2010 Audi Q7 Adblue reset issue
gerber114
New Member
I have searched the internet for days now and I am running out of time to rest my Adblue warning light before the vehicle will not start!! When the Q7 notified me of 1100 miles remaining before non start, I added approx. 5.5 gallons to the tanks before it was completely full...the warning light went away (I thought) to return saying 600 miles before non start! Now I am in a race against time to reset this adblue warning light. I have tried the Ross-Tech suggestion I found from user "DUTCH VanAtlanta" using Engine 01 --> channel 80 and setting the new value to 1, but it will not let me change the number and save...I know the tank is full and I need help quick!! Below is my Autoscan:
Tuesday,23,September,2014,16:52:49:58291
VCDS Version: 14.8.0.0
Data version: 20140822
VIN: WA1WMBFE7AD006296   License Plate:
Mileage: 105760km-65716mi   Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
          52 55 56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMBFE7AD006296   Mileage: 105760km-65716miles
Address 01: Engine (CAT)       Labels: None
   Part No SW: 4L1 910 401 G    HW: 4L0 907 401 B
   Component: 3.0TDI EDC17G004AG  0100
   Revision: 31H02---    Serial number:
   Coding: 0121002A190F0968
   Shop #: WSC 37605 000 1048576
   VCID: 271E3CF5960EA702B2-8072
008430 - SCR NOx Catalyst Bank 1
               P20EE - 001 - Efficiency too Low - MIL ON
                    Fault Status: 11100001
                    Mileage: 101973 km
                    Date: 2014.08.04
                    Time: 12:22:51
                    RPM: 1764 /min
                    Speed: 89.6 km/h
                    Voltage: 14.06 V
                    Temperature: 264.0°C
                    (no units): 0.58
                    (no units): 0.61
                    (no units): 1.38
008863 - NOx Sensor 2 Bank 1
               P229F - 001 - Implausible Signal - Intermittent
                    Fault Status: 00100001
                    Mileage: 105147 km
                    Date: 2014.09.16
                    Time: 15:20:53
                    RPM: 1365 /min
                    Speed: 71.7 km/h
                    Inj. Quantity: 0.0 mg/str
                    Mass Air / Rev.: 628.6 mg/str
                        8 ppm
                        88 ppm
                    Duty Cycle: 99.6 %
008436 - NOx Reductant Consumption too Low
               P20F4 - 002 -  - Intermittent
                    Mileage: 104896 km
                    Date: 2014.09.14
                    Time: 10:24:10
                    RPM: 1575 /min
                    Speed: 47.0 km/h
                    Voltage: 14.29 V
                    Temperature: 342.0°C
                    (no units): 0.24
                    (no units): 0.61
                    (no units): 1.82
008319 - Reductant Quality Performance
               P207F - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 105539 km
                    Date: 2014.09.21
                    Time: 10:03:11
                    RPM: 2163 /min
                    Speed: 109.8 km/h
                    Voltage: 14.06 V
                    Temperature: 324.0°C
                    (no units): 0.00
                    (no units): 0.60
                    (no units): 1.72
Readiness: 1 4 0 0 0
   Part No SW: 09D 927 750 LL    HW: 09D 927 750 LL
   Component: AL 750 6A           1579
   Revision: 00H92000    Serial number:
   Coding: 0001016
   Shop #: WSC 31414 790 00001
   VCID: 0346486542F6AB22CE-8056
Address 03: ABS Brakes        Labels: 4L0-910-517.clb
   Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
   Revision: 00H30001
   Coding: 0103569
   VCID: 3228DDA1ADCCD2AA15-8067
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601513790
   Coding: 0000135
   VCID: 250236FDEC02B51280-8070
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 15
                    Mileage: 96217 km
                    Date: 2013.12.18
                    Time: 14:32:03
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 00110111
                    Reset counter: 84
                    Mileage: 96217 km
                    Date: 2013.12.18
                    Time: 14:32:03
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 66
                    Mileage: 96375 km
                    Date: 2014.04.09
                    Time: 15:12:36
                    Fault Status: 00111011
                    Reset counter: 61
                    Mileage: 96273 km
                    Date: 2014.03.24
                    Time: 14:32:00
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AC
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000030142840
   Coding: 042036
   VCID: 24042BF927384C1A97-8071
   Subsystem 1 - Part No SW: 8K0 959 772 A    HW: 8K0 959 772
   Component: SLR-B8  H05 0003
   Coding: 070000
   Part No SW: 4F0 910 279 R    HW: 4F0 907 279
   Component: ILM Fahrer      H26 0340
   Coding: 0033123
   VCID: 383CEF894BB038FA2B-806D
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Fault Status: 00100111
