Results 21 to 30 of 31
Thread: Driver Profile Select (MK7)
  1. #21
    Mar 2015
    Australia
    I had my Leon's cluster swapped to newer one. Original was from 2013, new was 2016, brand new 0km cluster. Completely different part number. ODIS rejected Guided function immediately by giving incompatible HW version notification. So we went to manual procedure from that point. IMMO adaptation which adapts the keys + removes CP was done with ODIS + FaZIT connection. Then manually inputted coding, adaptations etc. to the cluster with VCDS.
    And I watched the whole process as well and did the manual part myself as I wanted to make sure that mileage etc. are EXACTLY like in the old cluster.
    Maybe if the cluster is new enough, the guided function will work? Mine was without J&C crypto scheme and new one was J&C crypto.
    I have absolutely no idea what the restrictions would be on this...I just know that it worked on a very early MQB Golf going to Mk7.5 cluster.
    I know someone else who installed an Active Info cluster in his Mk2 Tiguan, but it was done the manual way as you have described.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  2. #22
    May 2017
    I'm not sure either. If the Golf 7 was from 2014 it already has Johnson Control crypto in the cluster so it is a bit different than the first 2013 MQB cars.
    Well, OP has used cluster so that is also no go with guided functions.
  3. #23
    Jan 2018
    Canada
    Here is a Scan from Yesterday :
    Monday,21,May,2018,14:59:09:46043
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 47 52 55
              5F A5
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091D00322466042F1000
       Shop #: WSC 03988 002 104857
       ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
       ROD: EV_ECM18TFS0208V0906264M.rod
       VCID: 46D5AB5B082CD0870BB-8012
       Part No SW: 0D9 300 014 M    HW: 02E 927 770 AS
       Component: DQ250-6A MQB  H54 5004
       Revision: 06454104    Serial number: TFK01702201596
       Shop #: WSC 00066 790 00218
       ROD: EV_TCMDQ250021.rod
       VCID: 221D17CBC444CCA7473-8076
              P1734 00 [002] - -
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 50697000000142
       Coding: 04FA6AA124230974807B030880C8292056249001C001943416435052C0A9430000000012121212B835351919323200
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 79AF10A709526F7F369-802C
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0433361821
       Coding: 032C1C
       VCID: 3B23CAAF43EE9D6F645-806E
       Part No SW: 5GM 907 044 E    HW: 5GM 907 044 E
       Revision: 00001K04
       Coding: 02020024200100010104004000101402
       Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: C86419041700C1
       Shop #: WSC 00066 790 00219
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 074B665F4FA6098F30D-8052
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    170207  043 0551
       Serial number: 97022066170216161029
       Component: RLHS  042 0105
       Serial number: S5Y17M03D16H08M29S31
       Coding: 06A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS22.409  H03 0004
       Serial number: 0000FST001EP42A00000
       Coding: 191800
       Roof Blind:
       Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS22.409  H03 0004
       Serial number: 0000FST001EP3Z600000
       Coding: 191800
       Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0054
       Revision: --------    Serial number: 39461701201855
       Coding: 0031167011
       ASAM Dataset: EV_EPHVA2CAU3700000 003021
       ROD: EV_EPHVA2CAU3700000_003_VW37.rod
       VCID: 47CBA65F0F26C98FF0D-8012
       Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
       Component: ACC BOSCH MQB H10 0620
       Coding: 3500004141FFC428949C810520300600000000000000000000
       Shop #: WSC 03988 002 1048576
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       VCID: 3C21C9B346E09A576DF-8068
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Component: AirbagVW20    011 0830
       Serial number: 003MHM03T2Z4
       VCID: 51FF8807F162073FAE9-8004
       Occupant Detection:
       Serial number: IBH000000000006VSLNQ
       Coding: 303136
       Subsystem 2 - Part No SW: -----------    HW: 480 000 303 17
       Serial number: 35700000000C848DE12Y
       Subsystem 3 - Part No SW: -----------    HW: 480 000 303 17
       Serial number: 35800000000300F0022
       Subsystem 4 - Part No SW: -----------    HW: 480 402 402 17
       Serial number: 35100019D2419652B7B4
       Subsystem 5 - Part No SW: -----------    HW: 480 400 203 17
       Serial number: 3520001AF247F120E410
       Subsystem 6 - Part No SW: -----------    HW: 480 400 603 17
       Serial number: 3550002B923C4E43F219
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 603 17
       Serial number: 3560002B923C4E422340
