Sticky HEX-NET or HEX-V2 Firmware Update Failed?
Sticky
   #141
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Click: [File] -> [Network Test]
   #142
widi
Hungary
C?ID=512383
not work:
   #144
Boki Ar
C?ID=57300
@widi, try another USB on PC or reboot PC & router, please.
   #145
Boki Ar
C?ID=57300
Now try a couple of HN2, update without any problem.
   #146
widi
Hungary
C?ID=512383
another USB on PC: not work
reboot PC and router: not work
reboot PC and internet from mobile phone: not work
   #147
Boki Ar
C?ID=57300
In that case, since I can't configure the ports, I would go to a neighbor or colleague where the update has been tested successfully. Maybe I would send it to a local VCDS distributor for an update.
Sorry, I have no better idea.
   #148
@widi , Please read and follow , click > HERE < , Worth a try (?).
   #149
OK, I see a problem with one (of the four) server instances.
Will try to get someone over there to give the server a whack on its side. This may take a bit, given that it's Easter Sunday...
widi
Hungary
C?ID=512383
Yes, it works, thank you!
I didn't have the fault, it worked well until yesterday. It didn't work this morning, I didn't do anything (I didn't configure TCP, UDP, firewall, etc.), now it's working again.
   #154
widi
Hungary
C?ID=512383
Thanks for the quick help!
And to everyone who tried to help!
Have a nice day! :)
   #156
rsp8
Australia
C?ID=329576
Struggling to update a registered cable which hasn't been used for a few years, all seems to be fine with network test but not able to get a good firmware file download and transfer. Device seems to 'disconnect' from Windows (at least it makes the windows sound like it's been unplugged) and goes to a solid green flashing LED only on the left side (with label facing up and cable towards you). Latest version of VCDS, Win10 enterprise, no changes made to default install options. Error is "Bad update download" followed by "Socket timed out". Any advice gratefully received.
   #157
Enterprise, eh? In what way is it locked down, and what nannyware is installed on it?
Try updating it on a different computer. You don't need to install VCDS if you don't want to, you can just grab VCIConfig.exe and hidapi.dll on a USB stick and run them directly from it.
