First Scan due to Engine Light
daders
C?ID=306650
Greetings all!
Been meaning to scan my car for a while now, but put it off until I finally had an idiot light that required some attention/research (engine light - solid yellow (new to Audi electronic codes/repairs so I'm unsure if it goes red or blinks to indicate severity of issue)). Any assistance in identifying necessity of repair/how to remove fault is greatly appreciated.
First, the car is acting normally (i.e. no odd shifting, hesitation, acceleration, etc), however I would like to de-illuminate the engine light.
Found below, in order of importance are the faults (see Auto Scan for additional info):
1. Shift solenoid 1 Malfunction - No fault mileage, intermittent, not confirmed, tested since memory clear
Does "tested since memory clear" mean it is working currently? What function does the shift solenoid perform, from what I understand there is more than one...and where is it located (or better still is there a repair guide?
2. Fuel tank cap - Unlock, Open, blah blah...happened over 600 miles ago which means I already filled up and corrected that issue. To verify I rechecked the cap anyway and the engine light did not de-illuminate. Therefore I assume this is not the culprit.
3. Bank 1; system too lean at idle - MIL ON (what does this mean?) Not super concerned about this causing an engine light illumination especially considering the date is well before I noticed the light (I'm typically quite observant of changes in my vehicle's operation and idiot lights).
Faults unrelated to engine light:
1. Key 2 - no or incorrect Basic setting. Can someone elucidate what this indicates? Perhaps new battery? Is there a way to identify which is Key 1 and Key 2?
2. Seat Memory Driver - Component Protection Active. What does this mean? No noticeable difference in seat controls and happened about 14k miles/over a year ago.
3. Door Locking unit (Passenger and Rear Right): I replaced the lock actuator units over two years ago and bought aftermarket; with them installed the car never was happy again in respect to it will not remain auto-locked during driving and it locks when stopped but I don't think it is engaging the alarm...I'm just confused as to why this would only be logged one time and not ongoing. I will probably buy OEM and replace soon, but I was mostly curious.
4. Tire Pressure- No signal/Communication: I see n. erkannt (assume that means not recognized) and assume it is simply a dead battery. I hate the fact the tire pressure monitoring is being forced and I have to buy a whole new sensor rather than replace a battery. If I had my druthers I would disable the tire pressure sensor system (as I am sick of the mind penetrating beeeep every time the car is turned on due to this fault) is that a possibility with VCDS?
5. El Radio (lol) - I assume this is simply the Sirius satellite radio being not activated?
TIA for feedback/assistance. I'm guessing/hopeful a few of these will be resolved simply by clearing fault codes, but again most important to me is resolving the engine light (which I'm guessing is the shift solenoid?).
Wednesday,14,February,2018,14:16:24:33086
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WAUCF78K49N048317   License Plate: DR6M463
Mileage: 160940km-100003mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
          65 72 77
VIN: WAUCF78K49N048317   Mileage: 160940km-100003miles
Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
   Revision: E1H14---
   Coding: 0104010A02070160
   Shop #: WSC 42508 444 96599
   VCID: 79ACE48D0951412F6A7-802C
4105 - Bank 1; System too Lean at Idle
          P2187 00 [236] - -
                    Mileage: 160911 km
                    Date: 2018.02.12
                    Time: 16:54:51
                    Engine speed: 838.00 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 99 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.418 V
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AD    HW: 0AW 927 156 H
   Component: 0AW 20TFSIUSA H01 0002
   Revision: --H01---    Serial number: 0000001131
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMVL381 A02002
   ROD: EV_TCMVL381_AU57.rod
   VCID: 75B4E8BD2549254F0EF-8020
2274 - Shift Solenoid 1 (N88)
          P0750 00 [032] - Malfunction
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 080500
   Shop #: WSC 02391 823 56573
   VCID: 7CA2FD9906E37407711-8028
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0145
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 333016A56B3D7B7FE0B-8066
   Serial number: 0508000078110021
   Serial number: 0208000097208013
00956 - Key 2
                    Fault Status: 00100101
                    Reset counter: 234
                    Mileage: 160264 km
                    Date: 2018.02.06
                    Time: 12:47:17
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01181120081391
   Coding: 64002000
   VCID: 72BED3A154A732772BD-8026
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Revision: 05022001    Serial number: 00000000268546
   Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
   VCID: 303A19A99A2B40679D9-8064
   Component: WWS 221108  H06 0070
   Serial number: SWF08110225025
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10325243
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Serial number: 00000000001211081711
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Serial number: 0039KD14KT6J
   Shop #: WSC 02135 785 00200
   VCID: 40DA49692A0BD0E76D9-8014
   Serial number: 5810000R08000032UT
   Serial number: 6334MSME4271641CA
   Serial number: 6344MSME43632E1CJ
   Serial number: 6352QSME59120A16B
   Serial number: 6362QSME38132B18F
   Serial number: 63732SME07052404L
