Monday,21,May,2018,14:59:09:46043
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 47 52 55
5F A5
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00322466042F1000
Shop #: WSC 03988 002 104857
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46D5AB5B082CD0870BB-8012
Part No SW: 0D9 300 014 M HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5004
Revision: 06454104 Serial number: TFK01702201596
Shop #: WSC 00066 790 00218
ROD: EV_TCMDQ250021.rod
VCID: 221D17CBC444CCA7473-8076
P1734 00 [002] - -
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 50697000000142
Coding: 04FA6AA124230974807B030880C8292056249001C001943416435052C0A9430000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 79AF10A709526F7F369-802C
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0433361821
Coding: 032C1C
VCID: 3B23CAAF43EE9D6F645-806E
Part No SW: 5GM 907 044 E HW: 5GM 907 044 E
Component: Climatronic H04 1801
Revision: 00001K04
Coding: 02020024200100010104004000101402
Part No SW: 5Q0 937 087 AN HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: C86419041700C1
Shop #: WSC 00066 790 00219
ROD: EV_BCMBOSCH_017.rod
VCID: 074B665F4FA6098F30D-8052
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170207 043 0551
Serial number: 97022066170216161029
Component: RLHS 042 0105
Serial number: S5Y17M03D16H08M29S31
Coding: 06A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST001EP42A00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST001EP3Z600000
Coding: 191800
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39461701201855
Coding: 0031167011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 47CBA65F0F26C98FF0D-8012
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Coding: 3500004141FFC428949C810520300600000000000000000000
Shop #: WSC 03988 002 1048576
VCID: 3C21C9B346E09A576DF-8068
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 011 0830
Serial number: 003MHM03T2Z4
VCID: 51FF8807F162073FAE9-8004
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000006VSLNQ
Coding: 303136
Subsystem 2 - Part No SW: ----------- HW: 480 000 303 17
Serial number: 35700000000C848DE12Y
Subsystem 3 - Part No SW: ----------- HW: 480 000 303 17
Serial number: 35800000000300F0022
Subsystem 4 - Part No SW: ----------- HW: 480 402 402 17
Serial number: 35100019D2419652B7B4
Subsystem 5 - Part No SW: ----------- HW: 480 400 203 17
Serial number: 3520001AF247F120E410
Subsystem 6 - Part No SW: ----------- HW: 480 400 603 17
Serial number: 3550002B923C4E43F219
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 603 17
Serial number: 3560002B923C4E422340
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 10031704221397
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 094F606759B27FFF269-805C
Part No SW: 5G1 920 740 B HW: 5G1 920 740 B
Component: KOMBI 244 8311
Coding: 0BA5101AED98880902886A0B5000000000000000
VCID: 25170CD7D56A3B9F221-8070
Component: GW MQB High 515 5286
Serial number: 23041700840106
Coding: 0901000870085900FA0002081C0F00000001050000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F3BEEFF879671CFD8D-807A
Component: E221__MFL-DC1 H16 0040
Serial number: 29150000155230105051
Coding: 2FFFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0290003
Serial number: HA1-00009.12.16
Coding: 0001
VCID: 4ACD9F6B1C3434E7EF3-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000069102007
Coding: 5D00000000000000
Shop #: WSC 00066 790 07027
ROD: EV_ELVMarquMQB.rod
VCID: 3431E1936EB05217A5F-8060
Component: HRE_Master H12 0071
Serial number: 0430453668
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0430474426
Coding: 020111
Component: TSG FS 020 0041
Serial number: 040417060508KX
Coding: 003A13200000020000000000
VCID: 43D3B24F3B1EE5AF2C5-8016
Serial number: 00000000000006023537
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 1302
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FFB8E7FE75611CFB8D-801A
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA034G0U
VCID: 6D8734F74D1AC3DFAA1-8038
Component: TSG BFS 020 0041
Serial number: 1204170605090C
Coding: 003A13200C00020000000000
VCID: 42DDB74B2404ECA7273-8016
Serial number: 00000000000004780646
Coding: 091000
Component: AFS-ECU H07 0090
Coding: 062A00010B000400
VCID: 40D9BD432A08FEB7317-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0755
Coding: 027302020000000051220002001828001F0100F401200105C6
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 323DE78B94A45C27B73-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9TJX00M98
Subsystem 2 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
B11CF 53 [009] - Deactivated
Reset counter: 72
Mileage: 9134 km
Date: 2018.05.21
Time: 14:35:57
Voltage terminal 30: 12.1 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 141 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 15021711P24359
Coding: 000307020002020100221354C040490084000E100020
ROD: EV_MFKBoschMQBB_VW27.rod
End----(Elapsed Time: 01:39, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
