Sticky HEX-NET or HEX-V2 Firmware Update Failed?
Sticky
   #121
Tried everything, rebooting, uninstalling, reinstallling, different internet connections (wifi from home, thetered from mobile phone and such with no luck), deactivated windows firewall and many more.
Try again. Server was down for a bit earlier.
5PBKD
Spain
C?ID=312442
Thanks Uwe.. worked flawless.
Tomorrow I'll run an Auto Scan of my new car (Cupra Formentor - Chasis Code: KM shares Manufacturer code with Seat brand -VSSZZZ-).
   #123
BruceG
C?ID=359669
Update!! it works now :banghead:
Here's what I did... it may be helpful for someone in the same situation.
I attached my cable to my laptop and started VCIconfig, it gave me the same error! I unplugged the cable (without closing VCIconfig) to plug it back to a different USB port. I started the update and it went smooth after!!!
Odd and weird, but it works :confused: I spent 5 hours yesterday trying to update the firmware but this time it took less than 5 minutes!
Hello Everyone,
I can't update my firmware! I went through this post and did everything it says.
I tried two computers (laptop and desktop) using fresh VCDS software on both devices.
However, my CB says 0.0, and the cable flashes red, not blue or green.
Any idea how to fix it??
Thanks in advance.
VWT6
C?ID=295527
Attempt to update HEX-V2 from CB:0.4553 to 0.4555 lead eventually to the error depicted above - CB: 0.0 and left LED flashing red :eek:
A kind of early symptom was that the status line at the bottom was fluctuating randomly: Transferring 27% remaining 1, 19% 1, 23% 2, 1% 86, etc. I gave up after 2 hours and did the steps in the post above and the problem was solved in about 2 minutes :thumbs:.
PS. The registration issue - was it a bit random lengthy message "A vehicle identification number (VIN) is required to properly load data for UDS modules...." when trying to connect (any) module? Perhaps related only to recent CB version(s) as haven't seen that earlier?
PS2. @Eric thanks again for the "repeat"-functionality for the maps in Beta 21.8 >here< Extremely useful :thanks:
Isaac-1
SW Louisiana, USA
C?ID=438210
I have a HEX-V2 which I bought last spring and just did a software update, which now requires a firmware update, when I try to do the firmware update I get the same connection failure message noted above about can't connect to TCP port 11000, I have tried doing the firmware update 2 or 3 times per day for the last 3 days with no luck. Any help resolving this would be most appreciated.
   #126
DV52
C?ID=194404
@Isaac-1: Hi. I'm not sure if this will help, but some time ago when I first upgraded my laptop (to a later release Surface PRO), I had a similar issue with the TCP port 1100 message (in my case, I suspect that the bi-directional handshaking facility that TCP needs to operate wasn't happening correctly)
Anyhow - to fix the problem, I reconfigured the status of VCDS to "public" in windows defender screen below.
Again, not sure if your situation is the same, but it's an easy try - so worth a shot IMO!
   #127
We recently had another person all frustrated that he couldn't do a firmware update, and the problem ended up being the network/router he was using. So a different network connection (such as tethering off your phone's hotspot) is also worth trying.
MrWoodcock
Illinois, USA
C?ID=490763
My Hex-v2 is all of a sudden having an issue with interface staying connected. It's easily duplicated by trying to update the firmware but happens when I try other features like scanning a vehicle.
When I plug in the adapter I hear windows connect and the status light turn blue. Opening up the config, I can see the serial and version like it would expect.
X3OwSy3g5m_jNjSZCFbnxV12GxV_Oey2ECOqTxCDpYI4huGLZwq-MTOG00B-RdGp0j7M0Pxo9VZ_fUVrCLR9a6s0gGHWy5QosMaKCH-0U4D_W6nSdeJmnEgooMdxEIuEqjxs4ycfdA=w2400
Going to the update tab, I can check and locate an update.
