Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 09G to 02Q transmission swap (2006 3C Passat)
    Quote Originally Posted by cazamoyr View Post
    Hi Yo2095
    I'm working on a transmission swap for my 2010 (3C) Passat. I'm already done with most of it and everything works fine . The only think I'm missing is the ABS coding as it has to be re-code it for the manual transmission. Could you please post the ABS coding for you 2009 CC manual tranny. I think I might be able to use your code as the ABS unit for Passat and CC should be same.
    Please post an Auto-Scan so people can see exactly what ABS module you have and what its existing coding is.
  2. #12
    Mar 2016
    Auto-scan:
    Thursday,06,December,2018,09:37:02:16534
    VCDS Version: 18.9.0.2 (x64)
    VIN: WVWJK7AN6AE112453   License Plate: PASSAT
    Mileage: 236370km-146873mi   Repair Order:
    Chassis Type: AN-VW46 (3C0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 53 56 62 65 72
              77
    VIN: WVWJK7AN6AE112453   Mileage: 236370km-146873miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 DA    HW: 06J 906 026 DA
       Component: MED17.5 TFSI 2,0    6987
       Revision: AAH15---    Serial number: VWZCZ000000000
       Coding: 0404010A18070160
       Shop #: WSC 05314 123 12345
       VCID: 6CD7FF894FCB612A19-8038
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000705132477
       Coding: 0000000
       Shop #: WSC 05311 000 00000
       VCID: 62CB91B1BD0F275AA3-8036
                        Reset counter: 138
                        Mileage: 236379 km
                        Date: 2013.04.28
                        Time: 14:21:45
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 149
                        Hex Value: 0x0000
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 05311 115 00000
       ROD: EV_ClimaBasis_VW46.rod
       VCID: 75E1DAEDD481A0E2F6-8020
       Revision: 00H54000    Serial number: 00000003639490
       Coding: 15848F0340041A00470000000F00000080285D435C000120000000000000
       Shop #: WSC 05124 123 12345
       VCID: 336524F55275FED218-8066
       Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
       Component: Wischer 140110 006  0208
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
       Component: J234__01T VW10 HI   1916
       Revision: 20013000    Serial number: 003E1P2X8EBP
       Coding: 0012628
       VCID: 428B71311DCF475A83-8016
       Subsystem 1 - Part No: 000 000 000 00
       Component: BF-Gewichtsens. 000 0000
       Subsystem 2 - Serial number: 00000000000000
       Subsystem 3 - Serial number: 0000.00.000000000000000000ˇ63
       Subsystem 4 - Serial number: 000000ˇ6332MTS612523509 ˇ63
       Subsystem 5 - Serial number: 23509 ˇ6342MTS649710270 ˇ63
       Subsystem 6 - Serial number: 10270 ˇ6351HTS6OIV286KJ ˇ63
       Subsystem 7 - Serial number: 286KJ ˇ6361HTS6JV2986KR ˇ63
       Subsystem 8 - Serial number: 986KR ˇ63727TS6K56886KR ˇ63
       Subsystem 9 - Serial number: 886KR ˇ63827TS6KGT986KR ˇ
       Subsystem 10 - Serial number: 986KR ˇ
    02511 - Control Module for Seat Occupied Recognition (J706)
                        Fault Status: 11100100
                        Reset counter: 178
                        Mileage: 236379 km
                        Date: 2013.04.28
                        Time: 14:11:31
    00592 - Seat Belt Switch; Passenger (E25)
                        Fault Status: 11101010
                        Mileage: 236379 km
                        Date: 2013.04.28
                        Time: 14:11:23
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Mileage: 236379 km
                        Date: 2013.04.28
                        Time: 14:11:23
                        Fault Status: 11100001
                        Mileage: 236379 km
                        Date: 2013.04.28
                        Time: 14:11:23
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Component: LENKS.MODUL   009 0122
       Revision: FF010035    Serial number: 20100208100160
       Coding: 018A270002
       Shop #: WSC 05311 115 12345
       ASAM Dataset: EV_VW360SteerWheelUDS A03002
       VCID: 6BD5FC9582C5661210-803E
       Coding: E20000
       Part No SW: 3C0 920 972 L    HW: 3C0 920 972 L
       Component: KOMBI         H03 0305
       Coding: 260F00
       Shop #: WSC 05314 115 00000
       VCID: 2F6D2885765DDA327C-807A
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3620P10218073D
       Coding: F9807F07001612001002
       VCID: 2F6D2885BE5DDA327C-807A
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1614128T1CCS02
       Shop #: WSC 05314 000 00000
       VCID: 75E1DAED1C81A0E2F6-8020
       Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       VCID: 78FFD3D90B93DD8AED-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0090
       Revision: A1001003    Serial number: 7667824967
       VCID: 2643CDA151A79B7A8F-8072
       Part No SW: 3C0 959 701     HW: 3C0 959 793
       Component: TUER-SG FT    002 0305
       Revision: 13101005    Serial number: 0000439990
       Coding: 0004B5
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 65C18AAD6421506246-8030
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 A    HW: 3C0 959 795 A  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0402
       Serial number: 00000001264426
       Coding: 000490
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.148 0703
       Revision: 1AH03726    Serial number: 00093370154002
       Coding: 0000258
       VCID: 3A7B09D1751F0F9ADB-806E
       Component:    KSG PQ46 RDK 052 0412
       Coding: 13910F8001862E521004141FF08A0F0E085801
       Part No SW: 3C0 959 702     HW: 3C0 959 792
       Component: TUER-SG BT    002 0305
       Revision: 15101005    Serial number: 0000416234
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 66C38DA199275B7A4F-8032
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704 A    HW: 3C0 959 794 A  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0402
       Serial number: 00000001281521
       Coding: 000490
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000167979
       Coding: 0000056
       VCID: 2C573F898F4BA12A59-8078
    03182 - Clutch Position Sensor (G476)
                        Fault Status: 11111010
                        Reset counter: 138
                        Mileage: 236379 km
                        Date: 2013.04.28
                        Time: 14:11:22
                        Voltage: 11.70 V
                        Count: 57
                        Hex Value: 0x1261
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0035
       Revision: -----20S    Serial number: VWZ4Z7K1111828
       Coding: 0100040004
       VCID: 61C99EBD78093C42BA-8034
                        Reset counter: 138
                        Mileage: 236379 km
                        Date: 2000.15.00
                        Time: 14:11:24
                        Reset counter: 138
                        Mileage: 236379 km
                        Date: 2000.15.00
                        Time: 14:11:21
       Component:    RDK              0453
       Coding: 0100101
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
       Component: FSE_2P8x        H40 0190
       Revision: 00000000    Serial number: 00000005197183
       Coding: 0013077
    End-------------------------(Elapsed Time: 02:27)--------------------------
  3. Likes Uwe liked this post
