Hi, So long story short, I was hoping to get more out my External Exhaust actuators (Installed Kufatec Sound Booster) but I found no sound at all (Not even in Sport mode - no Audi Drive select, So I activated it via this YouTube post - https://youtu.be/J0cws5oAc4M ), did the Debugging as per Kufatec - all seemed fine. So after VCDS found initially 2 fault codes 2nd one was simple the plug was not properly connected. But the First fault is the most concerning!
Seems that I have done something in my Coding to activate Audi Drive Select in MMI that has caused this, Any clues what I did?
Address C0: Act.for Ext. Noise Labels 4G0-907-160.CLB
Control Moule Part Number:8R0 907 160 HW 4G0 907 160 B
Component and/or Version: SAS-GEN 2 AGA H09 0002
Software coding:
Workshop Code:
ASAM Dataset: EV_ActuaForExterNoise UDS 003013 (AU48)
ROD: EV_ActuaForExterNoise UDS.rod
VCID: 71AA337DA0A2EBCD4A-8025
2 faults Found:
0005 - Incorrect Vehicle Type
U10D9 00[008] - -
[Keine Funktion durch Falschverbau im Fahrzeug- -> keine Funktion]
Reset Counter: 194
Mailage: 159953
Date: 2018.01.25
Time: 18:09:23
Software coding:
Workshop Code:
2 faults Found:
U10D9 00[008] - -
Reset Counter: 194
Mailage: 159953
Date: 2018.01.25
Time: 18:09:23
