- May 16, 2014
- 5,469
- 5,935
- Melbourne, Australia
- C?ID=194404
Friday,16,February,2018,09:55:08:16808
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4407.4
VIN: WVWZZZAUZJW018852 License Plate: 2016 LOANER
Mileage: 199km-123mi Repair Order: mk7
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZJW018852 Mileage: 199km-123miles
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H26 3742
Revision: R7H26---
Coding: 0125001224241D082000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D920CDCBCD0562E51-8038
CAN Converter 01:
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 300 041 B HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1006
Revision: 00005026 Serial number: CU501705226077
ROD: EV_TCMDQ200021_VW26.rod
VCID: 3424D9B89F7AC7E65E-8060
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 91247000001399
Coding: 01FA8AA124212174477F060540C52980512484E26002947310225038C202430000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 78BC2D88C392E386B2-802C
Part No SW: 5G0 907 426 AQ HW: 5G0 907 426 AQ
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 00120004200100001000000000000002
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 7AB83780FD9EF196C4-802E
Part No SW: 5Q0 937 084 CM HW: 5Q0 937 084 CD
Component: BCM MQBAB B H36 0253
Serial number: 01001715001288
ROD: EV_BCMBOSCH_018.rod
VCID: 0542547C84608E6EB9-8050
Component: WWS 170509 042 0551
Serial number: 170523013416
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 3300600111FFC428949C810500300600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416.rod
VCID: 3E30FB90A1361DB6B8-806A
Part No SW: 5Q0 959 655 BH HW: 5Q0 959 655 BH
Component: AirbagVW21 005 0336
Serial number: 003VVR31KD99
Coding: 98CCC000000000005C000000008800000065
VCID: 075E5E74BE6C9C7ECB-8052
Subsystem 1 - Part No SW: ----------- HW: 480 001 006 17
Serial number: 357000000007996D452R
Subsystem 2 - Part No SW: ----------- HW: 480 000 906 17
Serial number: 35800000000FBC40A42V
Subsystem 3 - Part No SW: ----------- HW: 480 400 606 17
Serial number: 3510001BB25975E51655
Subsystem 4 - Part No SW: ----------- HW: 480 400 606 17
Serial number: 35200019D25DA8B3462B
Subsystem 5 - Part No SW: ----------- HW: 480 400 806 17
Component: FrontSensor_D 000 6149
Serial number: 3550001B725DA8B4F23J
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 06061708490139
Coding: 0410
VCID: 02484F60954EB9569C-8056
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 740 C HW: 5G1 920 740 C
Component: KOMBI 202 0310
Coding: 27A429082380000801882A011400000000000000
VCID: 260033F059A6A576D0-8072
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 26051710802489
Coding: 030100347F085700FA0000481C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 3326DAA49A74C0DE47-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 46170001166220087197
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 4375244104
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 110517EEB27011
Coding: 003003208001040000001000
VCID: 41CA806CD0C8624EC5-8014
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 005 0007
Serial number: 00000000000015062261
Coding: 0D0000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 0107
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 45C2947CC4E04E6EF9-8010
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 040517EE41280A
Coding: 003001208001040000801000
VCID: 40CC8568DBC26B46CA-8014
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 005 0007
Serial number: 00000000000015030695
Coding: 150000
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER 721 0842
Coding: 02731000FF00000051510001000808001F0500D60120010003
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2D12CCDC7C50962E11-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT1620024
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
Admaps HERE