   Serial number: 63832SME19132E32Z
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HKG000F2
   Coding: 000016
   VCID: 3D24309D5D79BD0F06F-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9DR395RA8
   Coding: 8B1609000300D705020000
   VCID: 2D0400DD8D192D8FB6F-8078
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G08B088A0B
   Coding: 000303
   VCID: 4BC06E4513CD03BF88B-801E
   Component: J367-BDM  H04 0150
   Serial number: 180542E9051108
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Revision: 00000000
   Coding: 020302
   VCID: 78AAE18932DB5827159-802C
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001184505
   Coding: 00581300000000000000
   VCID: 77A8E2B53FC5575F1C3-8022
            000 -  -  - Intermittent
                    Fault Frequency: 25
                    Mileage: 139113 km
                    Date: 2016.12.16
                    Time: 16:25:01
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008120104
   Coding: 011C03204E00410001
   VCID: 41DC4C6D2181D9EF627-8014
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0116178449
   Coding: 0106023A007A440400B001
   Component: GTO BF  H06 0040
   Serial number: 00000000000000093983
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Reset counter: 247
                    Mileage: 159916 km
                    Date: 2018.01.20
                    Time: 14:33:15
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6E86C7D1409F1697CF5-803A
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008151308
   VCID: 40DA49692A8BD0E76D9-8014
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 209
                    Mileage: 134330 km
                    Date: 2016.10.14
                    Time: 12:56:23
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 00000000272188
   VCID: 323E13A194277277EBD-8066
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77A8E2B533C5575F1C3-8022
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
   Component: Symph3 Sirius H02 0231
   Revision: 00000005    Serial number: AUZ5Z4H1067231
   Coding: 040200020101850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
            000 -  -
                    Reset counter: 209
                    Mileage: 134330 km
                    Date: 2016.10.14
                    Time: 12:48:43
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100497509
   Coding: 010C03204000210001
   VCID: 44D245793E93CCC7491-8010
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140782135965
   Coding: 0CD154
                    Fault Status: 11100100
                    Reset counter: 209
                    Mileage: 134330 km
                    Date: 2016.10.14
                    Time: 16:50:33
                    Bin. Bits: 00000000 01000001
                    Voltage: 12.40 V
                    Text:  20,5°C;n.erkannt;3390320244;--h;---°C
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100497506
                    Reset counter: 209
                    Mileage: 134330 km
                    Date: 2016.10.14
                    Time: 12:51:56
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005011784
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3B203E854F6DB33F38B-806E
End----------(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.9V)-----------
1) I wouldn't get too antsy about any fault code that's flagged "Intermittent - Not Confirmed", which that one is.
2) That code is in your Central Convenience module. It is not responsible for your Check Engine light. It's not the fuel filler cap that's at issue here, but rather the locking mechanism for the flap/door that covers it. I would clear that fault, but it it recurs, check wiring to the actuator.
3) MIL ON -- means this fault is severe enough to turn on a Malfunction Indicator Lamp. "System too Lean at Idle" is usually indicative of an intake air leak.
1) Look with only one key in the car, look at MVB 022.3; that should tell you the current key number.
2) It's an intermittent fault. Something woke up on the wrong side of the bed that day. I'd clear it.
3) Sounds like FOD. :)
4) Have a look through the MVBs of this module to see which sensors are communicating and which aren't. Given that this is a 2009 car, if the sensors are original, they're probably at end-of-life.
5) Correct.
daders
C?ID=306650
Thanks Uwe! Have to laugh at myself that my order of importance was completely wrong wrto cause of engine light.
Oh boy, FOD can mean so many different things so I'm going to go with Freaking Online Dunce because it makes me chuckle the most.
Component: 2.0l R4/4V TF H14 0001 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FIRMWARE UPDATE NEEDED 0003 or higher!
Revision: E1H14---
I would be concerned with a lean issue.......especially if it went MIL which means..... it happened..... it corrected and it happened again & before it illuminated the MIL.
You may want to check the PSI control valve & at idle offset, PCV and evap controls for carbon. Do this before you blow an engine seal and check oil sump level conditions.
These links might be helpful for a process.
http://forums.ross-tech.com/showthr...gases-and-vacuum-amp-so-should-you!-Air-leaks!
JPPSG
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
See how it's bold-face, dark green, and has a broken double underline? Hover your cursor over it.
daders
C?ID=306650
I viewed and replied to your post while on the phone and tapping it resulted in no response...thus my reply.
NP OP
Just be sure to report back what it is.......... & so the "collective" will see the distinct patterns to add to our significance!
latest
Resistance is Futile!
daders
C?ID=306650
Here's the short answer diagnosis: Rear main seal.
