How to Turn off Gear Shift Indicator - 2015 S4 6MT
rbb1485
C?ID=325014
Hello All,
I just picked up a 2015 S4 6MT and trying turn off the "gear shift indicator" in the Driver Information System. It constantly wants me to upshift and is very annoying! I have gone through all options in the MMI and could not find an option to turn it off. I also do not have a "instrument cluster" option when I go into "Car". I am at a loss! Please VCDS gurus help me out! I can post auto-scan too in the morning.
Ross
Eric
HC800000
1) Post your autoscan :)
2) Go to cluster (17), long coding, byte 01. The helper will have the info you need to turn it off. It should have been off by default.
3) Since it appears someone was in there before, do you have the oil temp/lap timer enabled? If not, I highly recommend it :) It's in long coding byte 01 as well.
rbb1485
C?ID=325014
Hi Eric, thank you for the response. I will be posting the auto-scan in the next couple days. I am not quite sure I understand what you mean by "help will have the info you need to turn it off" I am very new to VCDS, just got it a month ago.
I do in fact have the oil temp/lap timer enabled, used Carista to do that, but want to get the know how and saviness to use Ross-tech for all these changes now. But not even sure what "long coding byte 01" is or where it is, and am nervous to mess something up!
Thanks again!
[Select]
[17-Instruments]
[Coding]
[Long Coding Helper]
Click on Byte 01.
rbb1485
C?ID=325014
Hello All,
Thank you for the advice on how to turn off my manual gear indicator. I got as far as:
[Select]
[17-Instruments]
[Coding]
I then clicked on Byte0-1 drop down menu, and I see several options: See pic below:
How do I know which to choose? 00, 01, 02, 03 ?
Also, for reference, here is my autoscan from my 2015 Audi S4 6MT:
 Thursday,15,February,2018,18:57:32:53404
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUDGAFL4FA070041   License Plate: BR95HE
Mileage: 86960km-54034mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUDGAFL4FA070041   Mileage: 86960km-54034miles
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---
   Coding: 0A190034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS0218K5907551G.rod
   VCID: 3A2DCFDE7CD29017661-806E
Readiness: 0000 0100
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 281D1A01
   Shop #: WSC 06325 000 00000
   VCID: 094F601269344B8F3FB-805C
   Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
   Component: BCM2 2.0      H15 0711
   Coding: 0F814040000000000000
   VCID: 05576C22452C2FEF5B3-8050
   Subsystem 1 - Part No SW: 8K0 959 754 BB    HW: 8K0 959 754 BB
   Serial number: 0514000145672007
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 3214000134001002
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Component: KLIMA 3 ZONEN H04 0122
   Revision: C1000000    Serial number: 01051120141101
   Coding: 6600228000
   VCID: 77AB16EA0FC04D7F59F-8022
   Revision: 08016001    Serial number: 00000937313502
   Coding: 26000011873CAFE0240040C300003D0D4F9C9308A2090221000008004000030100000030000000
   VCID: 78A915D602DE4207505-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA061014  H18 0461
   Serial number: 1410020603566
   Coding: 004577
   Serial number: 23412839
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002810145509
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01CC9020
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 04288757000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD12M9WW
   Coding: 303844354730383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4BC39A1A2348199FCD7-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000KV1F
   Serial number: 6334MSME497C1460G
   Serial number: 6344MSME4A7B3470K
   Serial number: 6352QSME0F4A205ER
   Serial number: 6362QSME124A32505
   Serial number: 63732SME0F4C157AA
   Serial number: 63832SME094C034E3
   Revision: --------    Serial number: 90372NK30008S
   Coding: 000016
   VCID: 44D1B1260E96D6E70CD-8010
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 63-6822CF
   Coding: 83BD09008301D705020000
   VCID: 72BD27FE64A228576E1-8026
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z14A2502E9
   Coding: 80C303FF00
   VCID: 4CC1990626C61EA7C4D-8018
   Serial number: 2183144903
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 208
                    Mileage: 86663 km
                    Date: 2017.02.02
                    Time: 16:19:55
                    Bin. Bits:    10000
                    Voltage: 12.30 V
                    Count: 11
                    Bin. Bits:    00000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 002810140001039
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
   VCID: 2F3BEE8AB79045BFC1F-807A
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000122733912
   Coding: 00581B00000000000000
   VCID: 3B23CADA7368A91F7D7-806E
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0350353379
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FDBBECA67F0B53F51F-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0350605444
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Coding: 011C13204E00410001
   VCID: 56F57B6EE80A5477629-8002
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0021119961
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3829D5D642DE8207905-806C
   Revision: 00002001    Serial number: 0351526317
   Coding: 0106063A00FA404580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000905130
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Revision: 00005001    Serial number: 94813036637306
   VCID: 2D07F482BD1C37AFF33-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   VCID: 55F77C62F50C5F6F6B3-8000
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001557454
   ROD: EV_ParkiBrake_AU48.rod
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156K10E8090734
   Coding: 020007010000000001
   VCID: 241111A6EED6F6E72CD-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523KY0E7503125
   Coding: 110200000206A1EF55028B5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130K50E3177889
   Serial number: 00000002034995
   Component: CD-Database  5950
02067 - Optical Databus; Unpermitted Wake-Up Request
            000 -  -  - Intermittent
                    Reset counter: 208
                    Mileage: 86663 km
                    Date: 2017.02.02
                    Time: 16:14:37
                    Voltage: 12.20 V
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C13204000210001
   VCID: 59EF705299147B0F4FB-800C
   Revision: --H09---    Serial number: 525PA8-J4892T2
   Coding: 1000006
   VCID: 3829D5D64E5E8207905-806C
   Component: TSG HR        H08 0305
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0006
   Serial number: 141011200009
   VCID: 72BD27FE642228576E1-8026
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)----------- ]
Any idea the one fault found in [19] CAN-Gateway ?