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 103976 km
                    Date: 2014.09.04
                    Time: 17:07:00
Address 0E: Media Player 1
   Component: 72 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09D6WO
   Coding: 0014130
   VCID: 2B16C0C58AE6836256-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME095252244
   Subsystem 3 - Serial number: 6342QSME2C5226308
   Subsystem 4 - Serial number: 6352QSME594D5304K
   Subsystem 5 - Serial number: 6362QSME474F322CR
   Subsystem 6 - Serial number: 63734SME764C06182
   Subsystem 7 - Serial number: 63834SME0F4C1F3CL
00532 - Supply Voltage B+
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026100450039
   Coding: 0002142
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 982 P    HW: 4L0 920 982 P
   Component: KOMBIINSTR.   H08 0147
   Revision: 00200000    Serial number: DKY24503A
   Coding: 835564040101CF05020201
   VCID: 3E30F991A99406CAE1-806B
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M10207004C
   Coding: 000303
   VCID: 3A38F581B5BC2AEADD-806F
   Component: J367-BDM  H07 0125
                    Reset counter: 0
                    Mileage: 105689 km
                    Date: 2014.09.22
                    Time: 18:14:14
                    Bin. Bits:    10111
                    Voltage: 11.10 V
                    Count: 7
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000030142504
   Coding: 0000006
   VCID: 689C7FC95B90687A7B-803D
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 100492 km
                    Date: 2014.07.24
                    Time: 17:05:50
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 J    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7860
   Revision: --H03001    Serial number: 15.1528-0122.2
   Coding: 0015520
   VCID: 312AD2ADA8CAE9B26C-8064
01577 - Turn-Off due to Over-Temp
                    Reset counter: 37
                    Mileage: 105270 km
                    Date: 2014.09.17
                    Time: 17:49:38
                    Error Code: 68
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010067701
   Coding: 00581B00000011110000
   VCID: 312AD2AD68CAE9B26C-8064
   Component: J0769_SWA_MasterH01 0050
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E10C9D1B9F4F64A71-807B
   Component: J0770_SWA_Slave_H01 0050
   Subsystem 3 - Serial number: 5F26.01.1000H010003C910564ÿ
   Subsystem 4 - Serial number: 910564ÿ
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102944762
   Coding: 011F57205E40440004
   VCID: 46C09171F1445E0AA9-8013
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01271326130000
   Coding: 3569821
   VCID: 3522E6BD5CA2C59230-8060
Address 47: Sound System
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H02 0110
   Revision: 00000506    Serial number: 00005061104237
   Coding: 0696269
   Shop #: WSC 06117 444 105162
   VCID: 230628E5E2364B22EE-8076
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000062903
   Coding: 0012001
   VCID: 5EF0591189D426CA81-800B
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102953256
   VCID: 45C2967DCC425512A0-8010
   Part No: 8P0 907 357 H
   Coding: 0000008
   VCID: 3FCE84956E9E0FC2EA-806A
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335BW0A7554733
   Coding: 020000010000000000
   VCID: 1D721E1D04527DD2D8-8048
02788 - Internal Communications Error
                    Reset counter: 20
                    Bin. Bits: 00000001
   Part No SW: 4L0 035 664 A    HW: 4L0 035 664 A
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 489C+0A7526354
   Coding: 010200060004F3EF51002305EF6300030000
   VCID: 291A3ACD401A9172A4-807C
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
   Component: E0380 Bedient  H05 0060
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000102984595
   Coding: 010E57204040230004
   VCID: 43C68865C2766B228E-8016
Address 69: Trailer (J345)       Labels: 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H08 0070
   Revision: 2A001001    Serial number: 00000126676147
   Coding: 0200000000000000
   Revision: --H03---    Serial number: 525PA8-J0240VO
   Coding: 1021001
   Part No SW: 4L0 910 945     HW: 4L0 827 851 D
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: 8K9827852  B
   Shop #: WSC 98765 666 38354
   VCID: 6C9403D94F68445A1F-8039
   Subsystem 3 - Serial number: RD03.03.10--H29001001C0010ÿ
   Subsystem 4 - Serial number: 1C0010ÿ
Address 6F: Centr. Conv. II        Labels: None
   Part No HW: 4L0 907 290 A
   Revision: AAH05061    Serial number: 003895936-----
   VCID: 55E2463DBCE2E592D0-8000
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000102984468
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H02 0100
   Revision: 00H02000    Serial number: 85131000701361
   Coding: 0231366
   VCID: 2C14C3D98FE8845A5F-8079
End-------------------------(Elapsed Time: 03:42)--------------------------
Early Q7 TDIs needed that reset via Adaptation Channel 80, but my understanding is this was changed with an ECU update.
