Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 109
Thread: HEX-NET or HEX-V2 Firmware Update Failed?
  1. #91
    Quote Originally Posted by Scott Evil View Post
    Could you point me in the right direction?
    If you're using that HEX-NET with the Windows version of VCDS, the lack of a DS update does not matter; it's only relevant to VCDS-Mobile.
    That said, I'm not seeing any obvious reason for this problem on our end. If you use VCDS-Mobile, try doing the update directly in VCDS-Mobile (the HEX-NET needs to be in Infrastructure Mode on a WiFi network that allows it to have internet access).
  2. Likes Dana liked this post
  3. #92
    Aug 2018
    Uwe,
    Thanks. I took your advice and shut everything down for about an hour, drank two pints of Guinness and the update finished just fine. Back in business. I have no explanation why the update didn't complete in one process. It is ok now.
  4. Likes Uwe, Dana liked this post
  5. #93
    Nov 2018
    LONDON UK
    Hi...I am having the same problems with the firmware update for my Hex-V2. I have tried 2 computers both with fresh and up to date installs of vcds 19.6.1 x64.I have rebooted my router and tried turning off firewall just for download and still no joy.It says, interface not found and also version mismatch detected I have copied a link with imgur for you to hopefully work out what is happening.....Thank You...
    https://imgur.com/a/cHTrm58
  6. Likes Mike@Gendan, Dana liked this post
  7. #94
    Jun 2014
    Swansea, UK
    Quote Originally Posted by DIRTYDUBS View Post
    Ross-Tech are investigating the version mismatch error at the moment, as we've reported a couple of cases to them too.
    If the problem is what they think it may be, they are hoping for a fix (which should happen server-side, so nothing you would need to do apart from waiting for it to be implemented) in the next few days.
  8. Likes Dana, Uwe, PetrolDave liked this post
  9. #95
    Nov 2018
    LONDON UK
    Thanks for your help,I will try it next week & see how we get on.
  10. Likes Mike@Gendan, Dana liked this post
  11. #96
    United States
    Hi Nick,
    We should have that issue resolved at this time. You may have to update twice, perhaps with unable to read version errors, in order to firstly recover the FW and secondly to recover the CB. Do let us know if you have any issues!
  12. Likes Mike@Gendan, Uwe liked this post
  13. #97
    Jan 2019
    Hex-V2 communication error after software update
    Sorry that this is my first post and asking for help at the same time but I seem to be having a similar issue after updating the software to the latest version today, the update went okay on the PC but now it's telling me there's a firmware update available but when I try to update is says all up to date. I have a no communication error when trying to access any modules but it does find the interface when plugged in to the PC using the VCI config
    The lead is a HEX-V2 and bought from Gendan in the UK.
    I don't seem to be able to post some screenshots of the errors
    Https://drive.google.com/folderview?...0ucVWREwWstYla
    Thanks in advance.
    Alex.
  14. #98
    Apr 2018
    There seems to be a global issue with the updates.
    In the german VCDS forum there are similar feedbacks.
  15. #99
    Quote Originally Posted by Alex P View Post
    Yes, I can see your interface should be getting an update. I believe the problem is on our end. We migrated the update database to new hardware and a newer version of MySQL yesterday, and I've seen a couple of similar reports. So I've tried some updates here myself and get the same thing, "You are up to date" when I can see the interfaces in question clearly are not.
    I'm confident this can be fixed, but I don't know what or how long it's going to take to fix it. I would hope we can get it resolved by Monday. A temporary work-around would to to uninstall the VCDS you currently have and install an older one that will work with the firmware currently in your interface. Shoot me a PM if you need help with that.
  16. #100
    Quote Originally Posted by Badboy99 View Post
    We think this is fixed now.
  17. Likes Eric liked this post
