Results 1 to 1 of 1
Thread: Golf mk6 GTI transmission overtemperature and engine over revving in sports mode
    Jul 2017
    Kenya
    Hello guys,below is an enclosed autoscan of an mk6 gti whose dash screams about overheating tranny frequently,but no fault code is logged in ecu memory,I think this might be a common issue with 02E,but someone can chime in,however the engine revolutions at times go past 6000rpm before shifting to the next gear in sports mode which makes me to believe that the car is chipped,is there anyway to tell
    Wednesday,14,February,2018,15:52:57:48669
    VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
    Dealer/Shop Name: FREDRICK'S VWAUDI
    VIN: WVWZZZ1KZAW203452   License Plate:
    Mileage: 123010km-76434mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 02 03 08 09 14 15 16 17 19 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZAW203452   Mileage: 123010km-76434miles
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0050
       Revision: AAH11---    Serial number:
       Coding: 0403000C1C070160
       Shop #: WSC 59398 768 16576
       VCID: 6788B271B36635EFC9F-8032
    001056 - Catalyst System; Bank 1
                   P0420 - 000 - Efficiency Below Threshold
                        Mileage: 122818 km
                        Date: 2012.07.04
                        Time: 23:01:45
                        RPM: 1885 /min
                        Load: 34.1 %
                        Speed: 64.0 km/h
                        Temperature: 96.0°C
                        Temperature: 33.0°C
                        Absolute Pres.: 810.0 mbar
                        Voltage: 13.208 V
    001089 - EVAP Emission Control Sys
                   P0441 - 000 - Incorrect Flow
                        Mileage: 122996 km
                        Date: 2012.07.07
                        Time: 09:06:22
                        RPM: 760 /min
                        Load: 25.5 %
                        Temperature: 102.0°C
                        Temperature: 45.0°C
                        Absolute Pres.: 820.0 mbar
                        Voltage: 13.208 V
    Readiness: 0010 0001
       Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1932
       Revision: 04844002    Serial number: 00000910231125
       VCID: 221EE36518C410C75E1-8076
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 133B600D092200FDC80F06E9901B0081350800
       VCID: 7AAEFB05DCD4B807261-802E
    02781 - ASR/ESP Button (E256)
                        Reset counter: 191
                        Mileage: 121931 km
                        Date: 2012.06.26
                        Time: 10:05:56
                        Count: 16384
                        Count: 32768
                        Count: 12800
                        Count: 156
                        Count: 46849
                        Count: 64768
                        Count: 768
                        Fault Status: 00101101
                        Reset counter: 203
                        Mileage: 122337 km
                        Date: 2012.06.30
                        Time: 08:44:52
                        Count: 4608
                        Count: 8193
                        Count: 50224
                        Count: 518
       Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
       Component: Climatronic   H14 0608
       Revision: 00003001
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 6D84C0599D1A1FBFB33-8038
    13701536 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 120984 km
                        Date: 2018.01.22
                        Time: 17:21:25
       Part No SW: 1K0 937 087 F    HW: 1K0 937 087 F
       Component: BCM PQ35  H   103 0573
       Revision: 00103 AF
       Coding: 4E180A7C48231AC0C408008015008B2447550288736D8960648000200000
       VCID: 3432153DBE308E77BCD-8060
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 13100  21  0512
       Coding: 009795
       Component: RLS 291009 05  54  0402
       Coding: 0B30AD
                        Reset counter: 121
                        Mileage: 120984 km
                        Date: 2012.06.14
                        Time: 17:22:34
                        Voltage: 13.60 V
                            Term 50 Off
       Component: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serial number: 28100900210002
       Coding: 000180
       VCID: 2708F2717FE6F5EF09F-8072
       Part No SW: 5K0 959 655 A    HW: 5K0 959 655 A
       Component: AirbagVW10G   035 0604
       Serial number: 003C3D0DCM80
       Coding: 00003233
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 382A210DA2D86A17905-806C
       Serial number: 7309464CZZZZZZZZZZZZ
       Serial number: 7824524CZZZZZZZZZZZZ
       Serial number: 2C2B4219ZZZZZZZZZZZZ
       Serial number: 0A0C3923ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Component: J0527           056 0111
       Coding: 0001632
       VCID: 76B6EF35E4CCDC67429-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 5K6 920 870 D    HW: 5K6 920 870 D
       Component: KOMBI         H03 0305
       Coding: 570F00
       VCID: 3432153DBEB08E77BCD-8060
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0111
       Revision:   H07 01    Serial number: 221009F1000109
       Coding: ED897F06000202000003
       VCID: 698CB449A572039FDFB-803C
                        Reset counter: 121
                        Mileage: 120984 km
                        Date: 2012.06.14
                        Time: 17:23:44
                        Reset counter: 201
                        Mileage: 120984 km
                        Date: 2012.06.14
                        Time: 17:23:45
       Component: IMMO          H03 0305
       VCID: 6A8ECB45ACF40887D61-803E
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2114
       Coding: 0004790
       VCID: 323E132548248047AE1-8066
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 184    3001
       Revision: 00H17000
       VCID: 313C1C294D22BB5FD7B-8064
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Component: Tuer-SG         009 2140
       Coding: 0005046
       VCID: 35342839B94A977F8B3-8060
       Component: AFS-Steuergeraet    0142
       Coding: 1445212
       VCID: 3432153DB2308E77BCD-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Coding: 00000022
       Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
       Component: MIB2-S-R-CN   025 0210
       Revision: -----001    Serial number: 01475GD2320936
       Coding: 0000040004000A
       Shop #: WSC 00081 790 00128
       VCID: 45D458F9E5AA07FF1B3-8010
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 201
                        Mileage: 122355 km
                        Date: 2012.06.30
                        Time: 16:27:45
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
    Address 72: Door, Rear Right
    End----------(Elapsed Time: 01:04, VBatt start/end: 13.3V/13.2V)-----------
