Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 109
Thread: HEX-NET or HEX-V2 Firmware Update Failed?
    Quote Originally Posted by Boki Ar View Post
    CB: 0.0 Is that a problem?
    Sure, it explains why the interface currently isn't useable with VCDS; but it's entirely recoverable.
  2. Likes Boki Ar liked this post
  3. #12
    Jan 2018
    I know formatting is extreme but want to start from scratch as i am running out of ideas.
  4. #13
    Apr 2015
    South Africa
    Hi Uwe
    The agents here in South Africa also tried to fix it through Teamviewer and telephonically.
    I send it back to them and they repaired it under warranty.
    Now I am a happy customer!
  5. Likes Boki Ar, Uwe, Eric, Derek liked this post
  6. #14
    Jan 2018
    Formated everything like i said laptop, router and installed everything from scratch and it all works fine now.
  7. Likes Andy, Uwe, Derek liked this post
  8. #15
    Oct 2017
    Maybe not the most tech solution, but ..I just go to the local library to use the windows machines and download the latest VCDS .exe file to a usb drive.
    Then take the usb home and update my window 10 laptop VCDS with the latest version on my usb stick..
    Then again, my laptop is a dedicated VCDS machine..
  9. #16
    Quote Originally Posted by shurur9 View Post
    That strategy will not a darn thing update the firmware in a HEX-NET or HEX-V2 interface.... You'd have to take it to the library and use their computer (or put your computer on their WiFi).
  10. Likes Boki Ar, PetrolDave liked this post
  11. #17
    Oct 2014
    Arandjelovac, Serbia
    Apr 2018
    update
    Hello, I hope this is correct area to post but since software and firmware update my V2 has been acting up, it will say not found then after restarting my laptop etc it will just start working, but today it took me 45 min to get it working and i have no idea why it did, this is unusual, it was always stable before update so i wanted to make you aware there may be an issue with recent updates.
  13. #19
    Quote Originally Posted by joe skinner View Post
    What is the behavior of the LEDs when it doesn't work?
  14. Likes Boki Ar liked this post
  15. #20
    Apr 2018
    I will try it today, see if it acts the same, i test it and it cannot find the dongle then i fiddle with thing restarting laptop , plugging and unplugging things and it starts working, but it was not this way before it worked everytime , so ill pay attention to leds , seems they were blue and then green when plugged into the audi but let me make sure!
