130918202216
End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.4V)-----------
what you try to code ?Howzit
Gents
Chris here from Retrofitters . I'm battling to get the key to read the Car . the car is a 2014 mk7 gti with kessy .
retrofitted the virtual cluster but cant get the car on to code it in .
and idea why?
do full exchange via ODIS and ODIS will do all what is need to do
is there no way you can read forum history ?is there no way do this this with Vcds and How do i go about the kessy issue
is too hard to use search button ? not many people who did that retrofit, but every single person use one, and ONLY one solution = ODIS
sorry man .
i see everyone is fitting them and we tried this yesterday . could not get ignition on , when we fitted to stock clusters in the brakes module was deleted this was very odd, hence i asked has anyone done this with Kessy , looking for answers i can find
no matter kessy or no kessy
IMMO is always IMMO.
If you do retrofiting, you know that not all retrofits can be do easy
and keep backup / coding is a first what every retrofitig guy shoud do
Chrisfz, try holding the key against the side of the steering column when you start matching the new components with ODIS.
Address 17,5G1 920 791 A,channel IDE02489-Display depiction,adapted from,Version 1 ,to,Version 2 ,
Address 17,5G1 920 791 A,recoded (Long Coding),from,0BA50A002980880A02887A011000000000000000,to,0BA552002980880A02887A011400000000000000,(05065/002/104857),
Address 17,5G1 920 791 A,channel ENG153766-Tube_version,adapted from,variant_0 ,to,variant_2 ,
Address 17,5G1 920 791 A,channel ENG153766-Tube_version,adapted from,variant_2 ,to,variant_0 ,
Address 17,5G1 920 791 A,channel ENG153766-Tube_version,adapted from,variant_0 ,to,variant_1 ,
Address 17,5G1 920 791 A,channel ENG153766-Tube_version,adapted from,variant_1 ,to,variant_2 ,
Address 17,5G1 920 791 A,channel ENG153766-Tube_version,adapted from,variant_1 ,to,variant_3 ,
Address 17,5G1 920 791 A,channel ENG153766-Tube_version,adapted from,variant_3 ,to,variant_2 ,
Address 5F,3G0 035 047 B,channel ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,adapted from,OFF ,to,On ,
Address 5F,3G0 035 047 B,channel ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,adapted from,OFF ,to,On ,
Address 5F,3G0 035 047 B,channel ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,adapted from,On ,to,On ,
Address 5F,3G0 035 047 B,channel ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,adapted from,RLE ,to,H264 ,
Address 5F,3G0 035 047 B,channel ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,adapted from,OFF ,to,MOST_streaming ,