YNUYP1epkMoO6UMqjsXT7eFwc48rGMx1oDC1VwDoqO4r4gFCL5dGbAuR9tsPee9bjSPOw1wrrVApHPkIkAh2O7E9RS8JkSgkv-PeJ7yujbg0DiNdLgv-JYi3GE-mM5G4tzFAwpvnwg=w2400
When I click download the interface disconnects, the light flashes green and stays that way.
H_TVO2Hh6pjUvHXyFkDE-XB_2dVhzeL05p75xAPGk9_aFjbSXl4SSTLShbujmXQrM-WXMMd8TbrynlvQuY3X1VvNy5GBPo0tCMx-OxsLYl1SdtLHLbvX8qxIrXXCHAqe6vJHqkAhSw=w2400
   #130
First thing to try: A different USB port (assuming you have one).
Second thing to try: Updating using a different PC. You don't need to install VCDS for this, you can just grab VCIConfig.exe and hidapi.dll.
Next thing to try: A different USB cable (any USB-A to USB-B "printer" cable).
If none of this solves the problem, please e-mail or call Support; your HEX-V2 is clearly still under warranty.
MrWoodcock
Illinois, USA
C?ID=490763
Different Computer worked! Little annoyed that my $3K laptop, which I have used before, is not working now.
Thanks!
Edit: Maybe the interface just needed to be updated. Now my laptop is connecting and scanning just fine.
Shaun
"Bad update download" sounds like you have some kind of antivirus or firewall type software that interfered with the download.
   #133
$3k? What kind of laptop is this? Details please?
Is it safe to think that you didn't uncheck "Fix Windows HID power mgmt..." in the installer?
Any chance it's putting the USB ports to sleep? Check Power Options -> Advanced Settings and make sure that "USB selective suspend" is set to Disabled:
egecko
C?ID=347315
Hopefully this information can help others that are having upgrade issues, as well information from previous posts.
I had this same problem within the 1st year of purchase (when I registered on the forums). It pretty much had the same results as everyone else, letting it update overnight, stuck on transferring, etc.
-I completed a hard reset 45-50 secs after reading a post from Uwe. NOGO
-Tried different computers Mac w/HexNetConfigV1.9 & V2.0, 2 Windows PC VCDS and both Ver of HexNetConfig. NOGO
-Miraculously a popup appeared and stated UDP PORT 777 and TCP PORT 10002 (Not PORT 11000).
-I verified Windows PC's IP address and opened both PORTS using PortForwarding to the PC IP.
example:
Destination IP/Port: 192.168.15.211:777
Protocol: UDP
Destination IP/Port: 192.168.15.211:10002
Protocol: TCP
Update completed within a few minutes and I was back up again.
Afterwards, I disable the PortForwarding until next time I update and just use Mac HexNetConfig for setup (and Windows only if needed).
**Of course I have to update the PortForwarding PC IP if I have to set to DCHP, but I keep it set for Static IP.
My network setup:
Fiber to the Home
Ubiquiti:
EdgeRouterX
USGPro (Unifi Security Gateway Pro)
16port PoE Switch
Several Access Points
  • Informative
cpockette
C?ID=353164
I recently experienced the same issue trying to update the firmware and found I had to temporarily reduce the security level on my WiFi Router from Maximum to Typical. This allowed for a successful network test and update.
  • Informative
What kind of router is it? Make & model might be useful here.
cpockette
C?ID=353164
COX communications brands it "Panoramic". The manufacturer is actually Arris , model TG1682G.
Click on "Firewall", then IPv4. You can then select the security level.
  • Informative
Ash3Auto
South Africa
C?ID=444321
Hi all
Had the same problem with update taking a long time to complete. Really frustrating to wait while a customer is waiting for their vehicle. Ended up closing the update after 2hours.
Tried the same thing that BruceG has done, updated in 2 minutes.
Thank you Bruce :)
Doccutter
C?ID=71879
Hello! Any chance the server is down? I’m trying to connect, my cable says it needs a firmware update, but I’m getting the error in VCIconfig, says it can’t connect to server.
   #140
widi
Hungary
C?ID=512383
I have the same, not connected to the server...
