Results 1 to 5 of 5
Thread: Cruise control label 7E0 BCM --> cancel switch
    Aug 2016
    The Hague, NL
    Hey guys, hope I'm not interrupting anyone watching the Bathurst 12h race. Spoiler alert: just completed the 1st racing lap.
    The advanced measurement values of the 7E0 937 090 BCM of the cruise control, more specific, the cancel switch seems to be the wrong way around.
    If the switch is at 'on' it says at the cancel button 'activated' and if cancel is selected, it says 'not activated'.
    I do apologise for the bad video quality but it's a bit dark an keeping both the screen and the stalk visible was a bit tricky.
    If you look closely, you can distinguish 'activated' and 'not activated'.
    The switch works the way it's intended:
    equipment:
    Tuesday,30,January,2018,15:48:11:11868
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
    VCDS Version 18.1.0.2  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZ6RZBYiichel  License Plate:
    Mileage:    Repair Order:
    Chassis Type: 6R-VW25 (7E0)
    Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
              61 69 6C 77
    VIN: WVWZZZ6RZBYiichel   Mileage:
    Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 B    HW: 03P 907 425
       Component: R3 1.2l TDI   H06 9980
       Revision: 12005001    Serial number:
       Coding: 00114036033401080000
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_ECM12TDI03103P906021B 001043
       ROD: EV_ECM12TDI03103P906021AA.rod
       VCID: 270B06DDAF6FF1FF09F-8073
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
       Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
       Component: ESP9.0i front H02 0002
       Serial number: --------------
       Coding: 21DD4885432500C5841A126EC25500521505
       Shop #: WSC 00049 770 00138
       ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
       ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
       VCID: 0F7B4E7D27DF89BFE1F-805B
       Part No SW: 6RA 959 654     HW: 6RA 959 654
       Component: LENKW.SENSOR  H02 0020
       Serial number: 090465LBH0000C
       Coding: 01
       ASAM Dataset: EV_LWSKLOVW25X 005002
       ROD: EV_LWSKLOVW25X.rod
       Revision: 00092000    Serial number: 0346244897
       Coding: 030C0C
       ROD: EV_KESSY_PQ35GP.rod
       VCID: 372BD69D7FCF617F99F-8063
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
       Component: Climatronic   H12 0812
       Revision: V0000000
       VCID: 3829D5A172516E07905-806D
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0733
       Revision: B9080001    Serial number: 0771 092150183
       Coding: 3CB02FF828CB2400933806E2FFEB9FD080A273EFE08D78D0A2  E400030800
       VCID: 688945E162713E87C05-803D
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 140415 03  37  0059
       Coding: 0380DD
       Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 8611
       Serial number: KU0KU011111300010103
       Coding: 0200A3
       Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 8611
       Serial number: KU0KU007111300016463
       Coding: 1000AB
       Subsystem 4 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 1K8 951 171 A
       Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
       Component: E221__MFL-DC1  H03 0103
       Serial number: 27140002547420014516
       Coding: A4FFFF
       Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
       Component: J388__TSG_HL  002 0803
       Serial number: KU0-KU008.06.0910897
       Coding: 08BC32
       Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
       Component: J389__TSG_HR  002 0803
       Serial number: KU0-KU004.06.0913330
       Coding: 08BC32
       Part No SW: 7E0 919 475 L    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0106
       Revision: --------    Serial number: 28231422402620
       Coding: 318001
       ASAM Dataset: EV_VW75XParkAssis8K 001003
       ROD: EV_EPHVA18VW250GPCS_VW25.rod
       VCID: 3B23CAAD43E7451F7D7-806F
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag01M H10 0020
       Revision: --------    Serial number: 003GX0142TCE
       Coding: 00314D
       Shop #: WSC 01383 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4ACD9F691C3DEC97F61-801F
       Serial number: 3575HRB40650BI7U48C8
       Serial number: 3585HRB405J09RECEOUJ
       Serial number: 3515RRB405T0BTBEF9G7
       Serial number: 3525RRB405R0BTBEKPFQ
       Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
       Component: KOMBI         H04 0709
       Coding: 140E01
       VCID: 3333E28D6BB78D5FA57-8067
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0733
       Revision: B9080001
       Coding: 042200
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 7E0 857 511 G    HW: 7E0 857 511 E
       Component: FLA           H10 0003
       Revision: AA001001
       Coding: 040C00E200000000000000
       ASAM Dataset: EV_HighBeamAssisAU316 001004
       ROD: EV_HighBeamAssisAU316.rod
       VCID: 2E05F3F98095A0B7CA9-807B
       Component: IMMO          H04 0709
       Coding: 000007
       VCID: 6A8D3FE97CFD0C97D61-803F
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
       Component: ELV-PQ35      H20 0240
       Revision: 00000000    Serial number: 11000256123005