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 10031704221397
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 094F606759B27FFF269-805C
       Part No SW: 5G1 920 740 B    HW: 5G1 920 740 B
       Component: KOMBI         244 8311
       Coding: 0BA5101AED98880902886A0B5000000000000000
       VCID: 25170CD7D56A3B9F221-8070
       Component: GW MQB High   515 5286
       Serial number: 23041700840106
       Coding: 0901000870085900FA0002081C0F00000001050000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F3BEEFF879671CFD8D-807A
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150000155230105051
       Coding: 2FFFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0290003
       Serial number: HA1-00009.12.16
       Coding: 0001
       VCID: 4ACD9F6B1C3434E7EF3-801E
       Revision: 00000000    Serial number: 17000069102007
       Coding: 5D00000000000000
       Shop #: WSC 00066 790 07027
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E1936EB05217A5F-8060
       Component: HRE_Master    H12 0071
       Serial number: 0430453668
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0071
       Serial number: 0430474426
       Coding: 020111
       Serial number: 040417060508KX
       Coding: 003A13200000020000000000
       VCID: 43D3B24F3B1EE5AF2C5-8016
       Serial number: 00000000000006023537
       Coding: 011000
       Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
       Component: EPS_MQB_ZFLS  171 1072
       Coding: 1302
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 4FFB8E7FE75611CFB8D-801A
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H30 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA034G0U
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6D8734F74D1AC3DFAA1-8038
       Serial number: 1204170605090C
       Coding: 003A13200C00020000000000
       VCID: 42DDB74B2404ECA7273-8016
       Serial number: 00000000000004780646
       Coding: 091000
       Coding: 062A00010B000400
       VCID: 40D9BD432A08FEB7317-8014
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0755
       Coding: 027302020000000051220002001828001F0100F401200105C6
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 323DE78B94A45C27B73-8066
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H53 1031
       Serial number: VWZ8Z9TJX00M98
       Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
              B11CF 53 [009] - Deactivated
                        Reset counter: 72
                        Mileage: 9134 km
                        Date: 2018.05.21
                        Time: 14:35:57
                        Voltage terminal 30: 12.1 V
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 141 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 15021711P24359
       Coding: 000307020002020100221354C040490084000E100020
       ROD: EV_MFKBoschMQBB_VW27.rod
    End----(Elapsed Time: 01:39, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  4. #24
    Aug 2014
    Have you ever fixed it ?
    I'm trying the same on a Skoda Kodiaq. I've got the SWAP codes generated. They can be entered into the gateway with a tool that also starts with V :-)
    The coding - based on several cars should be:
    09 - BCM:
    IDE06507-MAS13132-Button in center console-Function of button 3 -> "Driving program"
    13 - ACC
    Byte 3 bit 7
    Byte 4 bit 6
    19 - Gateway:
    Byte 8 bit 1
    Byte 8 bit 3
    Byte 8 bit 6
    Byte 8 bit 7
    Byte 11 bit 2 (I'm not sure)
    Byte 11 bit 3
    Byte 12 bit 2
    Byte 12 bit 3
    ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_ Adaptation -> 180000 ms
    44 - Steering wheel
    Byte 6 bit 1
    I don't know if it solves the problem, but next week I'm trying to see if it's working or not. Only coding the adaption channel in 09 turned on the LED for a fraction of a second so the button and LED is working (well - I know - it's only 2% of the solution )
  5. #25
    May 2016
    As far as I know it is a SWAP product. With the license there is also some paramaterizon in gateway, same like CCS and MKE. Do with only coding it will no succeed i guess.
  6. #26
    May 2017
    I’m guessing Diskoboy is mixing pr code input and SWaP codes.
    You can input the pr codes to gateway with the other tool but that does not enable the product.
  7. #27
    Aug 2014
    I was really hoping when SWAP codes was added the functionality was unlocked. Basically just like adding license keys in other programs on your computer
  8. #28
    May 2017
    But you cannot add the SWaP codes/license yourself. You need factory connection for those.
  9. #29
    Verified VCDS User kreativ's Avatar
    Aug 2014
    Yes you can, if you got the right tools and know-how
    It can be done offline without factory connection
  10. #30
    May 2016
    You be first in the world I think. If you can add SWAP codes to gateway
