Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Vw Eos AFS Coding
    May 2017
    Why can't you use the coding from the previous posters autoscan? It should be fine if you have the same car?
  2. #12
    Mar 2018
    Done. AFS works. Now only problem is with licence plate bulb error. Should I change byte 18 to any different value?
    I've checked "License Plate Light w/o Pulse Width Modulation (PWM) [LED Light]" in BCM.
    Friday,06,July,2018,01:08:16:43668
    VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
    VIN: WVWZZZ1FZBV008451   License Plate: EOS AFS
    Mileage: 92380km-57402mi   Repair Order:
    Chassis Type: 1F-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 26 37 42 44 46 52 55 56 61 62
              63 72
    VIN: WVWZZZ1FZBV008451   Mileage: 92380km-57402miles
    63-Entry Assist,D -- Status: OK 0000
       Part No SW: 03L 906 018 GA    HW: 03L 907 309 N
       Component: R4 2,0L EDC   H23 8089
       Revision: 41H23---    Serial number:
       Coding: 00190012042401080000
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_ECM20TDI01103L906018GA 003002
       ROD: EV_ECM20TDI01103L906018GA_VW36.rod
       VCID: 6FAE2029B637983CCE-803A
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Revision: 00H31001
       Coding: 543B6008092200022A0F06E9901A0052350000
       Shop #: WSC 00020 790 00000
       VCID: 76A0154DC16DA9F40D-8022
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000003
       VCID: 6E903D2DB13D9134C5-803A
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                        Reset counter: 239
                        Mileage: 92388 km
                        Date: 2018.07.06
                        Time: 01:01:14
    9481988 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Reset counter: 239
                        Mileage: 92388 km
                        Date: 2018.07.06
                        Time: 01:00:42
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0045
       Revision: BC011001
       Coding: 40000A3B8A251A6040080080140089EC43FD5F08602005606484E7040041
       Shop #: WSC 80093 222 69422
       VCID: 3B36C479BACF349C32-806E
       Subsystem 1 - Part No: 1Q1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 27101  26  0512
       Coding: 009795
       Component: RLS 241110 05  54  0403
       Coding: 0330CD
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 239
                        Mileage: 92388 km
                        Date: 2012.11.26
                        Time: 01:01:56
                            Term 15 On
                        Voltage: 12.20 V
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 239
                        Mileage: 92388 km
                        Date: 2012.11.26
                        Time: 01:01:54
                            Term 15 On
                        Voltage: 12.20 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 1Q0 919 475     HW: 1Q0 919 475
       Component: PARKHILFE 4K  H02 0005
       Revision: --------    Serial number: 32931028701603
       Coding: 10C001
       ASAM Dataset: EV_EPHVA14VW4650000 001003
       ROD: EV_EPHVA14VW4650000.rod
       VCID: 75A21241D46BA2EC04-8020
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 B    HW: 1Q0 959 655 B
       Component: 0M Airbag VW8C      0210
       Revision: 92011021    Serial number: 003G20008Y6Q
       Coding: 0012365
       VCID: 3B36C4797ACF349C32-806E
       Subsystem 1 - Serial number: 6332SRB40D214C8D8
       Subsystem 2 - Serial number: 6342SRB40D23CF203
       Subsystem 3 - Serial number: 637  RB4        8
       Subsystem 4 - Serial number: 638  RB4        9
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101203201191
       Coding: 1082140000
       ASAM Dataset: EV_SMLSNGVOLWS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76A0154DC96DA9F40D-8022
       Coding: E20000
       Part No SW: 1Q0 920 875 A    HW: 1Q0 920 875 A
       Coding: 171F01
       VCID: 3228E95D6585F5D4E1-8066
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 271110F2000016
       Coding: 355000
       Shop #: WSC 00020 790 12345
       VCID: 312AE6516883CECC98-8064
       VCID: 6A98313D8DD57D1499-803E
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 F    HW: 1Q0 959 255 F
       Component: Verdecksteuergeraet 0854
       Revision: 0033100Q    Serial number: 103200704
       Coding: 0655374
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2K8348200
       Coding: 000004110400000000041000
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: 608C53157BE9374447-8034
    1048599 - Rear Left Treble Speaker
              B1066 13 [009] - Open Circuit
              [tweeter rear left open load]
                        Reset counter: 239
                        Mileage: 92388 km
                        Date: 2018.07.06
                        Time: 01:04:38
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2143
       Coding: 0151735
       VCID: 393ADE7170F3068C20-806C
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 312AE651A883CECC98-8064
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0151990
       VCID: 3A38C17D75F50D9429-806E
       Part No SW: 5M0 907 357 D    HW: 5M0 907 357 D
       Component: AFS-Steuergeraet    0149
       Coding: 1770963
       Shop #: WSC 06441 785 00200
       VCID: 3522D2415CEBE2ECC4-8060
       Subsystem 1 - Part No: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0003
       Coding: 00000027
       Subsystem 2 - Part No: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0003
       Coding: 00000027
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71AA2651A8038ECCD8-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370213651
       Part No SW: 1Q0 959 811 B    HW: 1Q0 959 811 B
       Component: Tuer-SG         004 0602
       Coding: 0131216
       Shop #: WSC 00020 790 1012544
    Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
       Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
       Component: J572  EASYENTRY FS  0603
       Revision: 00H04000    Serial number: 5DS008646-01--
       Part No SW: 1Q0 959 812 B    HW: 1Q0 959 812 B
       Coding: 0131216
       VCID: 3620D54D41EDE9F4CD-8062
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.2V)-----------
  3. #13
    May 2017
    Just install resistors in parallel to the led bulbs. Much easier.
    And congratulations on successful AFS bixenon retrofit
  4. #14
    Stoke on Trent, England
    New User Keith
  5. #15
    Mar 2018
    02805 - that isn't a problem. As You can see in second scan Roof Elect. is OK.
  6. #16
    The second scan shows:
    02805 - System Interference
    That's why I posted that link.
    New User Keith
  7. #17
    Mar 2018
    Second scan shows:
    Coding: 0655374