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2F3BEEFD879FA9BFC1F-807B
       Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Revision: A1001003    Serial number: 7666620365
       Coding: 010100
       VCID: 2B03FAEDB307D59FED7-807F
       Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
       Component: RNS-MID       H26 6276
       Revision: AB001001    Serial number: VWZ6Z7P1950254
       Coding: 00070002010000A10001
       VCID: 3635DB9978459877829-8063
       Component: EU West V15  8515
       Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
       Component: SWA Master    H07 0030
       Serial number: 0384674663
       Coding: 030321
       Shop #: WSC 54321 321 54321
       ROD: EV_LaneChangAssis_VN75.rod
       VCID: 3039ED819AA1B647D85-8065
       Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0030
       Serial number: 0432634593
       Coding: 030321
       Part No: 6R0 423 156 B
       Coding: 11241
       Shop #: WSC 54321
       VCID: 2F3BEEFD8E5FA9BFC1F-807B
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H08 6831
       Revision: --------    Serial number: EAA098C0000052
       ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
       ROD: EV_AudioVerst10KanalSTT4.rod
       VCID: 280905E1A271FE87005-807D
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357     HW: 6R0 907 357
       Component: LWR-ECU       H02 0070
       Coding: 0192000001000000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
       ROD: EV_HeadlRegulVWLWRPt_VW25.rod
       VCID: 77AB169D3F4FA17F59F-8023
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0733
       Coding: 030F1A5A
       Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
       Component: J367-BDM  H08 0223
       Serial number: 61083A44504351928092
       Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
       Component: Anhaenger     H07 0080
       Revision: 3A002002    Serial number: 00000116932377
       Coding: 0100000100000000
       VCID: 2F3BEEFD871FA9BFC1F-807B
       Part No SW: 7E0 907 441     HW: 7E0 907 441
       Revision: 00H08000    Serial number: 525PA8-J060533
       Coding: 0030115
       VCID: 65974CD5996323EFFB3-8031
    Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
       Component: Telefon       025 0983
       Revision: --------    Serial number: 35502105254406
       Coding: 020100000100010000000101
       ASAM Dataset: EV_UHVPremi 002709
       ROD: EV_UHVPremi.rod
       VCID: 25170CD5D563E3EF3B3-8071
    End----(Elapsed Time: 02:19, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
  2. Likes Uwe, Dana liked this post
  3. #2
    United States
    Hi Michel,
    I'm not entirely sure if we checked/modified that label since this report. The YouTube videos aren't working anymore (likely due to time since creating them).
    I believe R-T is limited to one vehicle with that BCM type (2017 Jetta S 5 speed) so we can check the function on that car but it has the newer Mk7 type of steering wheel. There may be some discrepancies due to the newer wheel alone when compared to our early stalk-type CCS label file work.
    I'm subscribing to this thread as a reminder to revisit this file. Please do bump it back up if you still see the discrepancy with a current version of VCDS.
    Thanks,
    Dana
  4. Likes Santos liked this post
  5. #3
    Aug 2016
    The Hague, NL
    Hi Dana, using the latest VCDS and checking advanced MB:
    Stalk switch in ON:
    Cruise switch switch is ON
    Cancel switch is shown as operated
    Stalk switch is set to cancel
    Cruise switch is ON
    Cancel switch is shown as not operated
    Should be the other way around, I guess.
  6. Likes Uwe, Dana, Eric liked this post
  7. #4
    United States
    Thanks Michel. The current 7E file reads:
    004,0,Cruise Control Positions (CCS)
    004,1,Cruise Control,Main Switch,Range: ON/OFF/Not Installed
    004,2,Cruise Control,Cancel Switch,Range: ON/OFF/Not Oper.
    004,3,Cruise Control,SET/Decelerate,Range: ON/OFF/Not Oper.
    004,4,Cruise Control,RESET/Accelerate,Range: ON/OFF/Not Oper.
    My early 6R work contained:
    004,1,CCS W/O Activation,,Range: On / Off /Not Installed
    004,2,CCS Cancel,,Range: On / Off / Not Oper.
    004,3,CCS Decel,,Range: On / Off / Not Oper.
    004,4,CCS Accel,,Range: On / Off / Not Oper.
    I took a peek at the 6J Ibiza data (found in guided fault finding using a time machine) and it showed 004.1: GRA Switch in position without activation. 004.2: GRA switch in position - Cancel.
    That must be what I meant by "CCS W/O Activation" because it doesn't make much sense to current-day Dana I believe most of those old Seat documents were translated from Spanish to German followed by English so .. details easily end up scrambled.
    I'll hold off on editing 7E0-937-BCM-V1.lbl until I hear back from Santos. His control module map showed the following with (steering wheel control) CCS off:
    4,0,,
    4,1,,,
    ;OFF,,
    4,2,,,
    ;Not Oper.,,
    4,3,,,
    ;Not Oper.,,
    4,4,,,
    ;Not Oper.,,
  8. Likes Uwe, Eric liked this post
  9. #5
    Aug 2016
    The Hague, NL
    Hi Dana, here is a new video:
  10. Likes Uwe, Dana liked this post
