Hi All,
Hoping someone can help me out.......
I have a 2006 EOS 2.0 FSI which has recently developed a fault where the trunk, roof and sunroof all fail to operate, like there is no power to any of them. I did some checking yesterday and can confirm that there is a 12V supply to one of the connectors on the roof controller. However, I also discovered that the high level brake light has been letting in water and there were signs of corrosion on a couple of the electrical connectors - nothing too bad and they cleaned up quite easily with a small brush and some switch cleaner.
I have purchased and registered a Ross-Tech HEX-V2 and downloaded the latest VCDS software. My log file is as follows........
There are quite a few faults showing which I will investigate in time, but I'm particularly concerned with the convertible top control module (J256) which shows as 'no signal/communication'. Obviously without being able to communicate with it, I'm struggling to diagnose my roof issue.
Can anyone help??
Can anyone help??
Tuesday,13,February,2018,18:58:49:53052
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZ1FZ6V008036 License Plate:
Mileage: 180370km-112076mi Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 37 42 44 46 52 56 62 72 76
VIN: WVWZZZ1FZ6V008036 Mileage: 180370km-112076miles
26-Auto Roof -- Status: Cannot be reached 1100
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1Q0 907 115 C HW: 1Q0 907 115
Component: 2.0l R4/4V TFSI 0040
Revision: --H14--- Serial number: VWX7Z0F23NM8OQ
Coding: 041C000318070160
Shop #: WSC 00413 210 52643
VCID: 2C01FA465A07C4A7E4D-8078
008825 - Leak in Air Intake System
P2279 - 002 -
Fault Status: 01100010
Mileage: 175873 km
Time: 23:44:17
RPM: 795 /min
Load: 16.1 %
Temperature: 67.0°C
Temperature: 24.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction - Intermittent
Fault Status: 00100001
Mileage: 175940 km
Time: 05:40:37
RPM: 840 /min
Load: 16.1 %
Speed: 1.0 km/h
Temperature: 63.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Mileage: 176219 km
Time: 22:50:38
RPM: 899 /min
Load: 14.9 %
Temperature: 67.0°C
Temperature: 16.0°C
Voltage: 14.351 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Fault Status: 00110010
Mileage: 179606 km
Time: 10:08:02
RPM: 811 /min
Load: 14.5 %
Temperature: 73.0°C
Temperature: 31.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Load: 0.0 %
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Mileage: 180371 km
Time: 04:14:30
RPM: 1552 /min
Load: 11.8 %
Speed: 22.0 km/h
Temperature: 68.0°C
Temperature: 15.0°C
Voltage: 14.478 V
Readiness: 0000 0100
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0004834
Shop #: WSC 00020 000 00000
VCID: 71BF2B32BDA5E94F97B-8024
Part No SW: 1Q0 907 044 A HW: 1Q0 907 044 A
Component: ClimatronicPQ35 093 0101
Revision: 00093002 Serial number: 00000000000000
VCID: 2B03F95A5F09C39FED7-807E
00830 - Convertible Top Control Module (J256)
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005474167
Coding: E58E8F0700041500470A00000F00000000095D035C0000
VCID: 372BD52A9341777F99F-8062
Subsystem 1 - Part No: 1K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00020
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00020
Reset counter: 103
Mileage: 179894 km
Voltage: 12.40 V
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 3C Airbag VW8C 0180
Revision: 92009018 Serial number: 003B30007E0
Coding: 0013123
VCID: 3A2DCC1EA0536A17661-806E
Subsystem 1 - Serial number: 6332SRB402E34F2D8
Subsystem 2 - Serial number: 6342SRB4031B9223U
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000041
VCID: 76B5182ED4CBCE77429-8022
Part No: 1Q0 920 972 B
Component: KOMBIINSTRUMENT VDD 4314
Coding: 0021403
Shop #: WSC 80093 222 69422
VCID: 313FEB327D25A94FD7B-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 30001063248727
Coding: 3D3F274807005001
Fault Frequency: 16
Reset counter: 103
Mileage: 179894 km
Time: 11:39:51
Component: IMMO VDD 4314
Address 26: Auto Roof
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 F
Component: Navigation 0028
Coding: 0000101
VCID: 3C21CA06AA67542774D-8068
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1Q0 959 701 C
Component: Tuer-SG 024 2728
Coding: 0000695
VCID: 3431E22682379C67BCD-8060
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Coding: 81908A000186285B0804840570085EC690BC00
VCID: 035371FA9719EBDF757-8056
Subsystem 1 - Part No: 1K0 951 605 B
Component: LIN BACKUP HORN H07 7001
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 1Q0 951 177 A
Component: Innenraumueberw.158 0502
00956 - Key 2
Fault Status: 00110101
Reset counter: 142
Mileage: 177262 km
Time: 00:41:26
Fault Frequency: 9
Reset counter: 102
Reset counter: 142
01134 - Alarm Horn (H12)
Reset counter: 142
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1Q0 959 702 C
Coding: 0000694
VCID: 3537DF22894D856F8B3-8060
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 E
Component: Radio 0028
Coding: 0040402
Shop #: WSC 00413 210 63940
VCID: 270B056A43E1E7FF09F-8072
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1Q0 959 703
Component: Tuer-SG 021 2705
Coding: 0000128
VCID: 73B3213AC7B9DB5F657-8026
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1Q0 959 704
Component: Tuer-SG 020 2705
Coding: 0000128
VCID: 74B12226C2B7DC677CD-8020
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1Q0 919 283
Component: 30 Einparkhilfe 0702
VCID: 72BD243EB8A3D2576E1-8026
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 46: DTCs cleared
Activating transport mode...Done.