Full disclosure: This vehicle has been the bane of my existence since I made the horrific mistake of abandoning BMW. I fought with the Audi dealership shortly after purchasing this (CPO with 36k miles) vehicle and the oil indicator informing me I had gone through a quart of oil in about 2k miles. Shortly before the CPO ran out the dealer finally performed an oil consumption test after my constant badgering and agreed it wasn't normal (contrary to what they first stated). Result, replace the PCV (i.e. crankcase breather). By that time I was down to 1000 miles/quart. Consumption improved to about 2500 miles/quart, but started dropping to 1k miles/quart until I reached ~70k miles on the odometer. At which point I was using an Indy when the engine acted like it was in neutral while in gear; took it in and the breather once again was replaced. 5k miles later, at 75k miles on the odometer I found oil puddled all over the top of the engine. Replaced the timing cover gasket. Shortly after this repair I noticed oil splatter on the garage floor from it exiting via the tailpipes. Oil consumption improved to 3000 miles/quart the first interval then quickly descended to 500 miles/quart with about 95k miles on the odometer. That takes us to today, where my Indy thinks this car is fine after replacing the rear main seal...my perception is I'm just going to blow out the next weakest seal/gasket.
I'd love to hear your impression of what you would tell a customer the state of this engine given the above information...I have tried to keep it clean with multiple inductions (Audi's word for blowing chemicals through the engine in an attempt to remove carbon buildup as it was explained to me), but I can only imagine how fouled the catalytic converter is in addition to other parts given my oil consumption rate.
http://forums.ross-tech.com/showthr...o-Engine-Light&p=120856&viewfull=1#post120856
Thank you for confirming my suspensions & that I was indeed correct no?
This is why people should heed my warnings on PSI in the block and observe it right?
Still not a sticky huh? ;)
Hey OP did you get the firmware update done?
Want to get reimbursed for all that work or if paid out of pocket?
Final auto-scan?
Component: 2.0l R4/4V TF H14 0001 <<<<<<<<<<<<<<<<<<<<<<<<< Lets have a look see....ULEV2
HMMMMMMM
Mileage: 160940km-100003miles <<<<<<<<<<<<<<<<<<< Under warranty as CAEB ULEV don't you think so & for all aforementioned in this thread & as a vicarious result? :rolleyes:
daders
C?ID=306650
Final auto-scan?
HMMMMMMM
Well, prior to taking the vehicle in I did the paper over the oil cap test and it was pulling a vacuum so I assumed the PCV was operating as expected. Obviously that is not super scientific-y. All I can say is I have been watching both Audi & BMW have oil consumption problem complaints with both addressing the symptoms and not the underlying cause given that people (like myself) have recurring issues. I assume on my vehicle, given this has been ongoing for at least 65k miles, that next up are the piston rings and/or valve seals are next as it seems I'm about done with external seals/gaskets...but obviously I'm no mechanical expert.
Oh and, by the way, not only were you correct, but eerily so as I didn't drive it but 10 miles more after original post until oil started showing from different spots due to the underbody cover plinko game fluids play on those plastic panels.
No on firmware update.
Not sure how I would get reimbursed on a vehicle with 100k miles on the odometer, but I'll bite as a decent chunk of change has been spent in the past two years due to this.
Sure, I can post an auto-scan. Probably won't get to it today though, hopefully tomorrow...if I was smart I would have driven this car into one of those flooded areas "accidentally" yesterday and been done with it, lol.
I'm not certain I understand the final statement?
You are doing that test improper..........and a constant vacuum would indicate a problem as would blowing it off.
Switching of the valve is what you want to see & as "a DANCE cap" not dunce......... :rolleyes:
You didn't pay out of pocket for these repairs did you?
Jack is saying that the vehicle is still under an emissions warranty. I'm not sure I agree. To start with, you appear to be in a state where CARB rules do not apply, only the less stringent federal rules.
daders
C?ID=306650
Yes, I most certainly did as the dealership in no uncertain terms told me there was no longer a warranty after I reached the end of the CPO period.
daders
C?ID=306650
I was under the same impression, being in TX has its disadvantages at times.
Indeed am I?
If a car is certified Federally and vicariously by means of a 50 state CARB COC, it doesn't matter the state he resides in or to receive such a warranty extension & as stated on the EPA COC application & because the manufacturer had a choice to certify the car separately for states which don't partake in a bifurcated COC Federal application?
ANY manufacturer does and must clearly state what the warranty and useful life is of all and each SMOG component & on any such COC application, don't they?
Remember I am asking tough questions now right? ;)
daders
C?ID=306650
Indeed am I?
Good luck with that tactic; I don't have the time, resources or inclination to fight the local Audi Service Department, followed by the Service Manager, then Audi NA, followed by Audi lawyers and finally VWAG lawyers (or whatever the parent company is called now)...even if I skip the first two I really don't think it's worth the grey hair effort to recoup $5k. What I do have time to do is tell all my friends/colleagues my experience with how Audi responded to my concerns, how the vehicle behaved subsequently and that Audi will never receive another dime from me.