I also need to get an inspection, so I figured I'd do a "Readiness" check and got this:
"Evaporative Emissions failed / incomplete."
Only thing I can think of, is dealer installed a new battery at 53,820mi before I picked up, and I have only driven about 200 miles since.
Thanks all for your help!
You need to click on Byte 1. Your picture is from Byte 0. :)
The intermittent Optical Databus fault in the Gateway: If that were a significant problem, it would produce symptoms in your infotainment system.
Evap Readiness: The car may not have seen the correct conditions to perform the test. You could try forcing it, but personally, I don't think I would at this point.
rbb1485
C?ID=325014
Hmm...what exactly is "Byte01" ?
At the 4) Byte 0 --> Is that what you are referring to ?
or 1) 83BD09......
Sorry for being such a noob!
Look at the line in Long Coding Helper that's labelled 3)
The first byte is Byte 0. It has a value of 83. The next byte is Byte 1 has a value of BD. Click on it.
Also, the line labelled 4) will conveniently show you which Byte you're currently editing.
rbb1485
C?ID=325014
Thank you Uwe for literally spelling it out for me! lol Next question....so I am prepared once I go out and try it.....
What happens / what am I supposed to do/see when I click on Byte1 (value BD) ?
You'll see a bit labelled: "Shift Suggestion (Economy) active". Un-check it, then exit Long Coding Helper and click [Do it!] on the main Coding screen.
rbb1485
C?ID=325014
Hi Uwe, so last question and I think we've got it! After un-checking the "shift suggestion (economy) active" box, when I exit and click the [Do it!] , I get the following message:
And I am not sure what to do here! And don't want to take a guess and do something wrong!
Thanks!
Try [No] first and see if it will accept the coding change anyway. If so, there's no "who done it".
If that doesn't work, try [Yes] or try [Cancel]. If it accepts the coding change with [Yes] then there's an obvious "who done it" in there. If you use [Cancel], you could put more subtle non-zero numbers for Importer and Equipment Number.
FWIW, the above dialog is documented at the very bottom of the Coding Page in the VCDS product manual.
rbb1485
C?ID=325014
I selected "no" and it accepted the coding change! Not sure what you meant by "who done it" but nevertheless, thank you for all your help!
- Ross
rbb1485
C?ID=325014
Update! I just took it for a test drive, and it is still showing the gear shift suggestion! What gives ??
Workshop Code, Importer, and Equipment Number identify who last made changes to things like coding and adaptation values in a module. The dealers' tools have fixed values for these which are sent every time. VCDS will try to be stealthy and just put back whatever was there to begin with, but lots of modules these days won't accept that, especially when one or more of the fields is all zeros (as is the case in your instrument cluster). Hence the warning that the module may not accept changes unless you do something different.
First thing I would do is check whether the change to the bit in question really did "take".
rbb1485
C?ID=325014
Hi Uwe, I re-checked that the box for gear shift suggestion (active) stayed "un-checked" and it did. So I am assuming it "took" ?
Yep, sounds like it. Not sure why it would keep showing the upshift suggestion then.
rbb1485
C?ID=325014
Do you have any other suggestions for me to try ? do I have any options? Thanks!
Eric
HC800000
I'll try to turn it off on mine after lunch.
rbb1485
C?ID=325014
