2016 Audi Q7 VIM enable (Video in Motion) for DVD etc
FioranoCars
C?ID=68608
Hi
For once not a problem, just a tweak request, as seem unable to achieve the result using the serial decoding options for MMI 2G or 3G,
VIN: WAUZZZ4M4GD014xxx
Chassis Type: 4M-AU73 (4M1)
Serial: A270G0F7508982
2G/3G code generator gives:
Code 1: 08028
Code 2: 00892
Neither codes work to give access, and if unlocked using the hinted developer code, there is no option to code channel 48?!
Is this using a new MMI like a 3G+ or 4G?
Is there something daft I'm missing (probably!)
Anyone able to enlighten me on making this change, or if it is a software option or just a hard coded non changeable thing?
If anyone can point me to any resources on the options for this vehicle that can be changed, I'm sure the owner (a friend) would be interested to have a good browse to see what he can achieve!
thanks for any help
Richard
Here is the scan for address 5F, as assume you don't need/want a full scan?:
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 035 B HW: 4M0 035 035
Component: MU-P-LND-EU 042 0358
Serial number: A270G0F7508982
Coding: 01370601FF0A000013111101000A00332F001BE701700100DE
Shop #: WSC 31414 790 00001
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 230639042A6E2D5D88-8076
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9FJ400MU5
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 D HW: 4M0 919 615 D
Component: ControlUnit_P H14 0165
Serial number: 14071500000000000108
Component: Gracenote2 --- 1010
First, we don't "do" VIM here. There's just too much potential liability when a car crashes while a video is playing.
Second, this is clearly not an MMI 2G or 3G, so I'm not at all surprised that the "generator" doesn't work. In addition, it uses the UDS protocol, so there are no old-school numbered channels; see here.
DJAlix
London, United Kingdom
C?ID=238277
You have a MMI4G / MIB2 unit which is very different from the Audi MMI units of old. VCDS is not capable of activating Video in Motion on the new MIBx units as the process is not completed via a coding or adaptation.
