Results 1 to 6 of 6
Thread: Problem with cvt automatic transmision (01J) on audi a4
    Apr 2017
    Serbia
    hi enebody can help with this problem with transmision on audi a4 2.0 tdi .problem is only when is car cold.Ther is no truble code store in tcm no fault! problem is start beetven 2 and 3 gear at 1200 rpm to 1500 rpm .this is my scan and qvestion how i can do adaptatin with vcds?
    VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
    VIN: WAUZZZ8E86A088295   License Plate:
              67 69 75 76 77
    VIN: WAUZZZ8E86A088295   Mileage: 233760km-145251miles
    Address 01: Engine        Labels: 03G-906-016-BPW.clb
       Part No SW: 03G 906 016 FQ    HW: 028 101 254 7
       Component: R4 2,0L EDC G000CG  9382
       Revision: --H01---    Serial number:
       Coding: 0000076
       Shop #: WSC 80093 222 69422
       VCID: 77A8E295D3C176CF59F-8022
    Readiness: 0 0 1 1 1No fault code found.
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E1 910 155 F    HW: 01J 927 156 HT
       Component: V30 01J 2.0l PD RdW 0010
       Revision: 00000008    Serial number: 00000000902936
       Shop #: WSC 06325 000 00000
       VCID: 290CF4ED55F5103F1FB-807C
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
       Component: ESP8 front      H05 0120
       Coding: 0004402
       VCID: 280AF1E94EFF2937005-807C
       Part No: 8E0 820 043 BJ
       Component:   A4 Klimaautomat   2832
       Coding: 00000
       VCID: 6A8ECBE19563DB27D61-5160
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 K
       Component: int. Lastmodul  ECE 0504
       Coding: 10011
       Shop #: WSC 06325
       VCID: 3A2E3BA1A543ABA7661-4B00
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H11 3530
       Revision: 91H1135    Serial number: 0036M0071G2E
       Coding: 0033622
       VCID: 3B203EA5AF6992AF7D7-806E
       Subsystem 1 - Serial number: 6332DRB4020DC49BY
       Subsystem 2 - Serial number: 6342DRB4020590246
       Subsystem 3 - Serial number: 6352ARB4009849CBZ
       Subsystem 4 - Serial number: 6362ARB40094F9CC1
       Subsystem 5 - Serial number: 63729RB400A3DCF6%
       Subsystem 6 - Serial number: 63829RB400A3DD1E
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0701
       Coding: 00042
       Shop #: WSC 06335
       VCID: 41DC4C4DC895F87F27B-4B00
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 901 D    HW: 8E0 920 901 D
       Component: KOMBI+WFS 4     H12 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0006004
       VCID: 2616FFD144FB3F47329-5184
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0006004
    Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
       Part No: 8E0 959 433 BP
       Component: Komfortgerát T85    3332
       Coding: 07024
       Shop #: WSC 09123
       VCID: 005A8949831F3177685-4B00
       Subsystem 1 - Part No: 8E1959801H
       Component: Tőrsteuer.FS BRM 0406
       Subsystem 2 - Part No: 8E1959802B
       Component: Tőrsteuer.BF BRM 0205
       Part No: 8E0 035 186
       Component: concert II  GRO    0001
       Coding: 01001
       Shop #: WSC 63351
       VCID: 6492A5D977778D57ECD-4B1E
    End----------(Elapsed Time: 05:55, VBatt start/end: 14.0V/14.0V)-----------
    Oct 2014
    Arandjelovac, Serbia
    Hi Daca,
    I'm thinking the transmission has a mechanical fault, but let's wait for more experienced colleagues.
  3. Likes Daca liked this post
    Quote Originally Posted by Daca View Post
    You can try this, but I don't have much hope that it will improve things.
    FWIW, an 01J with over 200,000 km strikes me as something of a miracle to begin with.
  5. Likes Daca, NZDubNurd liked this post
  6. #4
    Apr 2017
    Serbia
    Thanks for reaplay to my qvestion...is it same with 7 speed procedurs as 6 speed ?my is 7 speed transmision?
    01J is a CVT (Continuously Variable Transmission). It effectively has an infinite number of gears, but it can simulate a transmission with a fixed number of gears. How many gears it simulates it just a question of software in the mechatronic. So yes, I think that this procedure applies to all the 01J transmissions that use older, non-UDS protcols.
  8. Likes Daca liked this post
  9. #6
    Apr 2017
    Serbia
    Thanks one more time now transmision work normal
  10. Likes Boki Ar, Uwe liked this post