I suspect the reason your Adblue light is on is not because the vehicle thinks it's low on fluid but because of the fault codes related to that system:
                    Mileage: 101973 km
                    Date: 2014.08.04
                    Time: 12:22:51
                    RPM: 1764 /min
                    Speed: 89.6 km/h
                    Voltage: 14.06 V
                    (no units): 0.58
                    (no units): 0.61
                    (no units): 1.38
                    Mileage: 105147 km
                    Date: 2014.09.16
                    Time: 15:20:53
                    RPM: 1365 /min
                    Speed: 71.7 km/h
                        8 ppm
                        88 ppm
                    Duty Cycle: 99.6 %
                    Mileage: 104896 km
                    Date: 2014.09.14
                    Time: 10:24:10
                    RPM: 1575 /min
                    Speed: 47.0 km/h
                    Voltage: 14.29 V
                    (no units): 0.24
                    (no units): 0.61
                    (no units): 1.82
                    Mileage: 105539 km
                    Date: 2014.09.21
                    Time: 10:03:11
                    RPM: 2163 /min
                    Speed: 109.8 km/h
                    Voltage: 14.06 V
                    (no units): 0.00
                    (no units): 0.60
                    (no units): 1.72
My guess is there's something actually awry with the reductant injection system. But... Have you tried clearing these codes? If so, how quickly do they come back?
gerber114
New Member
I cleared the codes last night and on my way to work the check engine light and Add Adblue lights came on again...only 6 miles down the road...one weird thing i noticed is the adblue showed 400miles till empty last night before clearing codes and this morning when it came back on it showed 600miles...at least I gained some time!! I scheduled a dealer visit in the mean time but i agree with you that something is wrong with the adblue injector system!
Andy
Sector 7G
HC424490
Out of curiousity, did you check which codes returned after the light came back on?
gerber114
New Member
See the codes after the light came back on this morning...what does "Reductant Quality Performance" mean? When I added DEF, I went to the local auto store and bought a name brand fluid right off the shelf?
Thursday,25,September,2014,19:29:31:58291
Mileage: 105890km-65796mi   Repair Order:
VIN: WA1WMBFE7AD006296   Mileage: 105890km-65796miles
                    Mileage: 105835 km
                    Date: 2014.09.25
                    Time: 06:34:37
                    RPM: 2079 /min
                    Speed: 105.3 km/h
                    Voltage: 14.21 V
                    Temperature: 294.0°C
                    (no units): 0.00
                    (no units): 0.59
                    (no units): 1.72
                    Mileage: 105835 km
                    Date: 2014.09.25
                    Time: 06:34:37
                    RPM: 2079 /min
                    Speed: 105.3 km/h
                    Voltage: 14.21 V
                    (no units): 0.00
                    (no units): 0.59
                    (no units): 1.72
Readiness: 1 2 0 0 1
   Coding: 0001016
   Revision: 00H30001
   Coding: 0103569
   Coding: 0000135
                    Reset counter: 15
                    Mileage: 96217 km
                    Date: 2013.12.18
                    Time: 14:32:03
                    Reset counter: 84
                    Mileage: 96217 km
                    Date: 2013.12.18
                    Time: 14:32:03
                    Reset counter: 66
                    Mileage: 96375 km
                    Date: 2014.04.09
                    Time: 15:12:36
                    Reset counter: 61
                    Mileage: 96273 km
                    Date: 2014.03.24
                    Time: 14:32:00
   Coding: 042036
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 A    HW: 8K0 959 772
   Coding: 070000
   Coding: 0033123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 103976 km
                    Date: 2014.09.04
                    Time: 17:07:00
   Coding: 0014130
   Coding: 0002142
   Coding: 000303
                    Reset counter: 40
                    Mileage: 105689 km
                    Date: 2014.09.22
                    Time: 18:14:14
                    Bin. Bits:    10111
                    Voltage: 11.10 V
                    Count: 7
   Coding: 0000006
                    Mileage: 100492 km
                    Date: 2014.07.24
                    Time: 17:05:50
   Coding: 0015520
                    Reset counter: 41
                    Mileage: 105270 km
                    Date: 2014.09.17
                    Time: 17:49:38
                    Error Code: 68
   Coding: 0010001
   Coding: 3569821
   Coding: 0696269
   Coding: 0012001
   Coding: 0000008
                    Reset counter: 20
                    Bin. Bits: 00000001
   Coding: 1021001
   Coding: 0231366
End-------------------------(Elapsed Time: 03:33)--------------------------
I suspect it means that the ECU thinks that the DEF in the tank is NFG. There's a sensor in the tank that checks the DEF's quality somehow. I could see where bad DEF might also cause a NOx Cat Efficiency too Low code
revo_bry
New Member
HC441633 (Second Hand)
had this issue a few times, u need to carry out an emergency regeneration regardless of dpf condition then drive beetween 90km and 130km for 600 seconds then cycle ignition then all will be well
