Gof mk7.5 - base model
DV52
C?ID=194404
Friday,16,February,2018,09:55:08:16808
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4407.4
VIN: WVWZZZAUZJW018852   License Plate: 2016 LOANER
Mileage: 199km-123mi   Repair Order: mk7
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZJW018852   Mileage: 199km-123miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 0125001224241D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D920CDCBCD0562E51-8038
   CAN Converter 01:
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1006
   Revision: 00005026    Serial number: CU501705226077
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3424D9B89F7AC7E65E-8060
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 91247000001399
   Coding: 01FA8AA124212174477F060540C52980512484E26002947310225038C202430000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 78BC2D88C392E386B2-802C
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120004200100001000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 7AB83780FD9EF196C4-802E
   Part No SW: 5Q0 937 084 CM    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H36 0253
   Serial number: 01001715001288
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0542547C84608E6EB9-8050
   Component: WWS    170509  042 0551
   Serial number:         170523013416
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300600111FFC428949C810500300600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416.rod
   VCID: 3E30FB90A1361DB6B8-806A
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Serial number: 003VVR31KD99
   Coding: 98CCC000000000005C000000008800000065
   VCID: 075E5E74BE6C9C7ECB-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 001 006 17
   Serial number: 357000000007996D452R
   Subsystem 2 - Part No SW: -----------    HW: 480 000 906 17
   Serial number: 35800000000FBC40A42V
   Subsystem 3 - Part No SW: -----------    HW: 480 400 606 17
   Serial number: 3510001BB25975E51655
   Subsystem 4 - Part No SW: -----------    HW: 480 400 606 17
   Serial number: 35200019D25DA8B3462B
   Subsystem 5 - Part No SW: -----------    HW: 480 400 806 17
   Serial number: 3550001B725DA8B4F23J
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 06061708490139
   Coding: 0410
   VCID: 02484F60954EB9569C-8056
   Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
   Component: KOMBI         202 0310
   Coding: 27A429082380000801882A011400000000000000
   VCID: 260033F059A6A576D0-8072
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 26051710802489
   Coding: 030100347F085700FA0000481C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3326DAA49A74C0DE47-8066
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 46170001166220087197
   Coding: 28FFFF
   Serial number: 4375244104
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 110517EEB27011
   Coding: 003003208001040000001000
   VCID: 41CA806CD0C8624EC5-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015062261
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 45C2947CC4E04E6EF9-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 040517EE41280A
   Coding: 003001208001040000801000
   VCID: 40CC8568DBC26B46CA-8014
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015030695
   Coding: 150000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      721 0842
   Coding: 02731000FF00000051510001000808001F0500D60120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D12CCDC7C50962E11-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT1620024
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
Admaps HERE
iichel
Netherlands, eastern part
C?ID=284912
Coding: 000000000000000000000000000000000000000000000000000000000000 <<<<<<<<
interesting to see the long coding of the J519. All is now done by the adaptation channels?
Yes, it looks that way. Some of the new BCMs have all zeros in the coding string and others don't have a coding string at all.
automat
Canada
C?ID=153257
Been like that since mid 2016 I would say...
energy22
New Member
Spain
Adapmap
Hello,Don
I need the adapmap for module 9 BCM, of a golf 7.5 with DLA led if possible, and if you have module 4B as well.
Thank you
