Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: HEX-NET or HEX-V2 Firmware Update Failed?
  1. #31
    Jun 2014
    Swansea, UK
    It shouldn't take that long but there have been a few server problems since the release of 18.9.
    If it's stuck in a loop, abort it and try again
    Apparently I should put something witty or profound in here...
  2. Likes Boki Ar, Uwe liked this post
  3. #32
    Feb 2018
    Romania
    Hello gentlemen!
    Hex-V2
    Last night, I tried to update the interface, for new C.B 0.4505!
    After the update, which failed, the interface, forgets that C.B. C.B 0.4505 when I remove it from the USB port.
    Blinking red until update, and green after update.
    But if I remove it from the USB port, it blinks red again when I insert it!
    I can not finish the test because the buttons are gray!
    again and again
    Preparing Update
    No update files received.
    Socket timed out (2)
    Transfer Complete
    Update completed successfully
    again and again
    Last edited by LostAngel; 05-27-2019 at 11:43 AM. Reason: the interface is unusable!
  4. #33
    Quote Originally Posted by LostAngel View Post
    again and again
    Preparing Update
    Transfer Complete
    again and again
    What version of VCIConfig are you using?
    Server status looks nominal from here. It is a major US holiday today, so nobody is in the office to check in more detail.
  5. #34
    Feb 2018
    Romania
    I sent a private message!
    The problem is that every update is forgotten and CB reverts to 0,
    as soon as they insert the interface,
    and changing the Beta channel in Release or Release to Beta is error !
    V 2.244
  6. #35
    V 2.244
    Yes, I just saw it.
    Try 2.248 that comes with the VCDS Beta version you can download from this page.
  7. #36
    Feb 2018
    Romania
    I tried everything that was human, possibly, including beta, even older versions!
    I'm basically turning into a vicious circle!
    After the update, everything looks fine, but I can not save anything. Buttons are gray. If I remove the interface from the usb, everything starts from the beginning. I tried and on the car, nothing works because I can not complete the test. The interface has not been used at least 20 times. Basically it's new!
  8. #37
    Unplug interface. Let it rest for at least one hour. Go have a beverage in the meanwhile. Then try again. Please use 2.248. If it still behaves the same, I will need the people in the office tomorrow to take a look if they can see something wrong.
  9. Likes LostAngel liked this post
  10. #38
    Feb 2018
    Romania
    Preparing Update
    Transfer Complete
    CB 0.4505
    FW 0.256
    CFB 0.10
    BL 0.28
    Port status OK
    Interface Not Found!
    Overview H11.........
    CB 0.4505
    fw 0.256
    .................................................. ........make sure your interface is set to use the BETA Channel
    but this function does not work - Change chanal givme message- chanal switch failed
  11. #39
    Server indicates it is already set to Beta channel, but I think right now, this doesn't matter since 0.4505 is the latest version on both channels.
  12. #40
    Feb 2018
    Romania
    24h try to solve the situation! I'll try it later! If I succeed, I will let you know, but I tried everything that was humanly possible! I wish you a beautiful day!
