I am swapping a European 5cyl TDI (engine code AJT) into a U.S. Eurovan. It was originally a VR6 AXK with an auto trans. The cluster, immobilzer, and key pill were swapped to match the ecu. It's running great on diesel now, and control units are mostly happy except for ABS. I need the correct login and coding for the ABS system with EPC. I can get PR numbers for either vin if needed. Any help would be greatly appreciated.
vin for the VR6 van: WV2KB47002H067736
vin for the TDI van: WV1ZZZ70Z3H101278
Monday,12,February,2018,11:51:54:45387
VCDS Version: 18.1.0.2 (x64) HEX-NET CB: 0.4411.4
VIN: WV1ZZZ70Z3H101278 License Plate:
Mileage: 312980km-194476mi Repair Order:
Chassis Type: 70 (7D - VW Transporter/Multivan (1996 > 2004))
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
VIN: WV1ZZZ70Z3H101278 Mileage: 312980km-194476miles
Part No: 074 906 018 AK
Component: 2,5l R5 EDC 0000SG 3905
Coding: 00002
Shop #: WSC 02757
VCID: 5F8E493ADF8CD7BDEC-4B7A
WV1ZZZ70Z3H101278 VWZ1Z0B2287967
17849 - EGR Valve (N18)
P1441 - 35-10 - Open Circuit or Short to Ground - Intermittent
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 7D0-907-379.lbl
Part No: 7D0 907 379 E
Component: ESP 5.3 T4 FRONT V37
Coding: 06732
Shop #: WSC 12345
VCID: 3326F58A038423DD78-5160
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
36-00 - Open Circuit
01203 - Electrical Connection between ABS and Instrument Cluster
35-00 - -
Part No: 7D0 907 040
Component: CLIMATRONIC 0004
Coding: 00032
Shop #: WSC 02743
VCID: 5F8E493ADF8CD7BDEC-25B6
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 BM
Component: AIRBAG VW3 - V04
Coding: 16973
Shop #: WSC 02743
VCID: 75A20B924D707DED96-4B7A
Address 17: Instruments Labels: 7D0-920-xxx-17.lbl
Part No: 7D0 920 903 B
Component: T4-KOMBIINSTR. VDO V26
Coding: 01252
Shop #: WSC 02743
VCID: 240406D6B66AB465F1-5160
01316 - ABS Control Module
Part No: 6N0 909 901
Coding: 00002
Shop #: WSC 02743
VCID: 70AC3A86321258C545-5160
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
VCID: 7DB213B2754025ADDE-4B3C
Address 35: Centr. Locks Labels: 7D0-959-800.lbl
Part No: 7D0 959 800 C
Component: Funksteuergerát 0001
Coding: 00001
Shop #: WSC 02743
VCID: 2D12E3F2E5A0752D2E-4B3C
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0005
Coding: 09400
Shop #: WSC 02743
VCID: 1E70343E98069EB5A7-51F2
End----(Elapsed Time: 02:27, VBatt start/end: 14.4V/14.4V. VIgn 0.0V)------
